Hi everyone.
I was installing a new 8400 to integrate with my oxe call server. i am having problems to conect the media server to oxe. can anyone please send me screenshots of oxe configuration and media server configuration.
I have a log in 8400:
Identifier
21309
Severity
MINOR
Type
Alarm
Date
Fri Feb 12 17:51:46 GMT 2010
Origin host
srvlracom07.mycompany.local
Origin component
MS
Originator instance
RMS
Summary
SIP service registration problem : Service 2292 is not registered (reason -1)
State
On
Description
SIP service registration error status.
Action
error -1 : OXE problem (not running, not well configurated in UC, SIP gateway not managed, UC not in SIP trusted list)
error 423: registration duration too brief (control UC management vs OXE SIP Proxy management)
error 401: authentication problem (control UC SIP authentication management vs OXE SIP Proxy authentication management)
others: control OXE status
When i do a traced in oxe i dont have any log from otuc
Best regards
SIP from 8400 to OXE
Hi here are my SIP configuration in OXE:a4400 wrote:Looking at your error log I would suggest your problems are with your SIP management on the OXE.
Try managing it without authentication to begin with.
┌─Review/Modify: Trunk Groups───────────────────────────────────────────────────────┐
│ Trunk Group ID : 0 │
│ Trunk Group Type + T2 │
│ Trunk Group Name : OTUC │
│ UTF-8 Trunk Group Name : ------------------------------------------- │
│ Number Compatible With : -1 │
│ Remote Network : 7 │
│ Shared Trunk Group + False │
│ Special Services + Nothing │
│ Node number : 1 │
│ Transcom Trunk Group + False │
│ Auto.reserv.by Attendant + False │
│ Overflow trunk group No. : -1 │
│ Tone on seizure + False │
│ Private Trunk Group + False │
│ Q931 Signal variant + ABC-F │
│ SS7 Signal variant + No variant │
│ Number Of Digits To Send : 0 │
│ Channel selection type + Quantified │
│ Auto.DTMF dialing on outgoing call + NO │
│ T2 Specification + SIP │
│ Homogenous network for direct RTP + NO │
│ Public Network COS : 31 │
│ DID transcoding + False │
│ Can support UUS in SETUP + True │
│ Implicit Priority │
│ Activation mode : 0 │
│ Priority Level : 0 │
│ Preempter + NO │
│ Incoming calls Restriction COS : 10 │
│ Outgoing calls Restriction COS : 10 │
│ Callee number mpt1343 + NO │
│ Overlap dialing + YES │
│ Call diversion in ISDN + NO │
┌─Review/Modify: Trunk Group──────────────────────────────────────────────┐
│ Instance (reserved) : 1 │
│ Public Network Ref. : ------ │
│ VG for non-existent No. + YES │
│ Entity Number : 0 │
│ Supervised by Routing + NO │
│ VPN Cost Limit for Incom.Calls : 0 │
│ Immediate Trk Listening if VPNCall + YES │
│ VPN TS % : 50 │
│ CSTA-Monitored + NO │
│ Max.% of trunks out CCD : 0 │
│ Ratio analog.to ISDN cost : ------ │
│ TS Distribution on Accesses + YES │
│ Quality profile for voice over IP + Profile #1 │
│ IP Compression Type + Default │
│ Use of volume in system + YES │
│ Announcement for dial tone + NO │
│ Announcement for Ring tone + NO │
│ Private to Public Overflow + YES │
│ End-to-end dialing + NO │
│ DTMF end-to-end signal. + NO │
│ Trunk group used in DISA + NO │
│ DISA Secret Code : ---- │
│ Routing To Manager + NO │
│ Trunk COS : 31 │
│ Sending of Progress message + YES │
│ No. of digits unused (ISDN) : 0 │
│ B Channel Choice + YES │
│ Channels: Attendant Control (Rsvd) : 0 │
│ Redirection For ACD (Dissuasion) + NO │
│ DTO joining + NO │
│ Consultation Call On B Channel + NO │
│ Automated Attendant + NO │
│ Calling party Rights COS : 0 │
│ TS Overflow + YES │
│ Number To Be Added : -------- │
└─────────────────────────────────────────────────────────────────────────┘ ┌─Review/Modify: SIP Gateway───────────────────────────────────────────────────────────────┐
│ SIP Subnetwork : 2 │
│ SIP Trunk Group : 0 │
│ IP Address : 10.0.7.10 │
│ Machine name - Host : srvlrapbxm │
│ SIP Proxy Port Number : 5060 │
│ SIP Subscribe Min Duration : 1800 │
│ SIP Subscribe Max Duration : 86400 │
│ Session Timer : 86400 │
│ Min Session Timer : 900 │
│ Session Timer Method + UPDATE │
│ DNS local domain name : incentea.local │
│ DNS type + DNS A │
│ SIP DNS1 IP Address : 10.0.0.5 │
│ SIP DNS2 IP Address : ----------------------------------------------- │
│ SDP in 18x + True │
│ Cac SIP-SIP + False │
│ INFO method for remote extension + False │
│ Dynamic Payload type for DTMF : 97 │
┌─Review/Modify: SIP Proxy─────────────────────────────────────────────────────────────────┐
│ SIP initial time-out : 500 │
│ SIP timer T2 : 4000 │
│ Dns Timer overflow : 5000 │
│ Recursive search + False │
│ Minimal authentication method + SIP None │
│ Authentication realm : 10.0.0.25 │
│ Only authenticated incoming calls + False │
│ Framework Period : 3 │
│ Framework Nb Message By Period : 25 │
│ Framework Quarantine Period : 1800 │
