Subject: Security BugWare : Alcatel 4400 PBX hack
This is the only article in this thread
View: Original Format
Newsgroups: muc.lists.bugtraq
Date: 2002-02-19 08:51:14 PST
w w w . s e c u r i t y b u g w a r e . o r g
> A D V I S O R Y <
< Playing around with ALCATEL 4400 PBX >
SYSTEM AFFECTED
Alcatel 4400 Pbx
PROBLEM
A little audit of an Alcatel 4400 pbx leads us to some interesting bugs :
default passwords, many root accesses, DoS, halt. If you have a well configured
one, some of them won't work.
The one we tested is under Alcatel support control, they should have the
same "don't change anyting" policy for most of their customers - you should
have the same bugs on yours.
Note that our checks were done in a production environement, without
exploiting bugs.
0- Environnement
ALcatel 4400 runs real-time Chorus OS, now under SUN control.
More information can be found at http://www.sun.com/software/chorusos/
1- find the IP address of Alcatel 4400
Alcatel 4400 can be managed through serial port, or through LAN.
In case of LAN, 4400 is listening on port 2533.
After some sniffing, we show that every TCP packets contains in data field
the size of transmitted datas.
For example, to initiate a connexion, first data packet (after SYN, SYN-ACK,
ACK) contains \x00\x01\x43
\x43 is the data, \x00\x01 is the size - 1 char.
Every other data in first data packet will lead to a FIN-ACK reply,
closing the connexion.
To check for a running 4400 on your LAN, just scan your network for
port 2533 open, then send \x00\x01\x43 and wait for \x00\x01
Use nmap to scan for port 2533 open, and this little script
to send \x00\x01\x43 and wait for \x00\x01 :
8<------------ alcatel.pl
#!/usr/bin/perl
# Checks for Alcatel 4400, sending TCP data on port 2533
# looking for specific reply
# irib@securitybugware.org
use Getopt::Std;
use IO::Socket;
print("ALCATEL 4400 checker.\n");
getopts('s:', \%args);
if(!defined($args{s})){&usage;}
$data = "\x43";
$size = "\x00\x01";
$serv = $args{s};
$port = 2533;
$buf = $size . $data;
if($socket = new IO::Socket::INET(PeerAddr => "$serv:$port", Timeout => 1)){
print $socket "$buf";
read($socket,$chunk,2);
if($chunk & "\x00\x01"){
print "$serv may be an Alcatel 4400\n";
}else{ print "$serv doesn't look like an Alcatel 4400\n";
}else{ print "$serv is not an Alcatel 4400\n";
sub usage {die("\nUsage: $0 -s <server>\n\n");}
8<------------
2- Connect to Alcatel 4400
Here is the default /etc/password file
root:.Zn2PprVBQWI2:0:1:0000-Admin(0000):/:/chbin/sh
halt:xY3mcbaFNyp0k:0:1:0000-Admin(0000):/usr/halt:/chbin/sh
daemon:*:1:1:0000-Admin(0000):/:
bin:*:2:2:0000-Admin(0000):/bin:
sys:*:3:3:0000-Admin(0000):/usr:
adm:*:4:4:0000-Admin(0000):/usr/adm:
sync::67:1:0000-Admin(0000):/:/bin/sync
install:yYV3uyxkFX8bc:101:1:Initial Login:/usr/install:/chbin/sh
kermit:zYBmh/woCrN6E:102:1:kermit:/usr/kermit:/chbin/sh
swinst::0:1:installation-account:/usr/swinst:/chbin/sh
mtch:aUi5.tLxc7zRc:2010:20:mtch:/DHS3bin/mtch:/chbin/ksh
mtcl:bUAp.LcUa4SIo:2011:20:mtcl:/DHS3bin/mtcl:/chbin/ksh
dhs3pms:cUlGakVr1CAkE:2013:20:dhs3pms:/DHS3bin/dhs3pms:/chbin/sh
adfexc:dUHpLtTswZu/Q:2015:20:adfexc:/DHS3bin/adfexc:/chbin/sh
pcmao::2012:20:pcmao:/DHS3bin/mao:/chbin/sh
nmcmao:gUvHzOAi7wETE:2016:20:nmcmao:/DHS3bin/nmcmao:/chbin/sh
client:hUlAPfM7t4Nbo:2017:20:client:/DHS3bin/client:/chbin/sh
dhs3mt:iULmen4O5ZC9.:2018:20:dhs3mt:/DHS3bin/dhs3mt:/chbin/sh
at4400:jU5vsXHRG1lQc:2019:1:at4400:/DHS3bin/at4400:/chbin/sh
mntple:kUKXnTJ4.VGrI:2000:1:Sun-network-installation:/DHS3bin/mntple:/chbin/sh
And some decrypted passwords
llatsni (install)
tlah (halt)
dhs3pms (dhs3pms)
adfexc (adfexc)
client (client)
kermit (kermit)
dhs3mt (dhs3mt)
at4400 (at4400)
mtch (mtch)
mtcl (mtcl)
letacla (root)
Warning : most accounts have a .profile, executing particular commands
so don't log in without knowing what you are doing.
