trunk SIP OXE-XIVO
Re: trunk SIP OXE-XIVO
bwen wrote:mmm.. real mess with DDI transcoding to false.. cause to set it false, I have to set NPD selector to automatic and this is really not good..
If you manage TG NPD selector - NPD in normal mode - everything (DID id, or not use DID - "-1") managed in NPD. In this case item "DID transcoding" from TG parameters not used.
Really - item DID transcoding - just used for select NPD in automatic mode (f.e. NPD 9 or 10).
One more again - "DID transcoding" just for NPD selection. Everything managed in real NPD. So for system behaviour just check TG NPD selector and NPD.
F.e. - you can declare DID transcoding, system will use NPD 10. But you can manage in NPD 10:
- DID id=1
- DID 1 - manage transparent mode without DID rules.
And really system will works "without DID transcoding".
bwen
Post by bwen »
Hello Vad,
Thanks for your explanations. I have created a new TG "without DDI transcoding", I have no more 404 or 480 error during call but this log:
1475747339 -> Thu Oct  6 11:48:59 2016 RECEIVE MESSAGE FROM NETWORK (192.168.2.1        6:5060 [UDP])
INVITE sip:2299@192.168.XXX.XXX:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.X.X:5060;branch=z9hG4bK602132e0
Max-Forwards: 70
From: "jean-marc " <sip:2373@192.168.X.X>;tag=as1cfed3ba
To: <sip:2299@192.168.XXX.XXX:5060>
Contact: <sip:2373@192.168.X.X:5060>
Call-ID: 0a4c37776b846d1371a4564c71c06145@192.168.X.X:5060
CSeq: 102 INVITE
User-Agent: XIVO PBX
Date: Thu, 06 Oct 2016 09:48:59 GMT
Session-Expires: 1800
Min-SE: 300
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLIS        H, MESSAGE
Supported: replaces, timer
Remote-Party-ID: "jean-marc " <sip:2373@192.168.X.X>;party=calling;privac        y=off;screen=no
Content-Type: application/sdp
Content-Length: 366
v=0
o=root 2078047820 2078047820 IN IP4 192.168.X.X
s=Asterisk PBX 13.9.1
c=IN IP4 192.168.X.X
t=0 0
m=audio 11044 RTP/AVP 8 18 0 4 101
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:0 PCMU/8000
a=rtpmap:4 G723/8000
a=fmtp:4 annexa=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
a=maxptime:150
a=sendrecv
Thu Oct  6 11:48:59 2016  [CIOCom::receiveRequest] optimisation value 1
Thu Oct  6 11:48:59 2016  [CIOCom::IsNoeOptionsMsg] Not in same domain FAILED =>        192.168.XXX.XXX node000000
Thu Oct  6 11:48:59 2016  [CIOCom::IsNoeOptionsMsg] NoeOpt 0
Thu Oct  6 11:48:59 2016 ABBFA [CRequest::CRequest] Creation of a request (RECEI        VED FROM NETWORK)
1475747339 -> Thu Oct  6 11:48:59 2016 [CIOCom::receiveRequest] Received CReques        t ABBFA ref=1
Thu Oct  6 11:48:59 2016 [CIOCom::receiveRequest] rport1 not empty
Thu Oct  6 11:48:59 2016 [CDispatcher::onIncomingRequest()]
Thu Oct  6 11:48:59 2016 [CDispatcher::processRequestFromManagerIndex()] start a        t index 0
Thu Oct  6 11:48:59 2016  102 [CCallManager::onIncomingRequest()]
Thu Oct  6 11:48:59 2016  102 [CCallManager::onIncomingRequest()] creates a new        Call if this request doesn't refer to any old call
Thu Oct  6 11:48:59 2016 [CMotorCallManager::callFactory] For call : 0a4c37776b8        46d1371a4564c71c06145@192.168.X.X:5060.
Thu Oct  6 11:48:59 2016 [CMotorCall :: CMotorCall()] Oxe_Version_Name = OmniPCX        Enterprise R10.0 j1.410.49.a
Thu Oct  6 11:48:59 2016 [CMotorCallManager::callFactory]=850c0a8.
Thu Oct  6 11:48:59 2016 114b [CCall::receiveRequest] INVITE
Thu Oct  6 11:48:59 2016 114b [CCall::getDialog] Confirmed Dialog is not found (        ID = ;as1cfed3ba)
Thu Oct  6 11:48:59 2016 114b [CCall::getDialog] Initial Dialog Server not found
Thu Oct  6 11:48:59 2016 154f [CDialog::receiveRequest]
Thu Oct  6 11:48:59 2016 154f [CDialog::receiveInviteRequest]
Thu Oct  6 11:48:59 2016 216a [CTransaction::changeState] STATE CHANGED TO INITI        AL
Thu Oct  6 11:48:59 2016 216a [CTransaction::changeState] notifying the parent d        ialog
Thu Oct  6 11:48:59 2016 154f [CDialog::onTransactionState(pTrans = 216a, previo        usState = Terminated, currentState = Initial, reason = None]
Thu Oct  6 11:48:59 2016 216a [CTransInitialState::receiveRequest] Transaction c        hanges to Proceeding state
1475747339 -> Thu Oct  6 11:48:59 2016 216a [CTransaction::changeState] STATE CH        ANGED TO PROCEEDING
Thu Oct  6 11:48:59 2016 154f [CDialog::onTransactionState(pTrans = 216a, previo        usState = Initial, currentState = Proceeding, reason = Request reception]
Thu Oct  6 11:48:59 2016 C75F6 [CResponse::CResponse] Creation of a response
Thu Oct  6 11:48:59 2016 216a [CTransProceedingState::createResponse] CResponse        C75F6 ref=1
Thu Oct  6 11:48:59 2016 C75F6 [CResponse::create] RESPONSE CREATION
Thu Oct  6 11:48:59 2016 C75F6 [CResponse::checkStatusLine] Create StatusLine fr        om code given as parameter
Thu Oct  6 11:48:59 2016 C75F6 [CResponse::createViaHeaders] Copy Via headers fr        om previous request (number : 1)
Thu Oct  6 11:48:59 2016 ABBFA [CMessage::getHeaderAtIndexFromSipMessage(Timesta        mp, 0)] sip_getHeaderAtIndex FAILED => HSS ERROR No exist
Thu Oct  6 11:48:59 2016 C75F6 [CResponse::create] Initialize context (Local = T        o & Remote = From)
Thu Oct  6 11:48:59 2016 C75F6 [CMessage::send] sip_sendMessage (192.168.X.X:50        60)
Thu Oct  6 11:48:59 2016 SEND MESSAGE TO NETWORK (192.168.X.X:5060 [UDP]) (BUFF        LEN = 279)
SIP/2.0 100 Trying
CSeq: 102 INVITE
Content-Length: 0
1475747339 -> Thu Oct  6 11:48:59 2016 [sip_freeEventContext]
Thu Oct  6 11:48:59 2016 154f [CDialog::receiveInviteRequest]  a new Server INVI        TE transaction is in progress
Thu Oct  6 11:48:59 2016 [CSessionTimerContext::CSessionTimerContext] New CSessi        onTimerContext from request (Server, UA)
Thu Oct  6 11:48:59 2016 [CSessionTimerContext::updateAfterRefreshReception] Upd        ate CSessionTimerContext (refresh reception)
Thu Oct  6 11:48:59 2016 [CSessionTimerContext::updateSupported] Request timer s        upported
Thu Oct  6 11:48:59 2016 [CSessionTimerContext::updateMinSE] Min-SE updated : 30        0
Thu Oct  6 11:48:59 2016 [CSessionTimerContext::updateSessionExpires] Session-Ex        pires updated : 1800
Thu Oct  6 11:48:59 2016 [CSessionTimerContext::setRefreshMethod] Allow refreshM        ethod=INVITE
Thu Oct  6 11:48:59 2016 154f [CDialog::addTransaction] added transaction 216a w        ith branch z9hG4bK602132e0, with CSeq 102
Thu Oct  6 11:48:59 2016 114b [CCall::checkAuthentication] INVITE
Thu Oct  6 11:48:59 2016 ABBFA [CMessage::getAssertedIdCount] need to create the        wrapper
Thu Oct  6 11:48:59 2016 ABBFA [CMessage::createAssertedIdWrapperFromMessage]
Thu Oct  6 11:48:59 2016 ABBFA [CMessage::createAssertedIdWrapperFromMessage] th        ere is 0 P-Asserted-Identity header in the message
Thu Oct  6 11:48:59 2016 ABBFA [CMessage::getPreferredIdCount] need to create th        e wrapper
Thu Oct  6 11:48:59 2016 ABBFA [CMessage::createPreferredIdWrapperFromMessage] t        here is 0 P-Preferred-Identity header in the message
Thu Oct  6 11:48:59 2016 [CGwMngData::isAuthenticationRequiredForThisClient] 192        .168.2.16 .
1475747339 -> Thu Oct  6 11:48:59 2016 isDomainFromGwExt  SCSWorking: NO
Thu Oct  6 11:48:59 2016 [isDomainFromGwExt] Host from request is : 192.168.X.X        .
Thu Oct  6 11:48:59 2016 [isDomainFromGwExt] User from request is : 2373
Thu Oct  6 11:48:59 2016 isDomainFromGwExt--> For Non-PCS case GwExt=7
Thu Oct  6 11:48:59 2016 domain from External Gateway 7.
Thu Oct  6 11:48:59 2016 874d [CSipAddrSpec::getAddrSpecAsString]
Thu Oct  6 11:48:59 2016 874e [CSipAddrSpec::getAddrSpecAsString]
Thu Oct  6 11:48:59 2016 8751 [CSipAddrSpec::getAddrSpecAsString]
Thu Oct  6 11:48:59 2016 114b[CMotorCall::setFilterUsedMode] To be traced = 0
Thu Oct  6 11:48:59 2016 114b[CMotorCall::initOfUserType] values are reseted
Thu Oct  6 11:48:59 2016 [getFromHeader] displayName="jean-marc ".
Thu Oct  6 11:48:59 2016 [getFromHeader] =2373@192.168.X.X.
Thu Oct  6 11:48:59 2016 [getFromHeader] clirPresent=0.
Thu Oct  6 11:48:59 2016 [isAddrInDico] user=2373 host=192.168.X.X
Thu Oct  6 11:48:59 2016 [isUserInDico] 2373@192.168.X.X
Thu Oct  6 11:48:59 2016 isUserInDico] NOT found in the dictionnary.
Thu Oct  6 11:48:59 2016 [isAddrInDico] other sip user
Thu Oct  6 11:48:59 2016 114b[CMotorCall::getUserType] extGw = 7.
Thu Oct  6 11:48:59 2016 [isValidGwExt] ext gw 7 is valid
1475747339 -> Thu Oct  6 11:48:59 2016 114b[CMotorCall::toGatewayOrProxy] reques        t for proxydomain=192.168.XXX.XXX.
Thu Oct  6 11:48:59 2016 114b[CMotorCall ABCF ExtGW
Thu Oct  6 11:48:59 2016 [isUserRegistred] getRegistration=2299.
Thu Oct  6 11:48:59 2016 [isUserRegistred] result=-1.
Thu Oct  6 11:48:59 2016 [isAddrInDico] user=2299 host=192.168.XXX.XXX
Thu Oct  6 11:48:59 2016 [isUserInDico] 2299@192.168.XXX.XXX
Thu Oct  6 11:48:59 2016 [isUserInDico]  found in the dictionnary.
Thu Oct  6 11:48:59 2016 114b[CMotorCall::storeRequestInCall] inRequest storage=        0x84edb40.
Thu Oct  6 11:48:59 2016 114b[CMotorCall::onReceiveRequest] request for gateway.
Thu Oct  6 11:48:59 2016 114b[CMotorCall::onReceiveRequest] state = INITIAL_STAT        E.
Thu Oct  6 11:48:59 2016 114b[CMotorCall::methodInviteReceived] nb available lic        enses=73 .
