Load Balancing across links in a linkaggregation
helmers
Post by helmers »
in need to know how the traffic is load balanced across the links in a linkaggregation. Is the distribution based on MAC-addresses or IP-addresses or is it a complete other algorithm?
Is it possible to change the load balancing method?
Best Regards
Helmut
benny
Post by benny »
Hi Helmut,
Welcome to the board!
Yes, since AOS 6.4.2.R01 you can modify the way the traffic is load-balanced over a link-aggregation.
OS6855-LAB-> show hash-control
Hash Mode    = brief,
Udp-Tcp-Port = disabled
The mode you are looking for is "extended". You'll find everything you need in the documentation available through the link in my signature.
cedric1
Post by cedric1 »
and in complement hashing is dependent on RFC 2292.
same hashing is used for SLB, Linkagg and ECMP.
Cedric
agungaryo
Post by agungaryo »
I'm using AOS 6.3.4.399.R01 ,could I use "load-balancing" over linkagg ?
benny
Post by benny »
The traffic is already load-balanced over the link aggregation. AOS 6.4.2.R01 just adds additional ways to look at the flows.
-benny
agungaryo
Post by agungaryo »
hi benny,
I'm sorry for asking again,cause I'm still new.
I try in my switch :
Switch1# show linkagg port
Slot/Port Aggregate SNMP Id Status Agg Oper Link Prim
1/1 Dynamic 1001 ATTACHED 1 UP UP YES
1/2 Dynamic 1002 CONFIGURED NONE DOWN DOWN UNK
1/5 Dynamic 1005 ATTACHED 2 UP UP YES
1/6 Dynamic 1006 ATTACHED 2 UP UP NO
switch1# show linkagg 2
Dynamic Aggregate
SNMP Id : 40000002,
Aggregate Number : 2,
SNMP Descriptor : Dynamic Aggregate Number 2 ref 40000002 size 4,
Admin State : ENABLED,
Operational State : UP,
Aggregate Size : 4,
Number of Selected Ports : 2,
Number of Reserved Ports : 2,
Number of Attached Ports : 2,
Primary Port : 1/5
LACP
MACAddress : [*******],
Actor System Id : [00:00:00:00:00:00],
Actor System Priority : 0,
Actor Admin Key : 20,
Actor Oper Key : 20,
Partner System Id : [00:00:00:00:00:00],
Partner System Priority : 0,
Partner Admin Key : 0,
Partner Oper Key : 20
Switch1#
link-agg 2 use port 1/5 ,1/6 . I presumed, data is only go through port 1/5 (which is primary ).
is there any additional command to make link-agg as load balancer ?
I'm just using :
-> lacp linkagg 2 size 4 admin state enable
-> lacp linkagg 2 actor admin key 20
-> lacp agg 1/5 actor admin key 20
-> lacp agg 1/6 actor admin key 20
thank you,
agung aryo
agungaryo
Post by agungaryo »
I've read documentation like this :
"Link aggregation groups are identified by unique MAC addresses, which are created by the switch but can
be modified by the user at any time. Load balancing for Layer 2 non-IP packets is on a MAC address basis
and for IP packets the balancing algorithm uses the IP address as well. Ports must be of the same speed
within the same aggregate group."
but I don't know technically.
thank you
agung aryo
cedric1
Post by cedric1 »
what don't you know ?
agungaryo
Post by agungaryo »
cedric1 wrote:what don't you know ?
Link-agg that's used as load balancer ,. . .
agungaryo wrote:hi benny,
Dynamic Aggregate
SNMP Id : 40000002,
Aggregate Size : 4,
Primary Port : 1/5
LACP
Switch1#
I'm just using :
thank you,
agung aryo
benny
Post by benny »
It will use both ports 1/5 and 1/6. The primary port just indicates on which link the Multicast packets, ARP etc are handled.
You don't have to do anything else.
-benny
