compatibility issue between pc installer and windows 7
johnsontiam
Post by johnsontiam »
hi friends,
i wonder anyone ever experienced or have information regarding pc installer with windows 7,
i tried it already and it doesn't work.
i use the same method and it succeed with pc installer on windows XP.
FYI, my pc installer version is 2.26.
Please do advice.
Many Thank's
Best Regards,
Johnson
swinstation
Post by swinstation »
I tried and I don't have problem what is your problem (pic)?
johnsontiam
oh..really you can?!?
what version of PC installer do you use friend?
i just try it on my vmware, but it doesn't work,
just stop there.
but it work perfectly fine if i use PC installer on XP, for OXE vmware also.
it just like it's not connect at all, the pc installer and the OXE.
it won't communicate at all.
thank's
swinstation
hi i use version 2.23 if you ca not connect to crystal ! you should type your install procedure 2 or 3 time after that you can connect easily I tried it yesterday it is necessary to mention when I connect to common hardware it connects at frist time but for crystal you should follow procedure 2 or 3 time.tell me more about your pbx to solve problem
johnsontiam
i haven't got the chance to use on real pbx, like common /crystal or appliance server,
so far i only tried to my OXE vmware,
i'll try to real pbx next time.
thank's friend.
cheers.
swinstation
it is necessary to mention when I connect to common hardware it connects at first time but for crystal you should follow procedure 2 or 3 time.i mean about follow procedure is: with out disconnecting pc installer you should type tell version or %62.0 on com port connection session and please check your services.msc after running pc installer.
cwsonline
Post by cwsonline »
I am also having this problem. I cannot seem to perform a new install using PC Installer 2.26 with Windows 7 x64. It seems that the CPU is never seen by the DHCP server in PC Installer. I have confirmed that:
1. Windows Firewall and the firewall installed as part of antivirus suite are disabled.
2. Computer Browser service is started.
3. wperl, dhcpd, ftpd, and tftp processes appear after I have started Linux and Call Handling.
I have reproduced this problem on another system with Windows 7.
I have also tried with and without static addresses on PC Installer system. Does anyone have any ideas? Thank you.
swinstation
I think it dose not work with X64 bit.
Reinoud
Post by Reinoud »
If you just want to load a patch, you can use filezilla. Create an anonymous account and point it to the right drive...
cwsonline
Post by cwsonline »
Loading a patch works fine with PC Installer with Windows 7 x64. It's a new install that does not work so far. I have only been able to get as far as having DHCP work when starting PC Installer in Windows XP compatibility mode.
Return to “Software Loading”