Thu Oct  6 11:48:59 2016 114b[CMotorCall::methodInviteReceived] license OK.
Thu Oct  6 11:48:59 2016 35e9 [CSipContextID::isValid] Call-ID is not valid
Thu Oct  6 11:48:59 2016 114b[CMotorCall::compareDialogFromContext] presumed to        be the same Dialog
Thu Oct  6 11:48:59 2016 114b[CMotorCall::methodInviteReceived] Invite => update        the inviteContext.
Thu Oct  6 11:48:59 2016 875a [CSipAddrSpec::CSipAddrSpec()] Invalid type
1475747339 -> Thu Oct  6 11:48:59 2016 [CForkedBranch::CForkedBranch] context =        0x850c550.
Thu Oct  6 11:48:59 2016 875d [CSipAddrSpec::getAddrSpecAsString]
Thu Oct  6 11:48:59 2016 114b[CMotorCall::methodInviteReceived] reqUri stored: s        ip:2373@192.168.X.X:5060
Thu Oct  6 11:48:59 2016 114b[CMotorCall::methodInviteReceived] cacUsed = 0 befo        re.
Thu Oct  6 11:48:59 2016 114b[CMotorCall::methodInviteReceived] returnStat = 0 b        efore.
Thu Oct  6 11:48:59 2016 114b[CMotorCall::methodInviteReceived] cacUsed = 0 afte        r.
Thu Oct  6 11:48:59 2016 114b[CMotorCall::methodInviteReceived] CAC = 0
Thu Oct  6 11:48:59 2016 [receiveInviteMessage] Call: 0a4c37776b846d1371a4564c71        c06145@192.168.X.X:5060 eqt: -1 INITIAL_STATE received a message.
Thu Oct  6 11:48:59 2016 [decodeInviteCLIR].
Thu Oct  6 11:48:59 2016 [receiveInviteMessage] INFO present in Allow header
Thu Oct  6 11:48:59 2016  am_I_PCS SCSWorking : NO
Thu Oct  6 11:48:59 2016  check_extgw_PCSstate EXTGW  is : 7
Thu Oct  6 11:48:59 2016  The check_extgw_PCSstate extgwid : 7
Thu Oct  6 11:48:59 2016  The state of PCS which rescued the extgw is : -1
Thu Oct  6 11:48:59 2016 [decodeInviteFromUsingPAI]. octet3a_scrn = 1
Thu Oct  6 11:48:59 2016 114b[CMotorCall::analyseSessionTimer] exit with  uacGat        ewayMode=0 uacRefresher=0.
1475747339 -> Thu Oct  6 11:48:59 2016 [CSipMediaDescription::parseFormatString]        Got 5 format(s) from string 8 18 0 4 101
Thu Oct  6 11:48:59 2016 [checkSdpValidity] Media 0 type 1 contains 5 formats.
Thu Oct  6 11:48:59 2016 [checkSdpValidity] Format : 8.
Thu Oct  6 11:48:59 2016 114b[CMotorCall::isCryptoAuthorized] config crypto=0/0.
Thu Oct  6 11:48:59 2016 [convertSdpIntoTsdp] No Direction in the session part.
Thu Oct  6 11:48:59 2016 [convertSdpIntoTsdp] Check the direction in Session par        t - result:0.
Thu Oct  6 11:48:59 2016 [convertSdpIntoTsdp] media AUDIO detected (previous cry        pto=0).
Thu Oct  6 11:48:59 2016 [convertAudioMedia] The audio media contains  5 format(        s).
Thu Oct  6 11:48:59 2016 [convertAudioMedia] Format 0 is 8.
Thu Oct  6 11:48:59 2016 [convertAudioMedia] Format 1 is 18.
Thu Oct  6 11:48:59 2016 [convertAudioMedia] Format 2 is 0.
Thu Oct  6 11:48:59 2016 [convertAudioMedia] Format 3 is 4.
Thu Oct  6 11:48:59 2016 [convertAudioMedia] Format 4 is 101.
Thu Oct  6 11:48:59 2016 [convertAudioMedia] 101.
Thu Oct  6 11:48:59 2016 [convertAudioMedia] Format is DTMF:101.
Thu Oct  6 11:48:59 2016 [convertAudioMedia] Direction is sendrecv.
Thu Oct  6 11:48:59 2016 [convertAudioMedia] Connection address retrieved in sdp        : 192.168.X.X.
Thu Oct  6 11:48:59 2016 [convertIPStrIntoTuipv] 192.168.X.X => 192.168.X.X
Thu Oct  6 11:48:59 2016 [display_sdp] address =192.168.X.X
Thu Oct  6 11:48:59 2016 [display_sdp] direction=0.
Thu Oct  6 11:48:59 2016 [convertSdpIntoTsdp] only one media taken into account        xxx crypto_index=0 clear media=1
1475747339 -> Thu Oct  6 11:48:59 2016 [convertSdpIntoTsdp] crypto_index=0 clear        media=1.
Thu Oct  6 11:48:59 2016 [receiveInviteMessage] NO  100rel REQUIRED for this cal        l.
Thu Oct  6 11:48:59 2016 [CInitialState::receiveinvitemessage allow_update 0 pra        ck_required 0
Thu Oct  6 11:48:59 2016 [decodeInviteTo].
Thu Oct  6 11:48:59 2016 [decodeInviteReferredBy].
Thu Oct  6 11:48:59 2016 [decodeInviteACSBU].
Thu Oct  6 11:48:59 2016 114b[emitEventToMonitel] content size (lginfo): 660 cca        l crypted= 0
Thu Oct  6 11:48:59 2016 ** SIP TRUNKING **
Thu Oct  6 11:48:59 2016 [ipc_thread] IPC Thread : Ipc reception 30139.
Thu Oct  6 11:48:59 2016 [ipc_thread] IPC Thread : TCL thread signaled.
Thu Oct  6 11:48:59 2016 [CMotorCallManager::insertCallwithEqt] CMotorCall 3525        inserted.
Thu Oct  6 11:48:59 2016 114b[sendLgEvtSipCreate] Event sent on eqt : 3525
Thu Oct  6 11:48:59 2016 [display_ipc_out] ------------ Begin ---------------
1475747339 -> Thu Oct  6 11:48:59 2016 Id : -1
Thu Oct  6 11:48:59 2016 INVITE
Thu Oct  6 11:48:59 2016 REQUEST URI : <> 2299@192.168.XXX.XXX:5060 ; user=name
Thu Oct  6 11:48:59 2016 FROM : <jean-marc > 2373@192.168.X.X:5060 ; user        =name
Thu Oct  6 11:48:59 2016 TO : <> 2299@192.168.XXX.XXX:5060 ; user=name
Thu Oct  6 11:48:59 2016 CAC : 0
Thu Oct  6 11:48:59 2016   CAC ADDRESS :
Thu Oct  6 11:48:59 2016 CAC-CSBU info : UNKNOWN
Thu Oct  6 11:48:59 2016 CLIR : 0
Thu Oct  6 11:48:59 2016 Prack Required : 0
Thu Oct  6 11:48:59 2016 Allow Update : 0
Thu Oct  6 11:48:59 2016 SDP :
Thu Oct  6 11:48:59 2016   ADDRESS : 192.168.X.X :11044
Thu Oct  6 11:48:59 2016   ALGOS :
Thu Oct  6 11:48:59 2016     PCMA
Thu Oct  6 11:48:59 2016     G729
Thu Oct  6 11:48:59 2016     G723
Thu Oct  6 11:48:59 2016     101
Thu Oct  6 11:48:59 2016   DIRECTION : SEND & RECEIVE
Thu Oct  6 11:48:59 2016   crypto index : 0
Thu Oct  6 11:48:59 2016        N_GW_EXT : 7
Thu Oct  6 11:48:59 2016 [display_ipc_out] ------------- End ----------------
Thu Oct  6 11:48:59 2016 114b[CMotorCall::setCurrentState] NOE-SIP : sendBackupU        pdate Msg not sent to twin CS
Thu Oct  6 11:48:59 2016 [exec_ipc] in 30138.
Thu Oct  6 11:48:59 2016 [display_ipc_in] ------------ Begin ---------------
Thu Oct  6 11:48:59 2016 neqt : 3525 Id : -1
Thu Oct  6 11:48:59 2016 REDIRECTION
Thu Oct  6 11:48:59 2016        CONTACT : <2280> 2280@192.168.XXX.XXX:5060
Thu Oct  6 11:48:59 2016 xx :        2
Thu Oct  6 11:48:59 2016        RELATIVE REQUEST : INVITE
Thu Oct  6 11:48:59 2016 [display_ipc_in] ------------- End ----------------
1475747339 -> Thu Oct  6 11:48:59 2016 [CMotorCallManager::onIncomingEvent] an e        vent 10766 arrived on the eqt 3525 -1.
Thu Oct  6 11:48:59 2016 [CMotorCallManager::onIncomingEvent] state = PROCEEDING        _STATE.
Thu Oct  6 11:48:59 2016 [onIncomingEvent] REDIRECTION arrived.
Thu Oct  6 11:48:59 2016 [receiveRedirectionEvent] Call: 0a4c37776b846d1371a4564        c71c06145@192.168.X.X:5060 eqt: 3525 PROCEEDING_STATE received an event.
Thu Oct  6 11:48:59 2016 114b[CMotorCall::sipUriType] sip Uri.
Thu Oct  6 11:48:59 2016 114b[CMotorCall::isTLSProtRequiredForExtGw] =0.
Thu Oct  6 11:48:59 2016 [isDomainFromGwExt] Host from request is : 192.168.200.        1.
Thu Oct  6 11:48:59 2016 [isDomainFromGwExt] User from request is : 2280
Thu Oct  6 11:48:59 2016 114b [CCall::makeGenericResponse] 302
Thu Oct  6 11:48:59 2016 114b [CCall::getDialog] Returning Initial Dialog Server
Thu Oct  6 11:48:59 2016 154f [CDialog::createResponse] 302
Thu Oct  6 11:48:59 2016 C75F7 [CResponse::CResponse] Creation of a response
Thu Oct  6 11:48:59 2016 216a [CTransProceedingState::createResponse] CResponse        C75F7 ref=1
1475747339 -> Thu Oct  6 11:48:59 2016 C75F7 [CResponse::create] RESPONSE CREATI        ON
Thu Oct  6 11:48:59 2016 C75F7 [CResponse::checkStatusLine] Create StatusLine fr        om code given as parameter
Thu Oct  6 11:48:59 2016 C75F7 [CResponse::createToHeader] Initialize To TAG fro        m context
Thu Oct  6 11:48:59 2016 C75F7 [CResponse::createToHeader] Creation a tag for To        header
Thu Oct  6 11:48:59 2016 C75F7 [CResponse::createViaHeaders] Copy Via headers fr        om previous request (number : 1)
Thu Oct  6 11:48:59 2016 C75F7 [CResponse::create] Initialize context (Local = T        o & Remote = From)
Thu Oct  6 11:48:59 2016 C75F7 [CMessage::send] sip_sendMessage (192.168.X.X:50        60)
Thu Oct  6 11:48:59 2016 SEND MESSAGE TO NETWORK (192.168.X.X:5060 [UDP]) (BUFF        LEN = 423)
SIP/2.0 302 Moved Temporarily
Contact: <sip:2280@192.168.XXX.XXX;user=phone>
User-Agent: OmniPCX Enterprise R10.0 j1.410.49.a
To: <sip:2299@192.168.XXX.XXX:5060>;tag=b294ed7c79308b472e5c3f820e62916a
CSeq: 102 INVITE
Content-Length: 0
Thu Oct  6 11:48:59 2016 C75F6 [~CResponse] resp(100) 0a4c37776b846d1371a4564c71        c06145@192.168.X.X:5060 102 INVITE
Thu Oct  6 11:48:59 2016 216a [CTransProceedingState::createResponse] Final : Tr        ansaction changes to Completed state
1475747339 -> Thu Oct  6 11:48:59 2016 216a [CTransaction::changeState] STATE CH        ANGED TO COMPLETED
Thu Oct  6 11:48:59 2016 154f [CDialog::onTransactionState(pTrans = 216a, previo        usState = Proceeding, currentState = Completed, reason = Final resp creation]
Thu Oct  6 11:48:59 2016 216a [CTransaction::startTimer] Timer G is started (del        ay = 500 ms)
Thu Oct  6 11:48:59 2016 216a [CTransaction::startTimer] Timer H is started (del        ay = 32000 ms)
Thu Oct  6 11:48:59 2016 154f [CDialog::updateRouteSet] there are 0 record-route        headers
Thu Oct  6 11:48:59 2016 [receiveRedirectionEvent] checking CAC for ACK to sent
Thu Oct  6 11:48:59 2016 [receiveRedirectionEvent] CAC is not true
Thu Oct  6 11:48:59 2016 114b[emitEventToMonitel] CAC = 0 eqtCAC = -1
Thu Oct  6 11:48:59 2016 114b[emitEventToMonitel] cacUsed=0 eqtCac=-1
Thu Oct  6 11:48:59 2016 114b[emitEventToMonitel] displayIPCMessageOut
Thu Oct  6 11:48:59 2016 [sendLgEvtSip] Event sent on eqt : 3525 Id :-1
Thu Oct  6 11:48:59 2016 ACK
Thu Oct  6 11:48:59 2016 [receiveRedirectionEvent] Reset of the session.
