Hi guys,
has anyone experience with setup SBC ? I configured from documentation, but isn't working.
My scheme as follows - LAN - there is OXE and eth1 from SBC, DMZ - there is eth0 from sbc. In DMZ is CISCO ASA. I can ping from eth1 to outside (e.g. google, yahoo etc). When i started X-Lite, so I can not registration to OXE from outside.
Can you help me ?
thanks
SBC (session border controller)
I don't know which log. Here is logs from ALGSip and ALGNoe
Open file: 20091216-163810_ALGSIP_TRACE-start.log
Use Ctrl+C to exit
[MP0] 127.0.0.1:22500
**** Media Proxies Sorted Association ****
reloadConfigurationCommandRequestPDU_chosen
DEBUG. ProxyConfiguration::loadInitFile: reading /etc/neotip/NeoALGSIP.ini
**** Interfaces ****
Interface: Intranet(Address) Attached address: 172.30.1.252 . VoIP address: 172.30.1.252
Device Name: eth0:0
Interface: Extranet(Address) Attached address: 10.70.147.22 . VoIP address: 10.70.147.22
Device Name: eth1:0
**** Media Proxies List ****
Device Name: eth0:0
Device Name: eth1:0
Device Name: eth0:0
Device Name: eth1:0
Use Ctrl+C to exit
Device Name: eth0:0
Device Name: eth1:0
Use Ctrl+C to exit
Device Name: eth0:0
Device Name: eth1:0
Open file: 20091127-113225_ALGNOE_TRACE-start.log
Use Ctrl+C to exit
WARN. Tracer::init: DEPRECATED method. Please use it s sibling
WARN. Tracer::Tracer: DEPRECATED constructor.
WARNING. Number of calls specified in init file is to o high
Number of calls set to 0
WARNING. Number of calls specified in init file is nu ll
WARNING. You need to create an other interface
Use Ctrl+C to exit
Device Name: eth0:0
Device Name: eth1:0
Device Name: eth0:0
Device Name: eth1:0
Device Name: eth0:0
Device Name: eth1:0
Use Ctrl+C to exit
Device Name: eth0:0
Device Name: eth1:0
Use Ctrl+C to exit
Device Name: eth0:0
Device Name: eth1:0
Use Ctrl+C to exit
So i did log from OXE, but this logs doesn't read in notepad.
Here is link for download (it doesn't work insert file here). http://rapidshare.com/files/333575671/sip.log.html
I opened SIP log in wireshark and there aren't IP from SBC. 172.28.1.13 is my IP through VPN and 10.152.144.7 is IP from OXE.
So problem is somewhere in config SBC. When i started X-Lite (from outside) together with wireshark, so i saw only request from X-Lite, but nothing from SBC, no answer. Remote system seems like death (bad configure obviously).
