Hi guys,
I am unable to send or receive FAX via public sip trunk group,
Is there any setting for FAX through Public sip trunk group.
Trace file attached and my PABX release is 9.0
FAX from public sip trunk group.
It is possible if the public switch implements Fax over T.38
On the trace i can see that the call is well done, then the OXE make an re-invite in T.38 (this is the way oxe implements fax over ip) but the public switch releases the call.
Or the public switch does not implements t38 (that why i want to see the trace on the oposite direction) or there is something that he do not like (for instance the maxdatagram ?)
Sadim
Sadim