Thu Oct  6 11:48:59 2016 114b[CMotorCall::unRegister] Remove eqt : 3525 diag : -        1 from the map.
Thu Oct  6 11:48:59 2016 [CMotorCallManager::eraseCallwithEqt] erase 3525 -1.
Thu Oct  6 11:48:59 2016 [exec_ipc] in end 30138.
Thu Oct  6 11:48:59 2016 SIP EQT RELEASED
Thu Oct  6 11:48:59 2016 [CMotorCallManager::onIncomingEvent] an event 10773 arr        ived on the eqt 3525 -1.
Thu Oct  6 11:48:59 2016 [CMotorCallManager::onIncomingEvent] NO call with eqt:        3525 -1 to release.
Thu Oct  6 11:48:59 2016 RECEIVE MESSAGE FROM NETWORK (192.168.X.X:5060 [UDP])
ACK sip:2299@192.168.XXX.XXX:5060 SIP/2.0
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 0
1475747339 -> Thu Oct  6 11:48:59 2016  [CIOCom::receiveRequest] optimisation va        lue 1
Thu Oct  6 11:48:59 2016 ABBFB [CRequest::CRequest] Creation of a request (RECEI        VED FROM NETWORK)
Thu Oct  6 11:48:59 2016 [CIOCom::receiveRequest] Received CRequest ABBFB ref=1
Thu Oct  6 11:48:59 2016 114b [CCall::receiveRequest] ACK
Thu Oct  6 11:48:59 2016 114b [CCall::getDialog] Confirmed Dialog is not found (        ID = b294ed7c79308b472e5c3f820e62916a;as1cfed3ba)
Thu Oct  6 11:48:59 2016 154f [CDialog::receiveAckRequest]
Thu Oct  6 11:48:59 2016 216a [CTransCompletedState::receiveRequest] ACK(UDP) :        Transaction changes to Confirmed state
Thu Oct  6 11:48:59 2016 216a [CTransaction::changeState] STATE CHANGED TO CONFI        RMED
Thu Oct  6 11:48:59 2016 154f [CDialog::onTransactionState(pTrans = 216a, previo        usState = Completed, currentState = Confirmed, reason = Request reception]
1475747339 -> Thu Oct  6 11:48:59 2016 216a [CTransaction::freeTimerToken] Timer        G is freed
Thu Oct  6 11:48:59 2016 216a [CTransaction::freeTimerToken] Timer H is freed
Thu Oct  6 11:48:59 2016 216a [CTransaction::startTimer] Timer I is started (del        ay = 5000 ms)
Thu Oct  6 11:48:59 2016 154f [CDialog::receiveAckRequest] receiving an ACK on a        previously rejected INVITE
Thu Oct  6 11:48:59 2016 114b [CCall::checkAuthentication] ACK
Thu Oct  6 11:48:59 2016 114b[CMotorCall::controlAuthentication] ---*--- END ---        *--- Control authentication
Thu Oct  6 11:48:59 2016 ABBFB [CMessage::getAssertedIdCount] need to create the        wrapper
Thu Oct  6 11:48:59 2016 ABBFB [CMessage::createAssertedIdWrapperFromMessage]
Thu Oct  6 11:48:59 2016 ABBFB [CMessage::createAssertedIdWrapperFromMessage] th        ere is 0 P-Asserted-Identity header in the message
Thu Oct  6 11:48:59 2016 ABBFB [CMessage::getPreferredIdCount] need to create th        e wrapper
Thu Oct  6 11:48:59 2016 ABBFB [CMessage::createPreferredIdWrapperFromMessage] t        here is 0 P-Preferred-Identity header in the message
1475747339 -> Thu Oct  6 11:48:59 2016 [isDomainFromGwExt] Host from request is        : 192.168.X.X.
Thu Oct  6 11:48:59 2016 114b[CMotorCall::toGatewayOrProxy] request for proxydom        ain=192.168.XXX.XXX.
Thu Oct  6 11:48:59 2016 114b[CMotorCall::storeRequestInCall] inRequest storage=        0x854a1e0.
Thu Oct  6 11:48:59 2016 114b[CMotorCall::methodAckReceived] Ack => update the i        nviteContext.
Thu Oct  6 11:48:59 2016 [receiveAckMessage] Call: 0a4c37776b846d1371a4564c71c06        145@192.168.X.X:5060 eqt: -1 INITIAL_STATE received a message.
1475747342 -> Thu Oct  6 11:48:59 2016 [receiveAckMessage] Call is not killed wa        iting for INVITE with authentication param
Thu Oct  6 11:49:02 2016 215f [CTransCompletedState::timerFires] Timer J fires
Thu Oct  6 11:49:02 2016 215f [CTransCompletedState::timerFires] Timer J : Trans        action changes to Terminated state
Thu Oct  6 11:49:02 2016 215f [CTransaction::changeState] STATE CHANGED TO TERMI        NATED
Thu Oct  6 11:49:02 2016 215f [CTransaction::changeState] no transaction state,        terminated reason : Timer J fires
Thu Oct  6 11:49:02 2016 [CTransaction::notifyDialog]
Thu Oct  6 11:49:02 2016 [CTransaction::notifyDialog] notify parent dialog
Thu Oct  6 11:49:02 2016 1546 [CDialog::onTransactionState(pTrans = 215f, previo        usState = null, currentState = Terminated, reason = Timer J fires]
Thu Oct  6 11:49:02 2016 1546 [CDialog::onTransactionState] dialog is terminated
Thu Oct  6 11:49:02 2016 1546 [CDialog::onTransactionState] onDialogClosed
Thu Oct  6 11:49:02 2016 1145 [CCall::onDialogClosed]
Thu Oct  6 11:49:02 2016 1145 [CCall::onDialogClosed] only initial *********
Thu Oct  6 11:49:02 2016 1145 [CCall::onDialogClosed] All the initial dialogs in        the Call are closed
Thu Oct  6 11:49:02 2016 1145 [CCall] closed
Thu Oct  6 11:49:02 2016  102 [CCallManager::onCallClosed]
Thu Oct  6 11:49:02 2016  102 [CCallManager::onCallClosed()] Call 1145 closed. R        emoving call 139468848 from the maps
Thu Oct  6 11:49:02 2016 [CMotorCallManager::onNotifyCallClosed] Call : 10e31ab2        653055d57b717ef53469e871@192.168.X.X:5060 is closed.
^V
(1)cs-paris> timed out waiting for input: auto-logout
I dont understand anything, why forwarding? 2280 isn't even an existing user...
2299 - usual user?
Without any forward? Not DECT set moved to another nodes or something like this (desk sharing etc.)
bwen
Post by bwen »
Finally!!! I see a hope, I really started to desperate. When I call from Xivo to OXE, the remote phone rings! but I dont hear anything and same for my interlocutor...
bwen wrote: but I dont hear anything and same for my interlocutor...
Check codecs - G723/729/711.
And RTP path (network).
When you try to establish calls:
- for signalling used CPU IP address
- for voice - VoIP board (INTIP/GD/GA) IP address.
May be you have route for signalling and have problem (routing, access/protocol rules)with RTP routing.
bwen
Post by bwen »
vad wrote: May be you have route for signalling and have problem (routing, access/protocol rules)with RTP routing.
Its working good! it was a route problem to the remote phone subnetwork on the first gateway. Thanks for your help ;-)
I can call all phones (DECT, analogic, iptouch) except standards (who have 4059 application installed), do you have a tip please?
another thing is the number show on interlocutor phone screen ("073" here) I guess for 2373, it strip 23 and add 0, how can I set it with name?
tgn
Post by tgn »
about the 4059... which number you are calling (individual attendant call, attendant group call). do you have any traces?
about the 073 problem. do you have any traces?
regards...
bwen
Post by bwen »
tgn wrote:about the 4059... which number you are calling (individual attendant call, attendant group call). do you have any traces?
"operator group call"
traced started ...
1476089134 -> Mon Oct 10 10:45:34 2016 RECEIVE MESSAGE FROM NETWORK (192.168.X.X:5060 [UDP])
INVITE sip:2399@192.168.XXX.XXX:5060;user=phone SIP/2.0
Via: SIP/2.0/UDP 192.168.X.X:5060;branch=z9hG4bK7a6f5d40
Max-Forwards: 70
From: "BRYAN_" <sip:2373@192.168.X.X>;tag=as0c03c1de
To: <sip:2399@192.168.XXX.XXX:5060;user=phone>
Call-ID: 4ef890fe127eda7525c422270a30dad1@192.168.X.X:5060
CSeq: 102 INVITE
Date: Mon, 10 Oct 2016 08:45:34 GMT
Min-SE: 300
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH, MESSAGE
Remote-Party-ID: "BRYAN_" <sip:2373@192.168.X.X>;party=calling;privacy=off;screen=no
Content-Length: 366
v=0
o=root 1197324175 1197324175 IN IP4 192.168.X.X
t=0 0
m=audio 17354 RTP/AVP 8 0 18 4 101
a=fmtp:18 annexb=no
a=fmtp:4 annexa=no
a=fmtp:101 0-16
a=ptime:20
a=maxptime:150
a=sendrecv
Mon Oct 10 10:45:34 2016  [CIOCom::receiveRequest] optimisation value 1
Mon Oct 10 10:45:34 2016  [CIOCom::IsNoeOptionsMsg] Not in same domain FAILED => 192.168.XXX.XXX node000000
Mon Oct 10 10:45:34 2016  [CIOCom::IsNoeOptionsMsg] NoeOpt 0
1476089134 -> Mon Oct 10 10:45:34 2016 B24D2 [CRequest::CRequest] Creation of a request (RECEIVED FROM NETWORK)
Mon Oct 10 10:45:34 2016 [CIOCom::receiveRequest] Received CRequest B24D2 ref=1
Mon Oct 10 10:45:34 2016 [CIOCom::receiveRequest] rport1 not empty
Mon Oct 10 10:45:34 2016 [CDispatcher::onIncomingRequest()]
Mon Oct 10 10:45:34 2016 [CDispatcher::processRequestFromManagerIndex()] start at index 0
Mon Oct 10 10:45:34 2016  102 [CCallManager::onIncomingRequest()]
Mon Oct 10 10:45:34 2016  102 [CCallManager::onIncomingRequest()] creates a new Call if this request doesn't refer to any old call
Mon Oct 10 10:45:34 2016 [CMotorCallManager::callFactory] For call : 4ef890fe127eda7525c422270a30dad1@192.168.X.X:5060.
