Delay time on Analog trunk line.
nguyenhaitoan2008
Post by nguyenhaitoan2008 »
Hi everybody,
I have an new OXO release 7.1 with one APA8 card.When i call a number outside my network,it has a long delay time before the a called phone ring,about 30 second.What do i have config to fix it?
Thanks.
sera544
Post by sera544 »
Check out ur trunk MF is enabled, if ur using decadic delay happens..
cheers
nguyenhaitoan2008
Thanks for your reply.what does "MF" mean?where can i find it?
sera544
Post by sera544 »
Go to external lines > list of access> double clik port number > dialling should be DTMF,
hope this helps you
Return to “Configuration”