- ~halt/.profile shuts down 4400,
- ~swinst/.profile launch utility to install 4400 from scratch
etc...
mtcl doesn't run anything dangerous, so you can use this one if you need to telnet the
box (it's the one given by Alcatel suppport if you need local management)
User adfexc is used by management client to retrieve version from server
using FTP, it should have always the same password, just be careful because
it executes some stuff in .profile...
3- How to be root, when root password has been changed ?
Fortunately, FTP is open :
nmap returns following
Port State Service
21/tcp open ftp
23/tcp open telnet
513/tcp open login
514/tcp open shell
2533/tcp open unknown
2535/tcp open unknown
2536/tcp open unknown
2539/tcp open unknown
2540/tcp open unknown
2554/tcp open unknown
2555/tcp open unknown
TCP Sequence Prediction: Class=64K rule
Difficulty=1 (Trivial joke)
to log in as root, just ftp as halt user, rename .profile, and telnet
the box... your UID is... O !
4- Halt the Alcatel 4400
You don't need to log in with halt user, nor to log in as root.
Just log in, and execute /chetc/shutdown...
(1)a4400a> ls -l /chetc/shutdown
-r-sr-sr-x 1 root other 6120 Jul 6 1998 /chetc/shutdown
All "other" group member are allowed to shutdown the 4400 (see the setuid bit)
"other" group member are : install kermit swinst mntple at4400 root halt sync
5- Bad file permissions
Lot of directories containing sensible data are world wide writable, or group
writable.
There are two groups easily usable : tel (20) and other (1).
other members : install kermit swinst mntple at4400 root halt sync
tel members : mtcl, mtch, client, dhs3pms adfexc pcmao dhs3mt
Here are some example of writable directories or suid executables...
The easiest way for tel members to access root :
> ls -l /chbin/pre_login
42 -rwsrwxr-x 1 root tel 20096 Oct 9 1998 pre_login
Any tel group members can overwrite /chbin/pre_login, and
execute commands as root...
Overwritable configuration files
/chetc/menus world wide writable
=> netinstall.def & netinstall.bat overwritable
/chetc/msg world wide writable
=> GEA_NET overwritable
/chetc/lck world wide writable
/etc/bootptab ==> world wide writable (config bootp server)
/etc/mnttab ==> world wide writable
Misc world wide writable files & directories
/etc/misc world wide writable
/fs world wide writable
/mnt world wide writable
/usr2/ world wide writable
/usr/ctsrv world wide writable
/usr/preserve world wide writable
/usr/tmp world wide writable
/usr2/soft_install world wide writable
/usr3/mao contains database files (with phone configurations),
all are at least group writable, allowing bad boys to scramble
phones...
All users .profile are overwritable
/usr2/ adfexc afe dhs3mt dhs3pms mao nmcmao ==> group tel writable
/usr2/ PKG at4400 client mntple mtch mtcl ==> group other writable
As userdirs are writable to other group members, .profile are
overwritable by other group members.
/usr4/account looks like accounting file directory, all are
world wide overwritable...
5- Other bugs & exploits ?
Here are not tested things, possibly buggy and exploitable...
- FTP glob() vulnerability has not been tested
- various rsh and login vulnerabilities have to be tested
- Management client should be tested against /DHS3bin/descript/deliv_id
and /DHS3bin/descript/patch_id unusual format (files retrieved through
ftp when connecting with management client)
- Explore network communication between management client and server, sending
periodically "\x00\x08TEST_REQ" (note that \x00\x08 is the size of string
"TEST_REQ"), waiting for "TEST_RSP"
- How to escape from .profile executed when login as swinst (without passwd,
UID=0)
SOLUTIONS
Put your Alcatel 4400 behind a firewall, and allow only connexion between
your pbxs (if you have more than one, linked) and from your management station.