Mon Oct 10 10:45:34 2016 [CMotorCall :: CMotorCall()] Oxe_Version_Name = OmniPCX Enterprise R10.0 j1.410.49.a
Mon Oct 10 10:45:34 2016 [CMotorCallManager::callFactory]=8586430.
Mon Oct 10 10:45:34 2016 1193 [CCall::receiveRequest] INVITE
Mon Oct 10 10:45:34 2016 1193 [CCall::getDialog] Confirmed Dialog is not found (ID = ;as0c03c1de)
Mon Oct 10 10:45:34 2016 1193 [CCall::getDialog] Initial Dialog Server not found
Mon Oct 10 10:45:34 2016 1531 [CDialog::receiveRequest]
Mon Oct 10 10:45:34 2016 1531 [CDialog::receiveInviteRequest]
Mon Oct 10 10:45:34 2016 211b [CTransaction::changeState] STATE CHANGED TO INITIAL
Mon Oct 10 10:45:34 2016 211b [CTransaction::changeState] notifying the parent dialog
Mon Oct 10 10:45:34 2016 1531 [CDialog::onTransactionState(pTrans = 211b, previousState = Terminated, currentState = Initial, reason = None]
1476089134 -> Mon Oct 10 10:45:34 2016 211b [CTransInitialState::receiveRequest] Transaction changes to Proceeding state
Mon Oct 10 10:45:34 2016 211b [CTransaction::changeState] STATE CHANGED TO PROCEEDING
Mon Oct 10 10:45:34 2016 1531 [CDialog::onTransactionState(pTrans = 211b, previousState = Initial, currentState = Proceeding, reason = Request reception]
Mon Oct 10 10:45:34 2016 CEB41 [CResponse::CResponse] Creation of a response
Mon Oct 10 10:45:34 2016 211b [CTransProceedingState::createResponse] CResponse CEB41 ref=1
Mon Oct 10 10:45:34 2016 CEB41 [CResponse::create] RESPONSE CREATION
Mon Oct 10 10:45:34 2016 CEB41 [CResponse::checkStatusLine] Create StatusLine from code given as parameter
Mon Oct 10 10:45:34 2016 CEB41 [CResponse::createViaHeaders] Copy Via headers from previous request (number : 1)
Mon Oct 10 10:45:34 2016 B24D2 [CMessage::getHeaderAtIndexFromSipMessage(Timestamp, 0)] sip_getHeaderAtIndex FAILED => HSS ERROR No exist
Mon Oct 10 10:45:34 2016 CEB41 [CResponse::create] Initialize context (Local = To & Remote = From)
Mon Oct 10 10:45:34 2016 CEB41 [CMessage::send] sip_sendMessage (192.168.X.X:5060)
Mon Oct 10 10:45:34 2016 SEND MESSAGE TO NETWORK (192.168.X.X:5060 [UDP]) (BUFF LEN = 286)
SIP/2.0 100 Trying
CSeq: 102 INVITE
Content-Length: 0
1476089134 -> Mon Oct 10 10:45:34 2016 [sip_freeEventContext]
Mon Oct 10 10:45:34 2016 1531 [CDialog::receiveInviteRequest]  a new Server INVITE transaction is in progress
Mon Oct 10 10:45:34 2016 [CSessionTimerContext::CSessionTimerContext] New CSessionTimerContext from request (Server, UA)
Mon Oct 10 10:45:34 2016 [CSessionTimerContext::updateAfterRefreshReception] Update CSessionTimerContext (refresh reception)
Mon Oct 10 10:45:34 2016 [CSessionTimerContext::updateSupported] Request timer supported
Mon Oct 10 10:45:34 2016 [CSessionTimerContext::updateMinSE] Min-SE updated : 300
Mon Oct 10 10:45:34 2016 [CSessionTimerContext::updateSessionExpires] Session-Expires updated : 1800
Mon Oct 10 10:45:34 2016 [CSessionTimerContext::setRefreshMethod] Allow refreshMethod=INVITE
Mon Oct 10 10:45:34 2016 1531 [CDialog::addTransaction] added transaction 211b with branch z9hG4bK7a6f5d40, with CSeq 102
Mon Oct 10 10:45:34 2016 1193 [CCall::checkAuthentication] INVITE
Mon Oct 10 10:45:34 2016 B24D2 [CMessage::getAssertedIdCount] need to create the wrapper
Mon Oct 10 10:45:34 2016 B24D2 [CMessage::createAssertedIdWrapperFromMessage]
Mon Oct 10 10:45:34 2016 B24D2 [CMessage::createAssertedIdWrapperFromMessage] there is 0 P-Asserted-Identity header in the message
Mon Oct 10 10:45:34 2016 B24D2 [CMessage::getPreferredIdCount] need to create the wrapper
Mon Oct 10 10:45:34 2016 B24D2 [CMessage::createPreferredIdWrapperFromMessage] there is 0 P-Preferred-Identity header in the message
Mon Oct 10 10:45:34 2016 [CGwMngData::isAuthenticationRequiredForThisClient] 192.168.X.X .
1476089134 -> Mon Oct 10 10:45:34 2016 isDomainFromGwExt  SCSWorking: NO
Mon Oct 10 10:45:34 2016 [isDomainFromGwExt] Host from request is : 192.168.X.X.
Mon Oct 10 10:45:34 2016 [isDomainFromGwExt] User from request is : 2373
Mon Oct 10 10:45:34 2016 isDomainFromGwExt--> For Non-PCS case GwExt=7
Mon Oct 10 10:45:34 2016 domain from External Gateway 7.
Mon Oct 10 10:45:34 2016 87c9 [CSipAddrSpec::getAddrSpecAsString]
Mon Oct 10 10:45:34 2016 87ca [CSipAddrSpec::getAddrSpecAsString]
Mon Oct 10 10:45:34 2016 87cd [CSipAddrSpec::getAddrSpecAsString]
Mon Oct 10 10:45:34 2016 1193[CMotorCall::setFilterUsedMode] To be traced = 0
Mon Oct 10 10:45:34 2016 1193[CMotorCall::initOfUserType] values are reseted
Mon Oct 10 10:45:34 2016 [getFromHeader] displayName="BRYAN_".
Mon Oct 10 10:45:34 2016 [getFromHeader] =2373@192.168.X.X.
Mon Oct 10 10:45:34 2016 [getFromHeader] clirPresent=0.
Mon Oct 10 10:45:34 2016 [isAddrInDico] user=2373 host=192.168.X.X
Mon Oct 10 10:45:34 2016 [isUserInDico] 2373@192.168.X.X
Mon Oct 10 10:45:34 2016 isUserInDico] NOT found in the dictionnary.
Mon Oct 10 10:45:34 2016 [isAddrInDico] other sip user
Mon Oct 10 10:45:34 2016 1193[CMotorCall::getUserType] extGw = 7.
Mon Oct 10 10:45:34 2016 [isValidGwExt] ext gw 7 is valid
1476089134 -> Mon Oct 10 10:45:34 2016 1193[CMotorCall::toGatewayOrProxy] request for proxydomain=192.168.XXX.XXX.
Mon Oct 10 10:45:34 2016 1193[CMotorCall ABCF ExtGW
Mon Oct 10 10:45:34 2016 [isUserRegistred] getRegistration=2399.
Mon Oct 10 10:45:34 2016 [isUserRegistred] result=-1.
Mon Oct 10 10:45:34 2016 [isAddrInDico] user=2399 host=192.168.XXX.XXX
Mon Oct 10 10:45:34 2016 [isUserInDico] 2399@192.168.XXX.XXX
Mon Oct 10 10:45:34 2016 1193[CMotorCall::storeRequestInCall] inRequest storage=0x8551d98.
Mon Oct 10 10:45:34 2016 1193[CMotorCall::onReceiveRequest] request for gateway.
Mon Oct 10 10:45:34 2016 1193[CMotorCall::onReceiveRequest] state = INITIAL_STATE.
Mon Oct 10 10:45:34 2016 1193[CMotorCall::methodInviteReceived] nb available licenses=71 .
Mon Oct 10 10:45:34 2016 1193[CMotorCall::methodInviteReceived] license OK.
Mon Oct 10 10:45:34 2016 3525 [CSipContextID::isValid] Call-ID is not valid
Mon Oct 10 10:45:34 2016 1193[CMotorCall::compareDialogFromContext] presumed to be the same Dialog
Mon Oct 10 10:45:34 2016 1193[CMotorCall::methodInviteReceived] Invite => update the inviteContext.
Mon Oct 10 10:45:34 2016 87d6 [CSipAddrSpec::CSipAddrSpec()] Invalid type
1476089134 -> Mon Oct 10 10:45:34 2016 [CForkedBranch::CForkedBranch] context = 0x85868d8.
Mon Oct 10 10:45:34 2016 87d9 [CSipAddrSpec::getAddrSpecAsString]
Mon Oct 10 10:45:34 2016 1193[CMotorCall::methodInviteReceived] reqUri stored: sip:2373@192.168.X.X:5060
Mon Oct 10 10:45:34 2016 1193[CMotorCall::methodInviteReceived] cacUsed = 0 before.
Mon Oct 10 10:45:34 2016 1193[CMotorCall::methodInviteReceived] returnStat = 0 before.
Mon Oct 10 10:45:34 2016 1193[CMotorCall::methodInviteReceived] cacUsed = 0 after.
Mon Oct 10 10:45:34 2016 1193[CMotorCall::methodInviteReceived] CAC = 0
Mon Oct 10 10:45:34 2016 [receiveInviteMessage] Call: 4ef890fe127eda7525c422270a30dad1@192.168.X.X:5060 eqt: -1 INITIAL_STATE received a message.
Mon Oct 10 10:45:34 2016 [decodeInviteCLIR].
Mon Oct 10 10:45:34 2016 [receiveInviteMessage] INFO present in Allow header
Mon Oct 10 10:45:34 2016  am_I_PCS SCSWorking : NO
Mon Oct 10 10:45:34 2016  check_extgw_PCSstate EXTGW  is : 7
Mon Oct 10 10:45:34 2016  The check_extgw_PCSstate extgwid : 7
Mon Oct 10 10:45:34 2016  The state of PCS which rescued the extgw is : -1
Mon Oct 10 10:45:34 2016 [decodeInviteFromUsingPAI]. octet3a_scrn = 1
Mon Oct 10 10:45:34 2016 1193[CMotorCall::analyseSessionTimer] exit with  uacGatewayMode=0 uacRefresher=0.
1476089134 -> Mon Oct 10 10:45:34 2016 [CSipMediaDescription::parseFormatString] Got 5 format(s) from string 8 0 18 4 101
Mon Oct 10 10:45:34 2016 [checkSdpValidity] Media 0 type 1 contains 5 formats.
Mon Oct 10 10:45:34 2016 [checkSdpValidity] Format : 8.
Mon Oct 10 10:45:34 2016 1193[CMotorCall::isCryptoAuthorized] config crypto=0/0.
Mon Oct 10 10:45:34 2016 [convertSdpIntoTsdp] No Direction in the session part.
Mon Oct 10 10:45:34 2016 [convertSdpIntoTsdp] Check the direction in Session part - result:0.
Mon Oct 10 10:45:34 2016 [convertSdpIntoTsdp] media AUDIO detected (previous crypto=0).
Mon Oct 10 10:45:34 2016 [convertAudioMedia] The audio media contains  5 format(s).
Mon Oct 10 10:45:34 2016 [convertAudioMedia] Format 0 is 8.
Mon Oct 10 10:45:34 2016 [convertAudioMedia] Format 1 is 0.
Mon Oct 10 10:45:34 2016 [convertAudioMedia] Format 2 is 18.
Mon Oct 10 10:45:34 2016 [convertAudioMedia] Format 3 is 4.
Mon Oct 10 10:45:34 2016 [convertAudioMedia] Format 4 is 101.
