Multi session-telnet emulator
swinstation
Post by swinstation »
Hi everybody
I am looking for a software like vt320 to telnet to alcatel that it shows multi telnet sessions in main page.
Imagine you have 14 site and you need monitor them"no omni4760" now you need a multi telnet emulator that it shows 14 site monitoring in main page and you can choose or re-size the opened pages.
I try token2shell it was very very good but the arrow keys were disable because it works with vt100.
now what is your advice?
tincho.rn
Post by tincho.rn »
Hi. If you need to monitor, perhaps you have to think about a SNMP trap receiver. Just an idea. Regards.
swinstation
hi thanks for your reply now where I can download it?
or putty ?
Mr T
Post by Mr T »
Putty may be illegal depending on where he's from...but putty is where it's at.
What exactly are you trying to monitor napo?
swinstation
I have 16 pabx in one of my sites THEY ARE CONNECTED through ABCF so I want to monitor all of them in one emulator like "CASCADE WINDOWS".anyway please don't bothering yourself I solve it with using vt320 but it monitors single site "it forced"
Putty ? Illegal ? Where did you see that ? It's a freeware !
Mr T
Post by Mr T »
Putty is illegal in countries where encryption is outlawed.
If you use putty for telnet, there is no encryption..
You can only encrypt what the server allows you to encrypt..
Mr T
Post by Mr T »
Yes, I understand, but putty has the capability of ssh too. So in a country where in encryption is outlawed, putty is outlawed. All websites that allow the download clearly state this, at least the ones I have been to.
Return to “Other Alcatel-Lucent tools”
