call diversion doesn't work to external numbers, transfer works ok
It's the new install, from all handsets:
- I can call mobiles/external numbers
- I can transfer to mobiles/external numbers
- I can not divert to mobiles/external numbers (in example immediate divert to mobile)
All features and barring are configured correctly (exactly the same as on another working system, I checked every single option).
When I try to divert I hear female voice after couple of seconds saying: "you are trying to access the service to witch you are not subscribed". Is it Alcatel PBX saying me this message?
We replaced cisco solution with Alcatel one... and this problem didn't exist before.
Any suggestions will be REALLY appreciated.
Jola
Jola
I guess the key here is: "Destination address is non-ISDN"?
This is the exact output I am getting when trying immediate divert to mobile:
ISDN3_00031 04/06 15:39:42 TX d_channel: 18 (S:00 T:000) payload: (67) 08 02 00 63 05 A1 04 03 80 90 A3 18 01 A3 1C 1D 91 A1 1A 02 01 12 02 01 0F 30 12 02 01 01 0A 01 01 A1 0A A0 08 80 06 34 33 32 33 38 35 1E 02 85 83 70 0C 81 30 37 39 38 34 31 39 32 30 30 30 7D 02 91 81
0x05 SETUP Ref: O,99
ie 0xA1 Sending complete
ie 0x04 Bearer capability: 80 90 A3
Coding: CCITT standardized
Information transfer capability: Speech
Transfer mode: Circuit mode
Transfer rate: 64 Kbit/s
User info layer 1: G.711 A-law
ie 0x18 Channel identification: A3
Interface identifier: Implicit
Interface type: Primary rate
Indicated channel: Preferred
D-channel identified: No
Information channel selection: any channel
ie 0x1C Facility: 91 A1 1A 02 01 12 02 01 0F 30 12 02 01 01 0A 01 01 A1 0A A0 08 80 06 34 33 32 33 38 35
ie 0x1E Progress indicator: 85 83
Progress: Origination address is non-ISDN
ie 0x70 Called party number: 81 30 37 39 38 34 31 39 32 30 30 30
Number type: Unknown
Numbering plan: ISDN/Telephony(CCITT Recommendation E.164/E.163)
Number: 07984192000
ie 0x7D High layer compatibility: 91 81
ISDN3_00032 04/06 15:39:42 RX d_channel: 18 (S:00 T:000) payload: (10) 08 02 80 63 02 18 03 A9 83 82
0x02 CALL_PROCEEDING Ref: D,99
ie 0x18 Channel identification: A9 83 82
Indicated channel: Exclusive
D-channel identified: Yes
Information channel selection: B1 channel
Channel type: B-channel units
Channel number: 0x02
ISDN3_00033 04/06 15:39:43 RX d_channel: 18 (S:00 T:000) payload: (9) 08 02 80 63 01 1E 02 84 82
0x01 ALERTING Ref: D,99
ie 0x1E Progress indicator: 84 82
Progress: Destination address is non-ISDN
Number: 07984192000
apologies for late response.
Joining: everything is selected except analog/analog
ARS: we don't use it, it has factory default config I would say
External numbering plan: attached
trunk group is public
calling station is handest ip touch 4038, call is diverted to mobile number or speed dial number which is mapped to a mobile number.
Not sure what do you mean by services. I will attach feature rights.
