Problem with upgrade from R7.1 to R9.1
BlackLightz
Post by BlackLightz »
Hi all,
I just did and upgrade fromR7.1 to R9.1. on ACT hardware.
All went fine untill I started to load the new OPS files as the last thing.
I got this:
Do you agree the new software keys (y/n): y
ooo Reading string-file /DHS3bin/oneshot/mtcl/objects.US0 ...
ooo Reading string-file /DHS3bin/oneshot/mtcl/spadmin.dct ...
ooo Reading string-file /DHS3bin/oneshot/mtcl/err2lov.dct ...
Version 8 -> Version 9
Error : Bad value for package OmniPCX Enterprise 4400 release number 1
*** INVALID NEW FILE software.mao : copy not done ***
ERROR: OPS files not copied.
Press return
I have been looking for "OmniPCX Enterprise 4400 release number " in the OPS list and it is under OPS Nr. 165:
165 OmniPCX Enterprise release = 36 -> 38
So, have anyone seen this error before or might point me in the right direction?
Best Regards
BL
Eliott
Post by Eliott »
0 means R1.3
1 means R1.4
2 means R1.5.2
3 means R1.5.3
4 means R2
5 means R2.SN
6 means R2.1
7 means R2.1 Multi Compagny
8 means R2.1 Page
9 means R3
10 means R3.1
11 means R3C1
12 means R3.xC2
13 means R3.2
14 means R4.1
15 means R4.1.1
16 means R4.2
17 means R5.0
30 means R5.0 OXE
31 means R5.1 OXE
32 means R6.0.x OXE
33 means R6.1.x OXE
34 means R6.2 OXE
35 means R7.0 OXE
36 means R7.1 OXE
37 means R8.0 OXE
38 means R9.0 OXE
39 means R9.1 OXE
Your OPS is for R9.0 only.
JoelO
Post by JoelO »
9.1 requires a separate license from 9.0. If 9.0 was purchased you have to stick with 9.0. It's not like 8.0 and 8.0.1.
BlackLightz
After some ping pong with Alcatel we found out the same. R9.1 was ordered in the first place with ACTIS. But Alcatel did some kind of mistake with it. Here is the text from the OPS files:
PRODUCT OXE
OPS E1210 dnaaSU0450DC
OPS_MAO 14.1.1 OPS_OXE_Release 9.1
MAO_OPS 000 MAO_OXE_Release 9.1
THX for pointing the the right way!!
Best Regards
Return to “Software Loading”
