Alarm 1307,MCDU in distri tab entity 1, col Day , line 4 incorrect or missing
belkhiati
Post by belkhiati »
can any one help me to resolve this problem of alarm , it does take in PRI card with minor gravity
thanks and best regards.
please Frank Urgent
In public network COS allowed overflow (total busy, free set, waiting) - but nothing managed in Entity CDT.
or forbid overflow, or declare overflow address - user/ dynamic user - associated set, or phone feature cos - default overflow type and address, or Entity CDT.
belkhiati
Post by belkhiati »
Thanks Vad
But where can I change or modefi this paramaters , do you have some docomutation about this
belkhiati
Post by belkhiati »
Vad
I need More Clarification please
In public network COS of users - allowed or not overflow (overflow on free set, overflow on waiting, overflow on total busy)?
If overflow allowed - you have two possibility:
1 - forbide overflow.
2 - manage overflow address - f.e. user/ dynamic state user - declare assocciated set, or in entity declare in call distribution attendant or secretary number.
Your incident say - in your system allowed oveflow but nothing managed in call distribution in entity. PBX not know destination for calls overflow.
belkhiati
Post by belkhiati »
Vad
do you have a tecniqual communication about this Alarm 1307
Thanks and best regards
smileyman
Post by smileyman »
Technical Communicatino fpr 1307? - Sorry, i don't know.
But where is the problem with vads description?
Do you mean 'incinfo'?
smileyman
belkhiati
Post by belkhiati »
thank you for your advice
the problem with Vads description , where do I find all those parameters in Omnivista or Mgr to Change it
and what does mean aboutIn public network COS of users
best regards
smileyman
Post by smileyman »
Hi belkhiati,
the simple way is to define a overflow destination in entity. You can find this parameter in OmniVista in the section entity (Routing overflow number)
The second way is to disalow the overlow in COS (Category of Service).
Every User have a COS-Parameter. This Parameter links to the COS-Table. You can find it in OmniVista / mgr below Category of Service. There you can disable the overflow for the user.
If this dosn't help, I will send you a screenshot.
smileyman
belkhiati
Post by belkhiati »
thank you very much
yes , send me a sceenshot
Return to “OmniVista 4760”
