connect to slave system over master through VoIP Line
Avi1
Post by Avi1 »
Hi there,
We have the following situation:
Master System: OXO R210_080.001
Slave System : OXO R210_080.001
The Master has about 8 ISDN Lines, the Slave is connected to the master over VoIP Line with 8 VoIP Channels and has NO public line !
My question is now: Is it possible to connect to the slave system through the master system with PM5 ??
thanks
Avi
I believe you mean using Modem connection, you should, if you create a DID to a extension of the second PBX.
But now modem over IP, as far as i know it's impossible because modem signals are more delicate than VoIP ones.
Avi1
Post by Avi1 »
I made an DID to the slave system, but when i try to call it or connect to it with pm5 it always says "line busy".
The curious thing is, that my distributor says it should work. But i can't get any further information from them.
Any other ideas ?
Return to “MAIN”
