UK TO US CONNECTION PROBLEMS
Moses
Post by Moses »
We are currently using twi different server version one based in the UK and the other based in the UK , we dial out to US after 8pm , However this works fine until 5am then calls keep getting dropped, we have checked to see if the calls are being handled at our UK end and the go through teh PBX and dials out but withing 2secs it ends the call. Does anyone have any experience in problems related to this or international calls. Any help will be appreciated. :)
Hi Moses,
Did you do a lookars i to check what route your international calls are taking depending on the hour ? This should give you some information on where to look then...
Return to “GENERAL”