Mon Oct 10 10:45:34 2016 [convertAudioMedia] 101.
Mon Oct 10 10:45:34 2016 [convertAudioMedia] Format is DTMF:101.
Mon Oct 10 10:45:34 2016 [convertAudioMedia] Direction is sendrecv.
Mon Oct 10 10:45:34 2016 [convertAudioMedia] Connection address retrieved in sdp: 192.168.X.X.
Mon Oct 10 10:45:34 2016 [convertIPStrIntoTuipv] 192.168.X.X => 192.168.X.X
Mon Oct 10 10:45:34 2016 [display_sdp] address =192.168.X.X
Mon Oct 10 10:45:34 2016 [display_sdp] direction=0.
Mon Oct 10 10:45:34 2016 [convertSdpIntoTsdp] only one media taken into account xxx crypto_index=0 clear media=1
1476089134 -> Mon Oct 10 10:45:34 2016 [convertSdpIntoTsdp] crypto_index=0 clear media=1.
Mon Oct 10 10:45:34 2016 [receiveInviteMessage] NO  100rel REQUIRED for this call.
Mon Oct 10 10:45:34 2016 [CInitialState::receiveinvitemessage allow_update 0 prack_required 0
Mon Oct 10 10:45:34 2016 [decodeInviteTo].
Mon Oct 10 10:45:34 2016 [decodeInviteReferredBy].
Mon Oct 10 10:45:34 2016 [decodeInviteACSBU].
Mon Oct 10 10:45:34 2016 1193[emitEventToMonitel] content size (lginfo): 660 ccal crypted= 0
Mon Oct 10 10:45:34 2016 ** SIP TRUNKING **
Mon Oct 10 10:45:34 2016 [ipc_thread] IPC Thread : Ipc reception 30139.
Mon Oct 10 10:45:34 2016 [ipc_thread] IPC Thread : TCL thread signaled.
Mon Oct 10 10:45:34 2016 [CMotorCallManager::insertCallwithEqt] CMotorCall 3525 inserted.
Mon Oct 10 10:45:34 2016 1193[sendLgEvtSipCreate] Event sent on eqt : 3525
Mon Oct 10 10:45:34 2016 [display_ipc_out] ------------ Begin ---------------
1476089134 -> Mon Oct 10 10:45:34 2016 Id : -1
Mon Oct 10 10:45:34 2016 INVITE
Mon Oct 10 10:45:34 2016 REQUEST URI : <> 2399@192.168.XXX.XXX:5060 ; user=phone
Mon Oct 10 10:45:34 2016 FROM : <BRYAN_> 2373@192.168.X.X:5060 ; user=name
Mon Oct 10 10:45:34 2016 TO : <> 2399@192.168.XXX.XXX:5060 ; user=phone
Mon Oct 10 10:45:34 2016 CAC : 0
Mon Oct 10 10:45:34 2016   CAC ADDRESS :
Mon Oct 10 10:45:34 2016 CAC-CSBU info : UNKNOWN
Mon Oct 10 10:45:34 2016 CLIR : 0
Mon Oct 10 10:45:34 2016 Prack Required : 0
Mon Oct 10 10:45:34 2016 Allow Update : 0
Mon Oct 10 10:45:34 2016 SDP :
Mon Oct 10 10:45:34 2016   ADDRESS : 192.168.X.X :17354
Mon Oct 10 10:45:34 2016   ALGOS :
Mon Oct 10 10:45:34 2016     PCMA
Mon Oct 10 10:45:34 2016     G729
Mon Oct 10 10:45:34 2016     G723
Mon Oct 10 10:45:34 2016     101
Mon Oct 10 10:45:34 2016   DIRECTION : SEND & RECEIVE
Mon Oct 10 10:45:34 2016   crypto index : 0
Mon Oct 10 10:45:34 2016        N_GW_EXT : 7
Mon Oct 10 10:45:34 2016 [display_ipc_out] ------------- End ----------------
Mon Oct 10 10:45:34 2016 1193[CMotorCall::setCurrentState] NOE-SIP : sendBackupUpdate Msg not sent to twin CS
Mon Oct 10 10:45:34 2016 [exec_ipc] in 30138.
Mon Oct 10 10:45:34 2016 [display_ipc_in] ------------ Begin ---------------
Mon Oct 10 10:45:34 2016 neqt : 3525 Id : -1
Mon Oct 10 10:45:34 2016 REDIRECTION
Mon Oct 10 10:45:34 2016        CONTACT : <2371> 2371@192.168.XXX.XXX:5060
Mon Oct 10 10:45:34 2016 DIVERSION :
Mon Oct 10 10:45:34 2016        URL : <663> ▒@CCUEIL 2 :13874
Mon Oct 10 10:45:34 2016        REASON : UNKNOWN
1476089134 -> Mon Oct 10 10:45:34 2016  COUNTER :        0
Mon Oct 10 10:45:34 2016 xx :        2
Mon Oct 10 10:45:34 2016        RELATIVE REQUEST : INVITE
Mon Oct 10 10:45:34 2016 [display_ipc_in] ------------- End ----------------
Mon Oct 10 10:45:34 2016 [CMotorCallManager::onIncomingEvent] an event 10766 arrived on the eqt 3525 -1.
Mon Oct 10 10:45:34 2016 [CMotorCallManager::onIncomingEvent] state = PROCEEDING_STATE.
Mon Oct 10 10:45:34 2016 [onIncomingEvent] REDIRECTION arrived.
Mon Oct 10 10:45:34 2016 [receiveRedirectionEvent] Call: 4ef890fe127eda7525c422270a30dad1@192.168.X.X:5060 eqt: 3525 PROCEEDING_STATE received an event.
Mon Oct 10 10:45:34 2016 1193[CMotorCall::sipUriType] sip Uri.
Mon Oct 10 10:45:34 2016 1193[CMotorCall::isTLSProtRequiredForExtGw] =0.
Mon Oct 10 10:45:34 2016 [isDomainFromGwExt] Host from request is : 192.168.XXX.XXX.
Mon Oct 10 10:45:34 2016 [isDomainFromGwExt] User from request is : 2371
Mon Oct 10 10:45:34 2016 1193 [CCall::makeGenericResponse] 302
Mon Oct 10 10:45:34 2016 1193 [CCall::getDialog] Returning Initial Dialog Server
1476089134 -> Mon Oct 10 10:45:34 2016 1531 [CDialog::createResponse] 302
Mon Oct 10 10:45:34 2016 CEB42 [CResponse::CResponse] Creation of a response
Mon Oct 10 10:45:34 2016 211b [CTransProceedingState::createResponse] CResponse CEB42 ref=1
Mon Oct 10 10:45:34 2016 CEB42 [CResponse::create] RESPONSE CREATION
Mon Oct 10 10:45:34 2016 CEB42 [CResponse::checkStatusLine] Create StatusLine from code given as parameter
Mon Oct 10 10:45:34 2016 CEB42 [CResponse::createToHeader] Initialize To TAG from context
Mon Oct 10 10:45:34 2016 CEB42 [CResponse::createToHeader] Creation a tag for To header
Mon Oct 10 10:45:34 2016 CEB42 [CResponse::createViaHeaders] Copy Via headers from previous request (number : 1)
Mon Oct 10 10:45:34 2016 CEB42 [CResponse::create] Initialize context (Local = To & Remote = From)
Mon Oct 10 10:45:34 2016 CEB42 [CMessage::send] sip_sendMessage (192.168.X.X:5060)
Mon Oct 10 10:45:34 2016 SEND MESSAGE TO NETWORK (192.168.X.X:5060 [UDP]) (BUFF LEN = 487)
Contact: <sip:2371@192.168.XXX.XXX;user=phone>
P-Alcatel-CSBU: rd=unknown;call_condition=forwardeduser
To: <sip:2399@192.168.XXX.XXX:5060;user=phone>;tag=4d882abcccd84e1481b197f3d2fe566c
CSeq: 102 INVITE
Content-Length: 0
Mon Oct 10 10:45:34 2016 CEB41 [~CResponse] resp(100) 4ef890fe127eda7525c422270a30dad1@192.168.X.X:5060 102 INVITE
Mon Oct 10 10:45:34 2016 211b [CTransProceedingState::createResponse] Final : Transaction changes to Completed state
Mon Oct 10 10:45:34 2016 211b [CTransaction::changeState] STATE CHANGED TO COMPLETED
Mon Oct 10 10:45:34 2016 1531 [CDialog::onTransactionState(pTrans = 211b, previousState = Proceeding, currentState = Completed, reason = Final resp creation]
Mon Oct 10 10:45:34 2016 211b [CTransaction::startTimer] Timer G is started (delay = 500 ms)
Mon Oct 10 10:45:34 2016 211b [CTransaction::startTimer] Timer H is started (delay = 32000 ms)
Mon Oct 10 10:45:34 2016 1531 [CDialog::updateRouteSet] there are 0 record-route headers
Mon Oct 10 10:45:34 2016 [receiveRedirectionEvent] checking CAC for ACK to sent
Mon Oct 10 10:45:34 2016 [receiveRedirectionEvent] CAC is not true
Mon Oct 10 10:45:34 2016 1193[emitEventToMonitel] CAC = 0 eqtCAC = -1
Mon Oct 10 10:45:34 2016 1193[emitEventToMonitel] cacUsed=0 eqtCac=-1
Mon Oct 10 10:45:34 2016 1193[emitEventToMonitel] displayIPCMessageOut
1476089134 -> Mon Oct 10 10:45:34 2016 [isValidGwExt] ext gw 7 is valid
Mon Oct 10 10:45:34 2016 [sendLgEvtSip] Event sent on eqt : 3525 Id :-1
Mon Oct 10 10:45:34 2016 ACK
Mon Oct 10 10:45:34 2016 [receiveRedirectionEvent] Reset of the session.
Mon Oct 10 10:45:34 2016 1193[CMotorCall::unRegister] Remove eqt : 3525 diag : -1 from the map.
Mon Oct 10 10:45:34 2016 [CMotorCallManager::eraseCallwithEqt] erase 3525 -1.
Mon Oct 10 10:45:34 2016 [exec_ipc] in end 30138.
Mon Oct 10 10:45:34 2016 SIP EQT RELEASED
Mon Oct 10 10:45:34 2016 [CMotorCallManager::onIncomingEvent] an event 10773 arrived on the eqt 3525 -1.
Mon Oct 10 10:45:34 2016 [CMotorCallManager::onIncomingEvent] NO call with eqt: 3525 -1 to release.
ACK sip:2399@192.168.XXX.XXX:5060;user=phone SIP/2.0
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 0
1476089134 -> Mon Oct 10 10:45:34 2016  [CIOCom::receiveRequest] optimisation value 1
Mon Oct 10 10:45:34 2016 B24D3 [CRequest::CRequest] Creation of a request (RECEIVED FROM NETWORK)
Mon Oct 10 10:45:34 2016 [CIOCom::receiveRequest] Received CRequest B24D3 ref=1
Mon Oct 10 10:45:34 2016 1193 [CCall::receiveRequest] ACK
Mon Oct 10 10:45:34 2016 1193 [CCall::getDialog] Confirmed Dialog is not found (ID = 4d882abcccd84e1481b197f3d2fe566c;as0c03c1de)
Mon Oct 10 10:45:34 2016 1531 [CDialog::receiveAckRequest]
Mon Oct 10 10:45:34 2016 211b [CTransCompletedState::receiveRequest] ACK(UDP) : Transaction changes to Confirmed state
Mon Oct 10 10:45:34 2016 211b [CTransaction::changeState] STATE CHANGED TO CONFIRMED
Mon Oct 10 10:45:34 2016 1531 [CDialog::onTransactionState(pTrans = 211b, previousState = Completed, currentState = Confirmed, reason = Request reception]
1476089134 -> Mon Oct 10 10:45:34 2016 211b [CTransaction::freeTimerToken] Timer G is freed
Mon Oct 10 10:45:34 2016 211b [CTransaction::freeTimerToken] Timer H is freed
Mon Oct 10 10:45:34 2016 211b [CTransaction::startTimer] Timer I is started (delay = 5000 ms)
Mon Oct 10 10:45:34 2016 1531 [CDialog::receiveAckRequest] receiving an ACK on a previously rejected INVITE
Mon Oct 10 10:45:34 2016 1193 [CCall::checkAuthentication] ACK
Mon Oct 10 10:45:34 2016 1193[CMotorCall::controlAuthentication] ---*--- END ---*--- Control authentication
Mon Oct 10 10:45:34 2016 B24D3 [CMessage::getAssertedIdCount] need to create the wrapper
Mon Oct 10 10:45:34 2016 B24D3 [CMessage::createAssertedIdWrapperFromMessage]
Mon Oct 10 10:45:34 2016 B24D3 [CMessage::createAssertedIdWrapperFromMessage] there is 0 P-Asserted-Identity header in the message
Mon Oct 10 10:45:34 2016 B24D3 [CMessage::getPreferredIdCount] need to create the wrapper
Mon Oct 10 10:45:34 2016 B24D3 [CMessage::createPreferredIdWrapperFromMessage] there is 0 P-Preferred-Identity header in the message
1476089134 -> Mon Oct 10 10:45:34 2016 [isDomainFromGwExt] Host from request is : 192.168.X.X.
