Mao database rebuild
Aquarius!
Post by Aquarius! »
Does anybody know what is the difference between "mao data" and "mao data for rebuild" terminology under swinst?
Eliott
Post by Eliott »
MAO Data for rebuild contains just the data files.
The index files will be created during the restore procedure. (using fichges)
It's also smaller and has not accounting data included.
You can check the content of the .blf files to know the files to be saved.
letacla
Post by letacla »
I need to know how can i extract from mao-acc or mao-dat voiceguide files
thx,
alex
Post by alex »
letacla wrote:Hi,
thx,
Check this one http://www.7zip.org. Very nice tool for extracting!
Eliott
Post by Eliott »
But mao-dat has no VG's included.
letacla
Post by letacla »
thanks, its working
Return to “Software Loading”
