OPS Backup Erros
Steveo
OPS Backup Erros
Post by Steveo »
Any ideas?
Code 6.1
Confirm the backup of OPS files on your cpu disk (y/n, default y): y
WARNING: no valid wb04b03a.hw file
Warning rack 18: OPS, invalid location at line 43
Warning rack 19: unknown OPS shelf type found
ops 2.0.2: operation successful
Updating hardware.mao according to data base ok
ERROR: Found 2 *.swk files in /DHS3data/mao. 1 is expected. Operation canceled
Creating ops.lis
sadim
Post by sadim »
delete the old .swk file in /usr4/BACKUP/OPS
Steveo
Post by Steveo »
there is nothing in there...
(101)CAO-PBX> cd /usr4/BACKUP/OPS
(101)CAO-PBX> ls
ops.lis
(101)CAO-PBX>
it's in /DHS3data/mao
iourid
Post by iourid »
I think you have two *.swk files in /usr3/mao, one wb04b03a.swk, another WB04B03A.swk
Steveo
Post by Steveo »
thank you...! yeah old file in there. no problems now
wizzy
Post by wizzy »
In this issue the one filename is in lowercase and the other in uppercase.
Which one should be deleted ??????
alurfe
Post by alurfe »
normally the file has same filename in .hw and .zip of OPS files. you can check that filename. usually is in lowercase.
best regards
hussain
Re: OPS Backup Erros
Post by hussain »
Dear Steveo
im facing problem in site while taking backup of ops like below
you said
is there any solution to take the backup??
Steveo wrote:Any ideas?
Code 6.1
Creating ops.lis
yeah read the topic solutionn is here
Return to “ON SITE TROUBLES”