Mon Oct 10 10:45:34 2016 1193[CMotorCall::storeRequestInCall] inRequest storage=0x85d3550.
Mon Oct 10 10:45:34 2016 1193[CMotorCall::methodAckReceived] Ack => update the inviteContext.
Mon Oct 10 10:45:34 2016 [receiveAckMessage] Call: 4ef890fe127eda7525c422270a30dad1@192.168.X.X:5060 eqt: -1 INITIAL_STATE received a message.
1476089137 -> Mon Oct 10 10:45:34 2016 [receiveAckMessage] Call is not killed waiting for INVITE with authentication param
tgn wrote:about the 073 problem. do you have any traces?
here it is (sorry , another call between):
traced started ...
1476091056 -> Mon Oct 10 11:17:34 2016 [sip_freeEventContext]
Mon Oct 10 11:17:34 2016 21d5 [CTransaction::changeState] STATE CHANGED TO TERMI        NATED
Mon Oct 10 11:17:34 2016 21d5 [CTransaction::freeTimerToken] Timer D is freed
Mon Oct 10 11:17:34 2016 21d5 [CTransaction::changeState] no transaction state,        terminated reason : Request creation
Mon Oct 10 11:17:34 2016 1522 [CDialog::createAckRequest] successful INVITE is t        erminated after the ACK is sent
Mon Oct 10 11:17:34 2016 1122[CMotorCall::setCurrentState] NOE-SIP : sendBackupU        pdate Msg not sent to twin CS
Mon Oct 10 11:17:34 2016 [exec_ipc] in end 30138.
Mon Oct 10 11:17:34 2016 [CTransaction::notifyDialog]
Mon Oct 10 11:17:34 2016 [CTransaction::notifyDialog] notify parent dialog
Mon Oct 10 11:17:34 2016 1522 [CDialog::onTransactionState(pTrans = 21d5, previo        usState = null, currentState = Terminated, reason = Request creation]
Mon Oct 10 11:17:34 2016 21D5 [~CTransaction] transaction 1399642855 INVITE
Mon Oct 10 11:17:36 2016 RECEIVE MESSAGE FROM NETWORK (192.168.X.X:5060 [UDP])
INVITE sip:2621@192.168.XXX.XXX:5060;user=phone SIP/2.0
Via: SIP/2.0/UDP 192.168.X.X:5060;branch=z9hG4bK5ddfda31
Max-Forwards: 70
From: "BRYAN" <sip:2373@192.168.X.X>;tag=as434494ea
To: <sip:2621@192.168.XXX.XXX:5060;user=phone>
Call-ID: 5b2021067e7722a144d5752d13ab0305@192.168.X.X:5060
CSeq: 102 INVITE
Date: Mon, 10 Oct 2016 09:17:36 GMT
Min-SE: 300
Remote-Party-ID: "BRYAN" <sip:2373@192.168.X.X>;party=calling;privacy=of        f;screen=no
Content-Length: 364
v=0
o=root 437104877 437104877 IN IP4 192.168.X.X
t=0 0
m=audio 11270 RTP/AVP 8 0 18 4 101
a=fmtp:18 annexb=no
a=fmtp:4 annexa=no
a=fmtp:101 0-16
a=ptime:20
a=maxptime:150
a=sendrecv
1476091056 -> Mon Oct 10 11:17:36 2016  [CIOCom::receiveRequest] optimisation va        lue 1
Mon Oct 10 11:17:36 2016  [CIOCom::IsNoeOptionsMsg] Not in same domain FAILED =>        192.168.XXX.XXX node000000
Mon Oct 10 11:17:36 2016  [CIOCom::IsNoeOptionsMsg] NoeOpt 0
Mon Oct 10 11:17:36 2016 B26F0 [CRequest::CRequest] Creation of a request (RECEI        VED FROM NETWORK)
Mon Oct 10 11:17:36 2016 [CIOCom::receiveRequest] Received CRequest B26F0 ref=1
Mon Oct 10 11:17:36 2016 [CIOCom::receiveRequest] rport1 not empty
Mon Oct 10 11:17:36 2016 [CDispatcher::onIncomingRequest()]
Mon Oct 10 11:17:36 2016 [CDispatcher::processRequestFromManagerIndex()] start a        t index 0
Mon Oct 10 11:17:36 2016  102 [CCallManager::onIncomingRequest()]
Mon Oct 10 11:17:36 2016  102 [CCallManager::onIncomingRequest()] creates a new        Call if this request doesn't refer to any old call
Mon Oct 10 11:17:36 2016 [CMotorCallManager::callFactory] For call : 5b2021067e7        722a144d5752d13ab0305@192.168.X.X:5060.
Mon Oct 10 11:17:36 2016 [CMotorCall :: CMotorCall()] Oxe_Version_Name = OmniPCX        Enterprise R10.0 j1.410.49.a
Mon Oct 10 11:17:36 2016 [CMotorCallManager::callFactory]=850d6d8.
Mon Oct 10 11:17:36 2016 1125 [CCall::receiveRequest] INVITE
Mon Oct 10 11:17:36 2016 1125 [CCall::getDialog] Confirmed Dialog is not found (        ID = ;as434494ea)
Mon Oct 10 11:17:36 2016 1125 [CCall::getDialog] Initial Dialog Server not found
Mon Oct 10 11:17:36 2016 1526 [CDialog::receiveRequest]
Mon Oct 10 11:17:36 2016 1526 [CDialog::receiveInviteRequest]
Mon Oct 10 11:17:36 2016 21d6 [CTransaction::changeState] STATE CHANGED TO INITI        AL
1476091056 -> Mon Oct 10 11:17:36 2016 21d6 [CTransaction::changeState] notifyin        g the parent dialog
Mon Oct 10 11:17:36 2016 1526 [CDialog::onTransactionState(pTrans = 21d6, previo        usState = Terminated, currentState = Initial, reason = None]
Mon Oct 10 11:17:36 2016 21d6 [CTransInitialState::receiveRequest] Transaction c        hanges to Proceeding state
Mon Oct 10 11:17:36 2016 21d6 [CTransaction::changeState] STATE CHANGED TO PROCE        EDING
Mon Oct 10 11:17:36 2016 21d6 [CTransaction::changeState] notifying the parent d        ialog
Mon Oct 10 11:17:36 2016 1526 [CDialog::onTransactionState(pTrans = 21d6, previo        usState = Initial, currentState = Proceeding, reason = Request reception]
Mon Oct 10 11:17:36 2016 CEDC9 [CResponse::CResponse] Creation of a response
Mon Oct 10 11:17:36 2016 21d6 [CTransProceedingState::createResponse] CResponse        CEDC9 ref=1
Mon Oct 10 11:17:36 2016 CEDC9 [CResponse::create] RESPONSE CREATION
Mon Oct 10 11:17:36 2016 CEDC9 [CResponse::checkStatusLine] Create StatusLine fr        om code given as parameter
Mon Oct 10 11:17:36 2016 CEDC9 [CResponse::createViaHeaders] Copy Via headers fr        om previous request (number : 1)
Mon Oct 10 11:17:36 2016 B26F0 [CMessage::getHeaderAtIndexFromSipMessage(Timesta        mp, 0)] sip_getHeaderAtIndex FAILED => HSS ERROR No exist
Mon Oct 10 11:17:36 2016 CEDC9 [CResponse::create] Initialize context (Local = T        o & Remote = From)
Mon Oct 10 11:17:36 2016 CEDC9 [CMessage::send] sip_sendMessage (192.168.X.X:50        60)
Mon Oct 10 11:17:36 2016 SEND MESSAGE TO NETWORK (192.168.X.X:5060 [UDP]) (BUFF        LEN = 286)
SIP/2.0 100 Trying
CSeq: 102 INVITE
Content-Length: 0
1476091056 -> Mon Oct 10 11:17:36 2016 [sip_freeEventContext]
Mon Oct 10 11:17:36 2016 1526 [CDialog::receiveInviteRequest]  a new Server INVI        TE transaction is in progress
Mon Oct 10 11:17:36 2016 [CSessionTimerContext::CSessionTimerContext] New CSessi        onTimerContext from request (Server, UA)
Mon Oct 10 11:17:36 2016 [CSessionTimerContext::updateAfterRefreshReception] Upd        ate CSessionTimerContext (refresh reception)
Mon Oct 10 11:17:36 2016 [CSessionTimerContext::updateSupported] Request timer s        upported
Mon Oct 10 11:17:36 2016 [CSessionTimerContext::updateMinSE] Min-SE updated : 30        0
Mon Oct 10 11:17:36 2016 [CSessionTimerContext::updateSessionExpires] Session-Ex        pires updated : 1800
Mon Oct 10 11:17:36 2016 [CSessionTimerContext::setRefreshMethod] Allow refreshM        ethod=INVITE
Mon Oct 10 11:17:36 2016 1526 [CDialog::addTransaction] added transaction 21d6 w        ith branch z9hG4bK5ddfda31, with CSeq 102
Mon Oct 10 11:17:36 2016 1125 [CCall::checkAuthentication] INVITE
Mon Oct 10 11:17:36 2016 B26F0 [CMessage::getAssertedIdCount] need to create the        wrapper
Mon Oct 10 11:17:36 2016 B26F0 [CMessage::createAssertedIdWrapperFromMessage]
Mon Oct 10 11:17:36 2016 B26F0 [CMessage::createAssertedIdWrapperFromMessage] th        ere is 0 P-Asserted-Identity header in the message
Mon Oct 10 11:17:36 2016 B26F0 [CMessage::getPreferredIdCount] need to create th        e wrapper
Mon Oct 10 11:17:36 2016 B26F0 [CMessage::createPreferredIdWrapperFromMessage] t        here is 0 P-Preferred-Identity header in the message
Mon Oct 10 11:17:36 2016 [CGwMngData::isAuthenticationRequiredForThisClient] 192        .168.2.16 .
1476091056 -> Mon Oct 10 11:17:36 2016 isDomainFromGwExt  SCSWorking: NO
Mon Oct 10 11:17:36 2016 [isDomainFromGwExt] Host from request is : 192.168.X.X        .
Mon Oct 10 11:17:36 2016 [isDomainFromGwExt] User from request is : 2373
Mon Oct 10 11:17:36 2016 isDomainFromGwExt--> For Non-PCS case GwExt=7
Mon Oct 10 11:17:36 2016 domain from External Gateway 7.
