IP ports used by OTUC
mouldy
Post by mouldy »
I have a customers who has OTUC users on the far side of a firewall form the server. When the firewall is bypassed it all works but when in place users cannot open the OTUC toolbar.
Does anyone have or can anyone point me to a document that has a list of all the port numbers used in OTUC communications?
Paul
tincho.rn
Post by tincho.rn »
Check this. Regards
0xbadf00d
Post by 0xbadf00d »
Thanks very much for this - very helpful information!
ubhatnagar
Re: IP ports used by OTUC
Post by ubhatnagar »
Can you please upload the same document again....it's not downloadable now...
The PDF is under the BPWS or into the installation DVD docs
Return to “OTUC”
