MMC Station on A4039
amumar12
Post by amumar12 »
Bravo to you all,
Two questions on OXO
a) Can I use Alcatel 4039 to manage the OXO like with advanced set. If yes how do I log in.
b) I am using virtual extensions for outoing calls. How can I change the passwords of virtual sets because I would like to use substitution.
Thanks folks,
Amumar12
et
Post by et »
a) You can use 4039 set, but only for Operator session. On menu page press "Operator" button, then operator password, then you can use "Expert" key. From R5.0 in Expert menu you can change Network Configuration (IP addresses and so on).
b) First of all You need to have Voice Mail activated. After creating Virtual set, create Voice mailbox for him. Then you can customise settings for mailbox (change password,...) by calling Hunt Group in which you have voice mail ports. Default password = 1515.
Return to “MAIN”
