External battries recomended for OXO pabx system
shirantha
Post by shirantha »
Please explain me following questions?
· Oxo babx system recommended to external battries·
How to install external batteries ( 100/50/25VPV’s)
· External Battery charging voltages
· External Battery connecting procedures
· Removing internal batteries ( How is the shutdown process)
Please explain me
Thanks,
Shirantha
shirantha
Post by shirantha »
The internal battries use for oxo shutdown prosses,,
we have to remove internal battries & stapper to select external battries so
oxo pabs suddanly off the power failer & external battries week
Is it crrect or not ?
Shirantha
Krusty65
Post by Krusty65 »
Moved the thread into an appropriate location
shirantha wrote:Hi
Shirantha
You are correct the internal batteries are only there to allow the OxO to shutdown properly if the power is lost.
You will have to order the external battery kit which comes with the necessary cables and instructions for removing the internal batteries and installing the cables to allow connection to the new external battery box.
K.
For system shutdown - press power button on CPU board, wait when power LED will be red. After you can dissconect power cord.
MTConsulting
Post by MTConsulting »
Save your money and buy a proper small UPS, it will also give surge protection and brown out protection.
johar.mohammed
Post by johar.mohammed »
OXO system recommended to external battries as shown below
1.Compact OXO system ---No External batteries Purely will run through UPS
2. S cabinet--12 Volt 7Ah 2-Batteries (two parallel batteries connections)
3. M cabinet-12 Volt 7 Ah-4-Batteries ( Four parallel batteries connections)
4. L cabinet--36 Volt 7 Ah-6 Batteries ( Three batteries in serial two set and then parellel)
shutdown is simple by off the switch of CPU.
johar
Return to “Hardware”