Mon Oct 10 11:17:36 2016 87d0 [CSipAddrSpec::getAddrSpecAsString]
Mon Oct 10 11:17:36 2016 87d1 [CSipAddrSpec::getAddrSpecAsString]
Mon Oct 10 11:17:36 2016 87d4 [CSipAddrSpec::getAddrSpecAsString]
Mon Oct 10 11:17:36 2016 1125[CMotorCall::setFilterUsedMode] To be traced = 0
Mon Oct 10 11:17:36 2016 1125[CMotorCall::initOfUserType] values are reseted
Mon Oct 10 11:17:36 2016 [getFromHeader] displayName="BRYAN".
Mon Oct 10 11:17:36 2016 [getFromHeader] =2373@192.168.X.X.
Mon Oct 10 11:17:36 2016 [getFromHeader] clirPresent=0.
Mon Oct 10 11:17:36 2016 [isAddrInDico] user=2373 host=192.168.X.X
Mon Oct 10 11:17:36 2016 [isUserInDico] 2373@192.168.X.X
Mon Oct 10 11:17:36 2016 isUserInDico] NOT found in the dictionnary.
Mon Oct 10 11:17:36 2016 [isAddrInDico] other sip user
Mon Oct 10 11:17:36 2016 1125[CMotorCall::getUserType] extGw = 7.
Mon Oct 10 11:17:36 2016 [isValidGwExt] ext gw 7 is valid
1476091056 -> Mon Oct 10 11:17:36 2016 1125[CMotorCall::toGatewayOrProxy] reques        t for proxydomain=192.168.XXX.XXX.
Mon Oct 10 11:17:36 2016 1125[CMotorCall ABCF ExtGW
Mon Oct 10 11:17:36 2016 [isUserRegistred] getRegistration=2621.
Mon Oct 10 11:17:36 2016 [isUserRegistred] result=-1.
Mon Oct 10 11:17:36 2016 [isAddrInDico] user=2621 host=192.168.XXX.XXX
Mon Oct 10 11:17:36 2016 [isUserInDico] 2621@192.168.XXX.XXX
Mon Oct 10 11:17:36 2016 1125[CMotorCall::storeRequestInCall] inRequest storage=        0x853d5e8.
Mon Oct 10 11:17:36 2016 1125[CMotorCall::onReceiveRequest] request for gateway.
Mon Oct 10 11:17:36 2016 1125[CMotorCall::onReceiveRequest] state = INITIAL_STAT        E.
Mon Oct 10 11:17:36 2016 1125[CMotorCall::methodInviteReceived] nb available lic        enses=74 .
Mon Oct 10 11:17:36 2016 1125[CMotorCall::methodInviteReceived] license OK.
Mon Oct 10 11:17:36 2016 3517 [CSipContextID::isValid] Call-ID is not valid
Mon Oct 10 11:17:36 2016 1125[CMotorCall::compareDialogFromContext] presumed to        be the same Dialog
Mon Oct 10 11:17:36 2016 1125[CMotorCall::methodInviteReceived] Invite => update        the inviteContext.
Mon Oct 10 11:17:36 2016 87dd [CSipAddrSpec::CSipAddrSpec()] Invalid type
1476091056 -> Mon Oct 10 11:17:36 2016 [CForkedBranch::CForkedBranch] context =        0x850db80.
Mon Oct 10 11:17:36 2016 87e0 [CSipAddrSpec::getAddrSpecAsString]
Mon Oct 10 11:17:36 2016 1125[CMotorCall::methodInviteReceived] reqUri stored: s        ip:2373@192.168.X.X:5060
Mon Oct 10 11:17:36 2016 1125[CMotorCall::methodInviteReceived] cacUsed = 0 befo        re.
Mon Oct 10 11:17:36 2016 1125[CMotorCall::methodInviteReceived] returnStat = 0 b        efore.
Mon Oct 10 11:17:36 2016 1125[CMotorCall::methodInviteReceived] cacUsed = 0 afte        r.
Mon Oct 10 11:17:36 2016 1125[CMotorCall::methodInviteReceived] CAC = 0
Mon Oct 10 11:17:36 2016 [receiveInviteMessage] Call: 5b2021067e7722a144d5752d13        ab0305@192.168.X.X:5060 eqt: -1 INITIAL_STATE received a message.
Mon Oct 10 11:17:36 2016 [decodeInviteCLIR].
Mon Oct 10 11:17:36 2016 [receiveInviteMessage] INFO present in Allow header
Mon Oct 10 11:17:36 2016  am_I_PCS SCSWorking : NO
Mon Oct 10 11:17:36 2016  check_extgw_PCSstate EXTGW  is : 7
Mon Oct 10 11:17:36 2016  The check_extgw_PCSstate extgwid : 7
Mon Oct 10 11:17:36 2016  The state of PCS which rescued the extgw is : -1
Mon Oct 10 11:17:36 2016 [decodeInviteFromUsingPAI]. octet3a_scrn = 1
Mon Oct 10 11:17:36 2016 1125[CMotorCall::analyseSessionTimer] exit with  uacGat        ewayMode=0 uacRefresher=0.
1476091056 -> Mon Oct 10 11:17:36 2016 [CSipMediaDescription::parseFormatString]        Got 5 format(s) from string 8 0 18 4 101
Mon Oct 10 11:17:36 2016 [checkSdpValidity] Media 0 type 1 contains 5 formats.
Mon Oct 10 11:17:36 2016 [checkSdpValidity] Format : 8.
Mon Oct 10 11:17:36 2016 1125[CMotorCall::isCryptoAuthorized] config crypto=0/0.
Mon Oct 10 11:17:36 2016 [convertSdpIntoTsdp] No Direction in the session part.
Mon Oct 10 11:17:36 2016 [convertSdpIntoTsdp] Check the direction in Session par        t - result:0.
Mon Oct 10 11:17:36 2016 [convertSdpIntoTsdp] media AUDIO detected (previous cry        pto=0).
Mon Oct 10 11:17:36 2016 [convertAudioMedia] The audio media contains  5 format(        s).
Mon Oct 10 11:17:36 2016 [convertAudioMedia] Format 0 is 8.
Mon Oct 10 11:17:36 2016 [convertAudioMedia] Format 1 is 0.
Mon Oct 10 11:17:36 2016 [convertAudioMedia] Format 2 is 18.
Mon Oct 10 11:17:36 2016 [convertAudioMedia] Format 3 is 4.
Mon Oct 10 11:17:36 2016 [convertAudioMedia] Format 4 is 101.
Mon Oct 10 11:17:36 2016 [convertAudioMedia] 101.
Mon Oct 10 11:17:36 2016 [convertAudioMedia] Format is DTMF:101.
Mon Oct 10 11:17:36 2016 [convertAudioMedia] Direction is sendrecv.
Mon Oct 10 11:17:36 2016 [convertAudioMedia] Connection address retrieved in sdp        : 192.168.X.X.
Mon Oct 10 11:17:36 2016 [convertIPStrIntoTuipv] 192.168.X.X => 192.168.X.X
Mon Oct 10 11:17:36 2016 [display_sdp] address =192.168.X.X
Mon Oct 10 11:17:36 2016 [display_sdp] direction=0.
Mon Oct 10 11:17:36 2016 [convertSdpIntoTsdp] only one media taken into account        xxx crypto_index=0 clear media=1
1476091056 -> Mon Oct 10 11:17:36 2016 [convertSdpIntoTsdp] crypto_index=0 clear        media=1.
Mon Oct 10 11:17:36 2016 [receiveInviteMessage] NO  100rel REQUIRED for this cal        l.
Mon Oct 10 11:17:36 2016 [CInitialState::receiveinvitemessage allow_update 0 pra        ck_required 0
Mon Oct 10 11:17:36 2016 [decodeInviteTo].
Mon Oct 10 11:17:36 2016 [decodeInviteReferredBy].
Mon Oct 10 11:17:36 2016 [decodeInviteACSBU].
Mon Oct 10 11:17:36 2016 1125[emitEventToMonitel] content size (lginfo): 660 cca        l crypted= 0
Mon Oct 10 11:17:36 2016 ** SIP TRUNKING **
Mon Oct 10 11:17:36 2016 [ipc_thread] IPC Thread : Ipc reception 30139.
Mon Oct 10 11:17:36 2016 [ipc_thread] IPC Thread : TCL thread signaled.
Mon Oct 10 11:17:36 2016 [CMotorCallManager::insertCallwithEqt] CMotorCall 3525        inserted.
Mon Oct 10 11:17:36 2016 1125[sendLgEvtSipCreate] Event sent on eqt : 3525
Mon Oct 10 11:17:36 2016 [display_ipc_out] ------------ Begin ---------------
1476091056 -> Mon Oct 10 11:17:36 2016 Id : -1
Mon Oct 10 11:17:36 2016 INVITE
Mon Oct 10 11:17:36 2016 REQUEST URI : <> 2621@192.168.XXX.XXX:5060 ; user=phone
Mon Oct 10 11:17:36 2016 FROM : <BRYAN> 2373@192.168.X.X:5060 ; user=nam        e
Mon Oct 10 11:17:36 2016 TO : <> 2621@192.168.XXX.XXX:5060 ; user=phone
Mon Oct 10 11:17:36 2016 CAC : 0
Mon Oct 10 11:17:36 2016   CAC ADDRESS :
Mon Oct 10 11:17:36 2016 CAC-CSBU info : UNKNOWN
Mon Oct 10 11:17:36 2016 CLIR : 0
Mon Oct 10 11:17:36 2016 Prack Required : 0
Mon Oct 10 11:17:36 2016 Allow Update : 0
Mon Oct 10 11:17:36 2016 SDP :
Mon Oct 10 11:17:36 2016   ADDRESS : 192.168.X.X :11270
Mon Oct 10 11:17:36 2016   ALGOS :
Mon Oct 10 11:17:36 2016     PCMA
Mon Oct 10 11:17:36 2016     G729
Mon Oct 10 11:17:36 2016     G723
Mon Oct 10 11:17:36 2016     101
Mon Oct 10 11:17:36 2016   DIRECTION : SEND & RECEIVE
Mon Oct 10 11:17:36 2016   crypto index : 0
Mon Oct 10 11:17:36 2016        N_GW_EXT : 7
Mon Oct 10 11:17:36 2016 [display_ipc_out] ------------- End ----------------
Mon Oct 10 11:17:36 2016 1125[CMotorCall::setCurrentState] NOE-SIP : sendBackupU        pdate Msg not sent to twin CS
Mon Oct 10 11:17:36 2016 [exec_ipc] in 30138.
Mon Oct 10 11:17:36 2016 [display_ipc_in] ------------ Begin ---------------
Mon Oct 10 11:17:36 2016 neqt : 3525 Id : -1
Mon Oct 10 11:17:36 2016 INFORMATIONAL
Mon Oct 10 11:17:36 2016 xx :       80
Mon Oct 10 11:17:36 2016        RELATIVE REQUEST : INVITE
Mon Oct 10 11:17:36 2016 [display_ipc_in] ------------- End ----------------
Mon Oct 10 11:17:36 2016 [CMotorCallManager::onIncomingEvent] an event 10764 arr        ived on the eqt 3525 -1.
1476091056 -> Mon Oct 10 11:17:36 2016 [CMotorCallManager::onIncomingEvent] stat        e = PROCEEDING_STATE.
Mon Oct 10 11:17:36 2016 [onIncomingEvent] INFORMATIONAL arrived.
Mon Oct 10 11:17:36 2016 [receiveInformationalEvent] Call: 5b2021067e7722a144d57        52d13ab0305@192.168.X.X:5060 eqt: 3525 PROCEEDING_STATE received an event.
Mon Oct 10 11:17:36 2016 1125[CMotorCall::isTLSProtRequiredForExtGw] =0.
