Changing the auto attendant off hook delay causes the auto attendant to answer in 2-3 US rings. Is there a way for it to answer sooner (prefer immediately)?
Also, when transfering to a extension, is there a way to have music instead of ringing?
Thanks!
Auto Attendant answer time and music on hold
Hi siptech
For your first question, the timer to answer a call thrugh AA is this. You don't have another timer for it.
For your second question, try this: at system miscellaneous --> feature design --> part 3 --> hold tone for external calls --> check if it is as MUSIC.
Best regards
Best regards
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
ACFE OXE R12
ACFE OXO C R3
JoelO
shirantha
fapy_294
elkiwi
Besugo
Re: Auto Attendant answer time and music on hold
Hi.
i know it's a old thread, but for future reference, helping out anyone who comes across this problem:
system miscellaneous --> feature design --> part 2 --> Ringing Tone for External Calls --> unchecked
Worked for me.
Thanks.
Worked for me.
Thanks.
