Unified logon error
Coen
Unified logon error
Post by Coen »
When using one number services from the webinterface the user is asked to logon again. There is a windwos which prompts to enter the user name and password again.
I have ran the script to disable the SSL and changed the port of unified logon from 443 to 80.
Could you please think with me to solve this issue? I think maybe it has somethin to do with the webbrowser of the user because it is not always.
I have not figured out yet which causes the system to prompt again.
Coen
Is OTUC on your trusted sites? Have you modified the IE settings?
Coen
Post by Coen »
Thanks, problem seems to be solved!
banfield
Post by banfield »
Nice CAV
