Hi all,
i have a OTUC configured as Voice Mail system and automated attendant. when i dial the voice mail and chose a user to transfer to the call is not tranfered.
With AA when i configure de tree to transfer to operator nothing the transfer ins not made.
Any idea,
cannot transfer calls from OTUC to OXE
Hi, but how do i change thec coedec without afecting external connections. I have a public sip truk to operator and i want to use G729 because compression.
My trunk group to otuc is configured with g711. look the trunk group configuration:
┌─Review/Modify: Trunk Group──────────────────────────────────────────────┐
│ Trunk Group ID : 0 │
│ Instance (reserved) : 1 │
│ Trunk Group Type + T2 │
│ T2 Specification + SIP │
│ Public Network Ref. : ------ │
│ VG for non-existent No. + YES │
│ Entity Number : 0 │
│ Supervised by Routing + NO │
│ VPN Cost Limit for Incom.Calls : 0 │
│ Immediate Trk Listening if VPNCall + YES │
│ VPN TS % : 50 │
│ CSTA-Monitored + NO │
│ Max.% of trunks out CCD : 0 │
│ Ratio analog.to ISDN cost : ------ │
│ TS Distribution on Accesses + YES │
│ Quality profile for voice over IP + Profile #1 │
│ IP Compression Type + G 711 │
│ Use of volume in system + YES │
│ VPN TS % : 50 │
