A few specific questions:
- Based on what I've found so far, the device uses CSTA phase 1. Is that correct?
- Is there a specific port or range of ports that should be used for this type of communication? I've been using port 32000, but that seems to be for something different.
- At least one other Alcatel device (the 4400 series) requires a one-byte exchange (one byte sent followed by one byte received) before any ACSE messages can be sent. Is it the same with the OmniPCX Office?
- Does the device use standard BER, or does it use the two-byte IETF prefix also?
