Pinouts for a sierals cable to a 4400
KillianK
Post by KillianK »
Hi All,
Do you know the pin outs for DB25 to DB9. I need to set one up for my laptop? Thanks a million,
Killian
google is your friend man....
http://www.zytrax.com/tech/layer_1/cabl ... m#db9_db25
use the the internet a little bit
KillianK
Post by KillianK »
Cheers Frank a good site, i thought there was a specific cable...
Killian
you will need a null modem cable if you are trying to connect to the RMA box...
KillianK
Post by KillianK »
Thanks a million,
Killian
Return to “GENERAL”