ALCATEL 4400 HACK
Jump to
- General topics
- ↳ Talk to the admins
- ↳ GENERAL
- ↳ Outside World
- ↳ PARTS
- ↳ Pre-Sales
- ↳ JOBS
- ↳ Remote assistance contracts
- ↳ Actis
- ↳ Equipement Pictures
- ↳ OT/OXE/OXO FEATURES REQUESTS
- ↳ Lucent Technologies
- IF YOU ARE NOT TECHNICALLY TRAINED ON THOSE PBX, PLEASE POST IN ONE OF THOSE FORUMS
- ↳ Beginner's questions about the Crystal Hardware
- ↳ Beginner's questions about the Common Hardware
- ↳ Beginner's questions about the (4400 / Enterprise) PHONE APPLICATION or OPERATING SYSTEM
- ↳ Beginner's questions about the OmniPCX OFFICE
- VOICE - Documentation
- ↳ OXE (Crystal / Common) - System Documentation
- ↳ 4760
- ↳ OXO - System Documentation
- ↳ Documentation
- VOICE - OXE (OmniPCX Enterprise)
- ↳ Shelf
- ↳ Media Gateway
- ↳ PWT/DECT System
- ↳ System
- ↳ Translator
- ↳ Classes of Services
- ↳ Attendant
- ↳ Users
- ↳ Users by profile
- ↳ Set Profile
- ↳ Groups
- ↳ Speed Dialing
- ↳ Phone Book
- ↳ Entities
- ↳ Trunk Groups
- ↳ External Services
- ↳ Inter-Node Links
- ↳ X25
- ↳ Data
- ↳ Application
- ↳ Specific Telephone Services
- ↳ ATM
- ↳ Event Routing Discriminator
- ↳ Security and Access Control
- ↳ IP
- ↳ SIP
- ↳ DHCP Configuration
- ↳ Alcatel-Lucent Series 8&9
- ↳ SIP Extension
- ↳ Encryption
- ↳ Passive Communication Server
- ↳ SNMP Configuration
- VOICE - OXE - Common topics
- ↳ MAIN
- ↳ ACTIS
- ↳ Asterisk
- ↳ Boards
- ↳ Bugs & Security issues
- ↳ Equipment Pictures
- ↳ Feature Request
- ↳ H323 / Sip
- ↳ IP / VoIP
- ↳ IP SECURITY / ENCRYPTION (Thales)
- ↳ ipTouch (40x8) issues and tricks
- ↳ Linux tricks
- ↳ MOH
- ↳ ON SITE TROUBLES
- ↳ Phones
- ↳ Sipfoundry
- ↳ Software Loading
- ↳ Swinst
- ↳ System Hacking
- ↳ Traces
- ↳ Usefull commands
- ↳ Voice Guides
- ↳ Wireless configuration and sets
- VOICE - OpenTouch
- ↳ MAIN
- ↳ OTEC - OpenTouch Enterprise Cloud
- ↳ OTBE - OpenTouch Business Edition
- ↳ OTMS - OpenTouch Multimedia Services
- ↳ OTSBC - OpenTouch Session Border Controller
- ↳ OTNS - OpenTouch Notification Service
- ↳ OTMC - OpenTouch Message Center
- ↳ OTFC - OpenTouch Fax Center
- ↳ OpenTouch Conversation
- ↳ Smart Guest Applications
- VOICE - BiCS
- ↳ MAIN
- VOICE - OXO
- ↳ MAIN
- ↳ Configuration
- ↳ 42xx Systems
- ↳ Networking
- ↳ H323 / IP / Pimphony
- ↳ Internet and related
- ↳ Applications
- ↳ Hotel mode
- ↳ DECT
- ↳ Hardware
- VOICE - Omni Suite
- ↳ OmniTouch 8400 Instant Communication Suite
- ↳ OmniTouch 8410 Instant Communication Web Services
- ↳ OmniTouch 8440 Messaging Software
- ↳ OmniTouch 8450 Fax Software
- ↳ OmniTouch 8460 Advanced Communication Server
- ↳ OmniTouch 8464 Meet-me Audio Conference Bridge
- ↳ OmniTouch 8660 My Teamwork Conferencing and Collaboration
- ↳ OmniTouch 8670 Automated Message Delivery System
- ↳ OmniTouch Contact Center Standard Edition
- ↳ OmniTouch Contact Center Premium Edition
- VOICE - Applications
- ↳ AECS - Alcatel Extended Communication Server
- ↳ Alcatel OpenTouch Customer Service
- ↳ Aviso
- ↳ Call Center SoftPanel (ALU ProServices)
- ↳ CCD / CCS / CCIVR
- ↳ Free Desktop
- ↳ GENESYS
- ↳ Hotel / Hospital
- ↳ Ip Desktop Softphone
- ↳ IpTouch Phones XML Applications
- ↳ MSAD
- ↳ MyIC (My Instant Communicator)
- ↳ My Messaging / IMAP
- ↳ My Teamwork (ex-eDial)
- ↳ OmniPCX Record
- ↳ OmniVista 4760
- ↳ OmniVista 8770
- ↳ OTUC
- ↳ PREMIUM / GCE
- ↳ Rainbow
- ↳ Ubiquity
- ↳ ENS - Emergency Notification Server
- ↳ VNA - Visual Notification Assistant
- ↳ VAA - Visual Auto Attendant
- ↳ VitalSuite
- ↳ VitalQIP
- ↳ Voicemail (46x5)
- ↳ XML Presentation Server & TAPI Server
- ↳ 4980 - WebSoftPhone
- ↳ 4625 Interactive Voice Response
- VOICE - Third Party Applications
- ↳ AGITO NETWORKS
- ↳ AUDIOCODES
- ↳ ASTERISK
- ↳ AVST
- ↳ CDR Real time on Ethernet
- ↳ CISCO
- ↳ NGINX
- ↳ NICE
- ↳ Notification Systems
- ↳ OAK
- ↳ SOURCE TECH
- ↳ systel
- ↳ IP Touch apps
- ↳ Click2Dial
- ↳ MYIC apps
- Voice - Virtualization
- ↳ AWS
- ↳ HyperV
- ↳ Linux KVM
- ↳ Proxmox
- ↳ VmWare
- ↳ Other
- Alcatel Unleashed tools, documentations, and misc files...
