Eva_tool error
Dan
Eva_tool error
Post by Dan »
When i try to run this command i get the following error.
(101)xa001001> Eva_tool
Grammar error
LIBC caught SIGSEGV in 30757
Registers:
EFLAGS = 0x00010286
EAX = 0x0000000e
EDX = 0x0000000e
EIP = 0x08071050
EDI = 0x08071050
ESI = 0x08081f7f
EBP = 0xbffffb98
EBX = 0xdfdfdfdf
ECX = 0x0807ecb4
Backtrace :
Backtrace recurence: 0 pc:0x08071050 ebp:0xbffffb98
Backtrace recurence: 1 pc:0x0807177f ebp:0xbffffba8
Backtrace recurence: 2 pc:0x0807158f ebp:0xbffffbb8
Backtrace recurence: 3 pc:0x08071566 ebp:0xbffffbcc
Backtrace recurence: 4 pc:0x08066b1b ebp:0xbffffbe8
Backtrace recurence: 5 pc:0x08066b4c ebp:0xbffffc04
Backtrace recurence: 6 pc:0x400307c0 ebp:0xbffffc40
Backtrace recurence: 7 pc:0x08062946 ebp:0x00000000
Segmentation fault
Any ideas.
spring
Post by spring »
Are u already install 4645? What is the status on
1. config 18
2. vmail
Dan
Post by Dan »
voicemail is working fine.
config 18 shows the 4645 is in service and vmail shows status ok.
Dan,
We need more info on your configuration..
Where is the 4645 installed ? CS or separate shelf ?
Copy / paste the result of config 18
Alonso Quijano
Re: Eva_tool error
Post by Alonso Quijano »
I have the same problem,
The SW version is R8.0-g1.302-5-es-c80s1.
Did you have the solution for this problem ?
Thanks.
kafe
Re: Eva_tool error
Post by kafe »
I had the same problem with Eva_tool command. But when I did a shutdown -r now for rebooting, everything goes well. I don't know if its can help you.
swinstu
Re: Eva_tool error
Post by swinstu »
I have also encountered an issue regarding Eva_tool as below:
(1)xa000001> Eva_tool ───────────────────────────────────────────┘
Grammar error or Eva_tool.dct corrupted
LIBC caught SIGSEGV in 19683
Registers:
EFLAGS = 0x00010246
EAX = 00000000
EDX = 0x00000028
EIP = 0x080721bf
EDI = 0x080721bf
ESI = 0x08083303
EBP = 0xbffffbc0
EBX = 0xd79a98af
ECX = 0x0807ffc6
Backtrace :
Backtrace recurence: 0 pc:0x080721bf ebp:0xbffffbc0
Backtrace recurence: 1 pc:0x0807276b ebp:0xbffffbd0
Backtrace recurence: 2 pc:0x080726fe ebp:0xbffffbe4
Backtrace recurence: 3 pc:0x08067c67 ebp:0xbffffc00
Backtrace recurence: 4 pc:0x08067c98 ebp:0xbffffc1c
Backtrace recurence: 5 pc:0x4002d5a0 ebp:0xbffffc58
Backtrace recurence: 6 pc:0x08063a26 ebp:0x00000000
Segmentation fault
I need a permenanet solution to this problem as its repeated itself. System is common hardware and 4645 is on main CS. system is R9.0 H130134. Have checked release notes for .50a but unable to see any fixes.
Has anyone else had this issue and how did they manage to fix it. I am thinking its a harddisk or software load fault. Any suggestions.
Thanks,
swinstu
SWINSTU
ACSE OXE R12.1
ACSE 8770 R3.2(4760 R5.x)
ACSE OT R2.3 IP/SIP and UC&C
swinstu
Re: Eva_tool error
Post by swinstu »
Any suggestions anyone. The voicemail is working fine except unable to execute Eva_tool command.
Swinstu
SWINSTU
ACSE OXE R12.1
alex
Re: Eva_tool error
Post by alex »
swinstu wrote:Grammar error or Eva_tool.dct corrupted
Very likely.
First try to reboot with the forced fsck (-F option). If this error appears again load the latest patch - i would propose even to load new HD and then restore backups of mao and 4645.
rob b
Re: Eva_tool error
Post by rob b »
This is a known issue according to Alcatel , hopefully you have a backup. do you get the same error when telephony is stopped on the cpu ? either way if you type the following xa001001> Eva_tool FORMAT this will reformat the partition so you can then put the backup back on, no need for a new hard drive.
Cheers
Return to “GENERAL”
