netadmin issue
Konstantinos.E
netadmin issue
Post by Konstantinos.E »
Hello to everybody!
Seems that Netadmin does not respond to certain ips.Does the pbx keep a range of ips for it self?
For example i put 10.3.1.100 for the local and 111 for the main and i cannot ping it both.Also i log on as root and the ifconfig doesnt show me the ip addresses that i put in netadmin.
I put the ip manual from the root i ping it normally then is put them also in netadmin but it doesnt let me log in thgrouh telnet or even through 4760i
wired?
I tryed default configuration with netadmin -n 3 1 works perfect but when i change it in 100 or something else it stucks.
In the beggining i thought that it was from the INT-IP cartds or from the x25 for this reason i created an empty data base and still make the same.
The crystal is cpu5 and 5.1 release.
Any idea why this happeninig?
What about netmask? Used like 255.255.255.0 or like default 255.255.255.192? If last one - IP address for 4760i PC in the same subnet?
Security used or no?
Konstantinos.E
netmask is 255.255.255.0.
No security and the pc is in same subnet.
Stupid question but - when you change IP address (menu 3) - after this what about menu 18 (apply modification)?
Konstantinos.E
Yes ofcourse i done that.
JoelO
Post by JoelO »
If you have on CPU no need to setup a main, but anyway no the PBX does not keep a range of IPs for itself.
Dieter
Post by Dieter »
change the local and main address to something else in the same subnet, save netadmin and reboot cpu5...if that does not work load your latest patch or reload binaries. something is very wrong...all the best:)
johank
Post by johank »
1) Make sure that there is noting else on the network using 100 or 111. (I have accidentally made my laptop the same as Cpu IP a few times)
2) Make sure there is no firewall blocking you, including widows firewall.
3) I have found it is always better to run netadmin when logged in as administrator ( su ) especially on older versions.
4) You must reboot after redoing the netadmin
Hope this helps
Reboot after netadmin needed if changed node/network number (after the same changing in System), or if CPU works as TFTP server (for IP set f.e.).
Konstantinos.E
Thank you all for your replies !!!
I tried everything you said and i am sure that i am changing ips the right way.I think there is something wrong with the database or system version.If someone knows how do go deeper to system to check some possibilities i am all ears(and eyes):P if not i will upgrate the system in next sunday: :eek:
Return to “IP”
