This is the 3rd site I go to in 3 months and have the same trouble:
The music on hold on the CPU6 can be hear for 1 second, then it says "You are in email processing, you might hang up"... I found a trick once, I found a trick twice, but on the 3rd one my tricks does not work anymore... When I'll find a solution, I will let you know..
Frank.
Music On Hold says "You are in email processing"
- frank
simon_DUP
