Control incoming line on trunk
phengvanna
Post by phengvanna »
Hi All Hope all of you doing well
My OXO with ACD connect with 3 analog line
2 line is supose to recieve incoming call at 11:00 am
and another 1 line supose to reciev incoming call at 2:00 pm
I have doubt how to control the time of incoming call instead of pilot open stat
Vanna.
MTCL_DUP
Post by MTCL_DUP »
You mean 2 and 1 external lines ?
For ACD you need in this case 2 hunting groups.
One for 2 lines, one for the other 1 line.
In each hunting group you must add the ACD channels.
Then use "External Lines" Call-Dist" to route your analog lines to the right hunting groups.
Now you can use the ACD menu to setup the rest.
Configure that one hunting group goes to ACD Group 1
and the other to ACD Group 2.
At this time you can configure the desired time in the ACD Group configuration.
phengvanna
I will try
Return to “MAIN”
