Root guard functionality
arojas2010
Post by arojas2010 »
Hi guys,
I need to activate the root guard functionality.
In fixed ports it works in correct way, but I have only mobile ports and root guard doesn´t work. Is here any restriction for mobile ports? or anyother precedure for configuring it in mobile ports?
Thanks for your help!
cedric1
Post by cedric1 »
what did you configure for root guard
please post you config
i assume you use restricted-role? I don't know any restriction.... do you get an error message during config?
Have you flat or 1x1-mode? If 1x1 please try it with flat mode.
An other way is bpdu filter for user-ports.
cedric1
Post by cedric1 »
without a config output yu will not get more help
benny
Post by benny »
Please note that per-default the "mobile ports" will revert back to a "fixed port" if they receive a BPDU.
-benny