- ↳ GitHub Script Repository
- ↳ "Home Made" documentations
- ↳ Alcatel Misc Documentation
- ↳ OFFICIAL TC's
- ↳ DIALER
- ↳ infocollect
- ↳ ipview analyzer
- ↳ motview
- ↳ sngrep
- ↳ VM_BACKUP
- ↳ Other Alcatel-Lucent tools
- Developer's corner
- ↳ AHL / OHL
- ↳ Alarming, Notification & Location
- ↳ CCTI / CCA
- ↳ CSTA
- ↳ My IC Phone
- ↳ My IP Touch Service for Enterprise
- ↳ O2G
- ↳ OmniVista 8770 User Provisioning
- ↳ SIP
- ↳ TAPI
- ↳ TSAPI
- ↳ Web Services
- Alcatel Data Equipment
- ↳ Security
- ↳ OmniAccess 3500 Nonstop Laptop Guardian
- ↳ Mobility
- ↳ OmniAccess WLAN Switching Systems
- ↳ OmniAccess WLAN 4302
- ↳ OmniAccess Wireless Access Points 41
- ↳ OmniAccess Wireless Access Points 65
- ↳ OmniAccess Wireless Access Points 60/61/70
- ↳ OmniAccess Wireless Access Points 80M
- ↳ Mobile IP Phones
- ↳ OmniAccess Devices
- ↳ OmniAccess 5780
- ↳ OmniAccess 5740
- ↳ OmniAccess 5510
- ↳ Network Management
- ↳ Omnivista
- ↳ Omnivista Mobility Manager
- DATA - Documentation
- ↳ Technical papers
- ↳ Troubleshooting guides
- DATA - Lan Switching
- ↳ OmniSwitch 10k
- ↳ OmniSwitch 9900
- ↳ OmniSwitch 9000 / 9000E
- ↳ OmniSwitch 6900
- ↳ OmniSwitch 6865
- ↳ OmniSwitch 6870
- ↳ OmniSwitch 6860 / 6860E
- ↳ OmniSwitch 6855
- ↳ OmniSwitch 6850 / 6850E
- ↳ OmniSwitch 6560 / 6570M
- ↳ OmniSwitch 6465
- ↳ OmniSwitch 6450
- ↳ OmniSwitch 6400
- ↳ OmniSwitch 6360
- ↳ OmniSwitch 6350
- ↳ OmniSwitch 6250
- ↳ OmniSwitch 2220
- ↳ OmniSwitch 2260 / 2360
- ↳ Legacy Devices (OS4024, XOS, OmniCore)
- ↳ OmniSwitch 6600 / 7000 / 8800
- ↳ OmniSwitch 6800
- ↳ OmniStack LS 6200
- ↳ Misc
- DATA - WLAN, Mobility and WAN
- ↳ OmniAccess WLAN Switching Systems (OEM)
- ↳ Mobile IPTouch Phones (MIPT)
- ↳ OmniAccess Stellar Express
- ↳ OmniAccess Stellar Enterprise
- ↳ Brick VPN Firewall
- ↳ OmniAccess 5740/5780
- ↳ OmniAccess ESR 5720
- ↳ OmniAccess 5510
- DATA - Network Management
- ↳ OmniVIsta 3600 Air Manager
- ↳ OmniVista 2500 v4.x
- ↳ OmniVista 2500 v3.5
- ↳ OmniVista 2500/2700 v3.4 and older
- ↳ OmniVista Cirrus
- ↳ Alcatel Quarantine Manager
- ↳ Fortigate Security
- DATA - Service Provider
- ↳ 5520 ASAM
- ↳ 5620 SAM
- ↳ 5650 CPAM
- ↳ 5670 RAM
- ↳ 5750 SSC
- ↳ 7210 SAS
- ↳ 7360 ISAM
- ↳ 7450 ESS
- ↳ 7450 Ethernet Service Switch
- ↳ 7750 Service Router
- ↳ 7705 SAR
- ↳ 7750 SR
