Factory Reset 6400
avrilspirit
Factory Reset 6400
Post by avrilspirit »
I would like to know if it's possible to make a factory reset for the 6400 and 6850 switch.
benny
Post by benny »
Yes, it is possible.
Switch-> cd working
Switch-> rm boot.cfg
Switch-> cd ..
Switch-> cd network
Switch-> rm userTable*
Switch-> reload working no rollback-timeout
*Wait for the OmniSwitch to reboot*
*Login with admin/switch*
Switch-> copy working certified
Your switch is now back to factory defaults (configuration & users).
-benny
dangkita
Post by dangkita »
Hi benny,
Is there any way to erase running configuration that dont need to delete boot.cfg and restart switch?
Thanks!
if you like to go to factory default, than you have to delete boot.cfg + restart like Benny descripted.
Otherwise it's possible to undo/disable all configs step by step.
-> write terminal
to show all the config. Depending of the config you can with no-commands delete the config (every vlan, every ip interface ..... line by line).
That's the onlies way to edit the running config in my knowledge.
dangkita
Post by dangkita »
That way will be a hard work :))
Thanks Silvio!
maria.para
Re: Factory Reset 6400
Post by maria.para »
Hello ,
I just performed a reset to factory of an OS6400 with the following commands:
Switch-> cd working
Switch-> cd ..
Switch-> cd network
After that I connect to the switch through the console port and I create a new ip interface but I can not activate it.
I also noticed that when I connect my laptop to one of the ports of the switch there is not any led flashing. Can you please tell me step by step what I have to do to activate vlan1 and the ip interface that I created ?
This is my first configuration of an 6400 and I have many queries and difficulties!!!!
Thank you very much !!!!
devnull
Post by devnull »
vlan 1 is default., so all your ports are in vlan 1.
to be sure:
show vlan 1 ports
create an IP interface:
ip interface "vlan1" address 10.10.10.1/24 vlan 1
to be able to login via ssh/telnet you need to set authentication:
aaa authentication default local
(or aaa authentication ssh local for only ssh)
But if no led is flashing there is a problem.. check your cables do a show interfaces 1/1 (or whatever port you used)
Hint: read the getting started guide!
maria.para
Thank you very much for your reply,
I had problem with the cables. Everything works fine now !!!!!!
Return to “OmniSwitch 6400”
