how to use "usb flaskdisk" in os6400?
nguyenhaitoan2008
Post by nguyenhaitoan2008 »
OmniSwitch 6400 has a usb port.but i don't know how to use it.anybody help me?
benny
Post by benny »
The USB port is meant for future use. It will be possible to use it for disaster recovery in case e.g. you delete all image files.
Right now the USB port doesn't do anything.
-benny
dangkita
Post by dangkita »
Now we can use this port for upgrade and backup,rite?
nguyenhaitoan2008
yes,we can but you have to upgrade software and boot image to version 6.4.3.
dangkita
Post by dangkita »
Have u tried it?
nguyenhaitoan2008
yes,i have.it worked perfectly!
cedric1
Post by cedric1 »
perhaps some output command of make it working
nguyenhaitoan2008
this is command i used:
-> usb enable
-> mount /uflash
-> cp /flash/working/boot.cfg /uflash/boog.cfg
-> umount /uflash
Once the USB flash drive is mounted most common file and directory commands can be performed on the
/uflash directory.
benny
Post by benny »
Ensure that the USB Stick has a FAT file system.
OmniSwitch
Re: how to use "usb flaskdisk" in os6400?
Post by OmniSwitch »
I'd like to know what make and model USB stick works with the switch.
I have tried numerous different makes and models all with different formatting (fat16/fat32, and different sizes)
The switch is updated to AOS kernel version: 6.4.4.410.R01 and UBOOT Version : 6.4.3.565.R01,
-> usb enable -- then I stick the memory to the usb-port:
+++ Bulk Device Not Supported!
-> mount /uflash
WED AUG 22 12:17:07 : SYSTEM (75) info message:
USB /uflash: error during mount, /uflash is unmounted.
ERROR: Call to mount failed.
Only one flash memory (Kingston 100 G2 8GB) has given a sign of hope:
it says the same bulk not supported and even mounts the uflash but doesn't work as it says there is no capacity.
The switch tells some details of the flash memory something like this:
vendor:
: 0 blocks
capacity: 2 Bytes or someting
: 0
Return to “OmniSwitch 6400”
