Good Morning,
I use SoftPanel Server 5.0.1 for Standard Edition and want to configurate Pilot daily statistics to a widget.
When I choose "Real Time Data" and Statistics in the SoftPanel Manager I only see realtime data fields.
I want to see the values discribed at page 90 of the SoftPanel Manager Documentation, for example "Pilot_xxx_daily_served_calls".
I modified the RTI Connector data filters Filter values, but there is no affect at all.
afe.properties file is modified as described in the docomentation.
Any ideas??
Thank you very much
Rainer
SoftPanel Server. No Daily Statistics available in SoftPanel Manager
jlebleu
RainerO
Hello jlebleu,
I am in a test mode on VMWAre. I have to install the SoftPanel two weeks later. I use Enterprise Rel. 9.0, CCS 9.0.90.3 as requested
Yes, I restarted the soft panel manager. Here is the RTI Connector.ini
[main]
;File Updated on 09/10/07 by Frédéric Miras for RTIConnector
; --- Début paramétrage obligatoire ----------------------------------------------
; --- Début des filtres de broadcasting ------------------------------------------
; --- 30 filtres max. pour la première version à séparer par des virgules
; Attention + les filtres sont passants + le traffic UserEvent augmente
; --- Exemples pour la création d'un filtre :
; * = toutes les valeurs
; A* = toutes les valeurs qui commencent par A
; A?B = toutes les valeurs AxB, ...
; --- Nom du type d'objet à monitorer = FilterNameObjectType
; Consulter la documentation : DocFilters.txt
; FilterNameObjectType = Pilot, WaitingQueue, ProcessingGroupAgent, ProcessingGroupOther, Agent
;FilterNameObjectType = ProcessingGroupAgent
; --- Nom des objets CCD à monitorer = FilterRelatedObjectName
; FilterRelatedObjectName = *NomAGENT_SK2*, VAYSSAC*, LEBLEU*, TOTO*
; Par exemple pour monitorer les 2 GT : 2_GT2 et 2_GT1
; --- Nom des variables à monitorer = FilterKeyValue
; FilterKeyValue = !WithdrawalsTotalDuration
; FilterKeyValue = AssociatedSet*, Withdraw*, PhoneState*
; FilterKeyValue = PhoneState*
FilterKeyValue = *
; --- Fin des filtres de broadcasting ---------------------------------------------
; --- Cacher les objets et supprimer les traitements de trace, par défaut True
HideMode = False
# WBM configuration file
# Created while installing version 1.5.0.0
WBMHost=localhost
WBMPortNum=61668
And here the afe.properties
afe.sites= 191.254.1.2
afe.pilots=
Thanks a lot
Rainer
[main]
FilterKeyValue = *
HideMode = False
WBMHost=localhost
WBMPortNum=61668
afe.pilots=
Thanks a lot
Rainer
jlebleu
Definitly daily stats are configured using afe.properties, and retreived every 20 mn, to if your oxe ip address is 191.254.1.2, and you can ping it from the soft panel manager server it should work. Any exceptions in the soft panel manager log files ?
RTIconnector.ini is only for realtime statistics.
RainerO
Diane
Re: SoftPanel Server. No Daily Statistics available in SoftP
We are using SoftPanel 5.5 but not getting daily stats. Can someone please help with the error we see in the log file below? We can ping the server ok.
Thanks in advance
afe.properties
afe.sites= 172.16.4.28
afe.pilots=
afe.log file:
5.5.1.0 04-01 12:04:50 INFO [th:QuartzScheduler_Worker-3]afe.impl.PilotStatsCollectorImpl.getAllStats - Launch daily stat retrieval
5.5.1.0 04-01 12:04:50 INFO [th:QuartzScheduler_Worker-3]afe.impl.SiteHandlerManagerImpl.loadConfiguration - loadConfiguration : sites = 172.16.4.28 pilots =
5.5.1.0 04-01 12:04:50 INFO [th:QuartzScheduler_Worker-3]afe.impl.SiteHandlerManagerImpl.loadConfiguration - create 0 pilots
5.5.1.0 04-01 12:04:50 INFO [th:QuartzScheduler_Worker-3]afe.impl.SiteHandlerManagerImpl.loadConfiguration - create 1 sites
5.5.1.0 04-01 12:04:50 INFO [th:QuartzScheduler_Worker-3]afe.impl.SiteHandlerManagerImpl.getAllStatistics - try to get statistics for site : 1 - 172.16.4.28:2538
5.5.1.0 04-01 12:04:50 INFO [th:QuartzScheduler_Worker-3]afe.impl.SiteHandlerImpl.getAllStats - try to open connection
5.5.1.0 04-01 12:04:50 INFO [th:QuartzScheduler_Worker-3]link.impl.SiteLinkImpl.openConnection - creating socket
5.5.1.0 04-01 12:04:51 ERROR [th:QuartzScheduler_Worker-3]afe.impl.SiteHandlerImpl.getAllStats - java.lang.Exception: server connection error
5.5.1.0 04-01 12:04:51 ERROR [th:QuartzScheduler_Worker-3]afe.impl.PilotStatsCollectorImpl.onConnectionError - unable to close one site
Thanks in advance
afe.properties
afe.pilots=
afe.log file:
krzysioD
try to
telnet 172.16.4.28 2538
on your sps server machine, log says: can't open tcp socket.
any firewall between ? router with some ACL?
warrengauci
Re: SoftPanel Server. No Daily Statistics available in SoftPanel Manager
I have the same exact issue. Soft panel manager is running smooth, but I have a problem with the Daily statistics.
As seen from the .afe logs error caused is java.lang.Exception : server connection error.
Using <netstat -a> on soft panel server shows TCP port connection established.
Firewall is disabled and direct connection to OXE is currently being used.
Any ideas of what the issue might be? Is a particular java plugin needed for daily statistics to show?
