Please show me how to do that!
many thanks
Thanh Nguyen
How to close ftp transaction on OmniPCX without restart?
Avi1
Hey.
There is an entry in "System miscellaneous - Memory read/write - Timer labels" called PM5ftpidle and PM5ppIdle.
I think the first is for ftp connections and the second for connections with modem etc.
The normal timer is 30min and can be changed in "dez." mode.
I haven't tried this yet but i think this is the entry you are looking for.
Please write back if you tried it.
mfg
Avi
mfg
Avi
thanhnguyen
Re:
Hello All,
thanks for your information, When I used PM5 software to manage my switchboard, an error occur, I try to log on again i received an error with message " HPTPS error, ........refuse to use.....is active" (can not remember exactly). When I restart my PABX it's ok.
Now I have an another problem with programming key for 4019 phone set. My PABX dont allow me do this.
Merci so much!
Thanh Nguyen
Merci so much!
Thanh Nguyen
- tot3nkopf
This is a well known OXO bug. When for some reason the connetion between PM5 and swich is cut, you cannot log back fo 30min to 1h. I think that this incident triggers a timer which has a value between 30 min and 1h (I don't know exactly - but after an hour you can log back in without restart) and when this timer elapses you can log back in.
I think this was orrected in OMC (from Rel 5.0 on). I've been unexpectedly been disconected with OMC, but I was able to logg back in without problems.
Unfortunateley there isn't any solution for PM5. You can either wait an hour or restart the PCX.
Hope that helps.
Hope that helps.
henk1964
In the realy old versions of the OXO the timer was set to 5 minutes. Problem was that, if you use the WBM it timed out because there was no activity at the PM5 for all the time you where working in the WBM.
So Alcatel increased the timer to 30 minutes and now we are f*cked if we have an unexpected error and loose the connection ;-)
et
henk1964
