we have enabled SNMP internally, but the port (161) seems closed (with nmap)
How to open this port?
Are there any other MIBS than A4400-RTM-MIB.txt MIB? in case, where?
sjur
SNMP configuration and MIB files
mboehringer
sjur
This is the only MIB I have.. But not that useful for my purpose...
Could attach file, so quoted it under.
-- Alcatel-Lucent OXE Real-Time Monitoring MIB
-- Revision: 1.2
-- Date: 2008/09/11
-- Feature Internal Reference - 3EU_29000_0125_DTZZA (External Specification)
A4400-RTM-MIB DEFINITIONS ::= BEGIN
IMPORTS
enterprises FROM RFC1155-SMI
OBJECT-TYPE FROM RFC-1212
a4400CPU FROM A4400-CPU-MIB
ipDomainTable OBJECT-TYPE
SYNTAX SEQUENCE OF IpDomainEntry
ACCESS read-only
STATUS current
DESCRIPTION
"Table for IP Domains."
::= { a4400CPU 3 }
ipDomainEntry OBJECT-TYPE
SYNTAX IpDomainEntry
ACCESS read-only
STATUS current
INDEX { ipDomain }
::= { ipDomainTable 1 }
IpDomainEntry ::= SEQUENCE {
ipDomain INTEGER,
confAvailable INTEGER,
confBusy INTEGER,
confOutOfOrder INTEGER,
dspRessAvailable INTEGER,
dspRessBusy INTEGER,
dspRessOutOfService INTEGER,
dspRessOverrun INTEGER,
cacAllowed INTEGER,
cacUsed INTEGER,
cacOverrun INTEGER,
ipDomain OBJECT-TYPE
SYNTAX INTEGER
ACCESS read-only
STATUS current
DESCRIPTION
"IP Domain number as found in MAO."
::= { ipDomainEntry 1 }
confAvailable OBJECT-TYPE
SYNTAX INTEGER
ACCESS read-only
STATUS current
DESCRIPTION
"Conference circuits available for given IP Domain"
::= { ipDomainEntry 2 }
confBusy OBJECT-TYPE
SYNTAX INTEGER
ACCESS read-only
STATUS current
DESCRIPTION
"Conference circuits busy for given IP Domain"
::= { ipDomainEntry 3 }
confOutOfOrder OBJECT-TYPE
SYNTAX INTEGER
ACCESS read-only
STATUS current
DESCRIPTION
"Conference circuits out of order for given IP Domain"
::= { ipDomainEntry 4 }
dspRessAvailable OBJECT-TYPE
SYNTAX INTEGER
ACCESS read-only
STATUS current
DESCRIPTION
"Compressors available for given IP Domain"
::= { ipDomainEntry 5 }
dspRessBusy OBJECT-TYPE
SYNTAX INTEGER
ACCESS read-only
STATUS current
DESCRIPTION
"Compressors busy for given IP Domain"
::= { ipDomainEntry 6 }
dspRessOutOfService OBJECT-TYPE
SYNTAX INTEGER
ACCESS read-only
STATUS current
DESCRIPTION
"Compressors out of order for given IP Domain"
::= { ipDomainEntry 7 }
dspRessOverrun OBJECT-TYPE
SYNTAX INTEGER
ACCESS read-only
STATUS current
DESCRIPTION
"Cumulated compressors overrun for given IP Domain"
::= { ipDomainEntry 8 }
cacAllowed OBJECT-TYPE
SYNTAX INTEGER
ACCESS read-only
STATUS current
DESCRIPTION
"Number of allowed external communications for given IP Domain"
::= { ipDomainEntry 9 }
cacUsed OBJECT-TYPE
SYNTAX INTEGER
ACCESS read-only
STATUS current
DESCRIPTION
"Current number of external communications for given IP Domain"
::= { ipDomainEntry 10 }
cacOverrun OBJECT-TYPE
SYNTAX INTEGER
ACCESS read-only
STATUS current
DESCRIPTION
"Cumulated CAC overrun since system startup for given IP Domain"
::= { ipDomainEntry 11 }
pbxRole OBJECT-TYPE
SYNTAX INTEGER {
INDETERMINATE(0),
MAIN(1),
STAND-BY(2),
ACTIVE-PCS(3),
INACTIVE-PCS(4),
ACCESS read-only
STATUS current
DESCRIPTION
"The PBX role."
::= { a4400CPU 4 }
sipRegSets OBJECT-TYPE
SYNTAX INTEGER
ACCESS read-only
STATUS current
DESCRIPTION
"Registered SIP sets."
::= { a4400CPU 5 }
sipUnregSets OBJECT-TYPE
SYNTAX INTEGER
ACCESS read-only
STATUS current
DESCRIPTION
"Unregistered SIP sets."
::= { a4400CPU 6 }
setsInService OBJECT-TYPE
SYNTAX INTEGER
ACCESS read-only
STATUS current
DESCRIPTION
"Number of sets in service."
::= { a4400CPU 7 }
setsOutOfService OBJECT-TYPE
SYNTAX INTEGER
ACCESS read-only
STATUS current
DESCRIPTION
"Number of sets out of service."
::= { a4400CPU 8 }
END
mboehringer
Reley
trjm