Mon Oct 10 11:17:36 2016 87e5 [CSipAddrSpec::getAddrSpecAsString]
Mon Oct 10 11:17:36 2016 1125[CMotorCall::buildContact]  Contact: sip:192.168.20        0.1
Mon Oct 10 11:17:36 2016    0[CMotorCall::emitInformationMessage] cause=-1073745        788
Mon Oct 10 11:17:36 2016 1125 [CCall::makeGenericResponse] 180
Mon Oct 10 11:17:36 2016 1125 [CCall::getDialog] Returning Initial Dialog Server
Mon Oct 10 11:17:36 2016 1526 [CDialog::createResponse] 180
Mon Oct 10 11:17:36 2016 CEDCA [CResponse::CResponse] Creation of a response
Mon Oct 10 11:17:36 2016 21d6 [CTransProceedingState::createResponse] CResponse        CEDCA ref=1
Mon Oct 10 11:17:36 2016 CEDCA [CResponse::create] RESPONSE CREATION
1476091056 -> Mon Oct 10 11:17:36 2016 CEDCA [CResponse::checkStatusLine] Create        StatusLine from code given as parameter
Mon Oct 10 11:17:36 2016 CEDCA [CResponse::createToHeader] Initialize To TAG fro        m context
Mon Oct 10 11:17:36 2016 CEDCA [CResponse::createToHeader] Creation a tag for To        header
Mon Oct 10 11:17:36 2016 CEDCA [CResponse::createViaHeaders] Copy Via headers fr        om previous request (number : 1)
Mon Oct 10 11:17:36 2016 CEDCA [CResponse::create] Initialize context (Local = T        o & Remote = From)
Mon Oct 10 11:17:36 2016 CEDCA [CMessage::send] sip_sendMessage (192.168.X.X:50        60)
Mon Oct 10 11:17:36 2016 SEND MESSAGE TO NETWORK (192.168.X.X:5060 [UDP]) (BUFF        LEN = 485)
SIP/2.0 180 Ringing
Allow: INVITE, ACK, CANCEL, BYE, PRACK, NOTIFY, REFER, SUBSCRIBE, OPTIONS, UPDAT        E
Contact: sip:192.168.XXX.XXX
To: <sip:2621@192.168.XXX.XXX:5060;user=phone>;tag=6eef3fcb72f467410d070f15a8fc641        7
CSeq: 102 INVITE
Content-Length: 0
Mon Oct 10 11:17:36 2016 CEDC9 [~CResponse] resp(100) 5b2021067e7722a144d5752d13        ab0305@192.168.X.X:5060 102 INVITE
Mon Oct 10 11:17:36 2016 1526 [CDialog::updateRouteSet] there are 0 record-route        headers
1476091057 -> is_my_node_in_campus false
1476091058 -> Mon Oct 10 11:17:36 2016 [exec_ipc] in end 30138.
Mon Oct 10 11:17:38 2016 RECEIVE MESSAGE FROM NETWORK (10.255.254.74:5060 [UDP])
SIP/2.0 180 Ringing
To: <sip:0623840537@10.255.254.74;user=phone>;tag=SD0tipb99-SD8a2f099-00770420-0        003-0e5b-0000-0000
From: "ACCUEIL 2 MARS" <sip:224848@192.168.XXX.XXX;user=phone>;tag=d8ff1b4b2dc9b1a        c7517cdf21989d938
Call-ID: 6f38fa52e2a0af8c76243d2803114b47@192.168.XXX.XXX
CSeq: 1937285326 INVITE
Via: SIP/2.0/UDP 192.168.XXX.XXX;branch=z9hG4bK45fcd6c0129c86f4345d32bdff2d8982
Accept: application/sdp,application/isup,application/xml
Allow: INVITE,ACK,PRACK,CANCEL,BYE,NOTIFY,UPDATE,INFO,OPTIONS
Contact: <sip:10.255.254.74:5060;transport=udp>
Content-Length: 247
v=0
o=- 567627016 0 IN IP4 10.255.254.74
s=-
c=IN IP4 10.255.254.74
t=0 0
m=audio 12792 RTP/AVP 8 101
a=fmtp:101 0-15
a=sendrecv
a=ptime:20
a=sqn:0
a=cdsc: 1 audio RTP/AVP 8
a=cdsc: 2 image udptl t38
Mon Oct 10 11:17:38 2016 CEDCB [CResponse::CResponse] Creation of a response (RE        CEIVED FROM NETWORK)
Mon Oct 10 11:17:38 2016 [CIOCom::receiveResponse] CResponse CEDCB ref=1
Mon Oct 10 11:17:38 2016 [CDispatcher::processResponseFromManagerIndex] start at        index 0
Mon Oct 10 11:17:38 2016  102 [CCallManager::onIncomingResponse]
Mon Oct 10 11:17:38 2016 1123 [CCall::receiveResponse] 180
Mon Oct 10 11:17:38 2016 1123 [CCall::getDialog] Confirmed Dialog is not found (        ID = d8ff1b4b2dc9b1ac7517cdf21989d938;SD0tipb99-SD8a2f099-00770420-0003-0e5b-000        0-0000)
1476091058 -> Mon Oct 10 11:17:38 2016 1123 [CCall::getDialog] Returning Initial        Dialog Client
Mon Oct 10 11:17:38 2016 1524 [CDialog::receiveResponse]
Mon Oct 10 11:17:38 2016 CEDC5 [~CResponse] resp(100) 6f38fa52e2a0af8c76243d2803        114b47@192.168.XXX.XXX 1937285326 INVITE
Mon Oct 10 11:17:38 2016 1524 [CDialog::updateRouteSet] there are 0 record-route        headers
Mon Oct 10 11:17:38 2016 1123[CMotorCall::searchForkedBranch]pForkedBranch=0x855        c340.
Mon Oct 10 11:17:38 2016 [receiveInformationalMessage] Call: 6f38fa52e2a0af8c762        43d2803114b47@192.168.XXX.XXX eqt: 3210 PROCEEDING_STATE received a message.
Mon Oct 10 11:17:38 2016 CEDCB [CMessage::getAssertedIdCount] need to create the        wrapper
Mon Oct 10 11:17:38 2016 CEDCB [CMessage::createAssertedIdWrapperFromMessage]
Mon Oct 10 11:17:38 2016 CEDCB [CMessage::createAssertedIdWrapperFromMessage] th        ere is 0 P-Asserted-Identity header in the message
Mon Oct 10 11:17:38 2016 CEDCB [CMessage::getPreferredIdCount] need to create th        e wrapper
Mon Oct 10 11:17:38 2016 CEDCB [CMessage::createPreferredIdWrapperFromMessage] t        here is 0 P-Preferred-Identity header in the message
Mon Oct 10 11:17:38 2016 [receiveInformationalMessage] is in the first IF of SDP        present
Mon Oct 10 11:17:38 2016 [CSipMediaDescription::parseFormatString] Got 2 format(        s) from string 8 101
Mon Oct 10 11:17:38 2016 [checkSdpValidity] Media 0 type 1 contains 2 formats.
Mon Oct 10 11:17:38 2016 [checkSdpValidity] Format : 8.
Mon Oct 10 11:17:38 2016 [receiveInformationalMessage] is in the else part of SD        P present
1476091058 -> Mon Oct 10 11:17:38 2016 1123[CMotorCall::isCryptoAuthorized] conf        ig crypto=0/0.
Mon Oct 10 11:17:38 2016 [convertSdpIntoTsdp] No Direction in the session part.
Mon Oct 10 11:17:38 2016 [convertSdpIntoTsdp] Check the direction in Session par        t - result:0.
Mon Oct 10 11:17:38 2016 [convertSdpIntoTsdp] media AUDIO detected (previous cry        pto=0).
Mon Oct 10 11:17:38 2016 [convertAudioMedia] The audio media contains  2 format(        s).
Mon Oct 10 11:17:38 2016 [convertAudioMedia] Format 0 is 8.
Mon Oct 10 11:17:38 2016 [convertAudioMedia] Format 1 is 101.
Mon Oct 10 11:17:38 2016 [convertAudioMedia] 101.
Mon Oct 10 11:17:38 2016 [convertAudioMedia] Format is DTMF:101.
Mon Oct 10 11:17:38 2016 [convertAudioMedia] Direction is sendrecv.
Mon Oct 10 11:17:38 2016 [convertAudioMedia] Connection address retrieved in sdp        : 10.255.254.74.
Mon Oct 10 11:17:38 2016 [convertIPStrIntoTuipv] 10.255.254.74 => 10.255.254.74
Mon Oct 10 11:17:38 2016 [display_sdp] address =10.255.254.74
Mon Oct 10 11:17:38 2016 [display_sdp] direction=0.
Mon Oct 10 11:17:38 2016 [convertSdpIntoTsdp] only one media taken into account        xxx crypto_index=0 clear media=1
Mon Oct 10 11:17:38 2016 [convertSdpIntoTsdp] crypto_index=0 clear media=1.
Mon Oct 10 11:17:38 2016 [methodAllowedByDistant] INFO allowed by distant.
Mon Oct 10 11:17:38 2016 1123[emitEventToMonitel] content size (lginfo): 660 cca        l crypted= 0
Mon Oct 10 11:17:38 2016 1123[emitEventToMonitel]1 T38 REINVITE TRUE
Mon Oct 10 11:17:38 2016 1123[emitEventToMonitel] CAC = 0 eqtCAC = -1
1476091058 ->  main.trace.timer = 480mn
1476091059 -> Mon Oct 10 11:17:38 2016 1123[emitEventToMonitel] cacUsed=0 eqtCac        =-1
Mon Oct 10 11:17:38 2016 1123[emitEventToMonitel] displayIPCMessageOut
Mon Oct 10 11:17:38 2016 [isValidGwExt] ext gw 2 is valid
Mon Oct 10 11:17:38 2016 ** SIP TRUNKING **
Mon Oct 10 11:17:38 2016 [sendLgEvtSip] Event sent on eqt : 3210 Id :-1
Mon Oct 10 11:17:38 2016 [display_ipc_out] ------------ Begin ---------------
Mon Oct 10 11:17:38 2016 Id : -1
Mon Oct 10 11:17:38 2016 INFORMATIONAL
Mon Oct 10 11:17:38 2016 xx :       80
Mon Oct 10 11:17:38 2016        RELATIVE REQUEST : INVITE
Mon Oct 10 11:17:38 2016 Allow Update : 0
Mon Oct 10 11:17:38 2016 SDP :
Mon Oct 10 11:17:38 2016   ADDRESS : 10.255.254.74 :12792
Mon Oct 10 11:17:38 2016   ALGOS :
Mon Oct 10 11:17:38 2016     PCMA
Mon Oct 10 11:17:38 2016     101
Mon Oct 10 11:17:38 2016   DIRECTION : SEND & RECEIVE
Mon Oct 10 11:17:38 2016   crypto index : 0
Mon Oct 10 11:17:38 2016 [display_ipc_out] ------------- End ----------------
Mon Oct 10 11:17:39 2016 [ipc_thread] IPC Thread : Ipc reception 30139.
Mon Oct 10 11:17:39 2016 [ipc_thread] IPC Thread : TCL thread signaled.
Mon Oct 10 11:17:39 2016 [exec_ipc] in 30138.
Mon Oct 10 11:17:39 2016 [display_ipc_in] ------------ Begin ---------------
Mon Oct 10 11:17:39 2016 neqt : 3525 Id : -1
Mon Oct 10 11:17:39 2016 SUCCESSFUL
Mon Oct 10 11:17:39 2016 xx :        0
Mon Oct 10 11:17:39 2016        RELATIVE REQUEST : INVITE
1476091059 -> Mon Oct 10 11:17:39 2016 CLIR : 0
Mon Oct 10 11:17:39 2016 COLP : 1
Mon Oct 10 11:17:39 2016 CAC-CSBU info : UNKNOWN
Mon Oct 10 11:17:39 2016 SDP :
Mon Oct 10 11:17:39 2016   ADDRESS : 10.51.255.5 :32612
Mon Oct 10 11:17:39 2016   ALGOS :
Mon Oct 10 11:17:39 2016     PCMA
Mon Oct 10 11:17:39 2016     101
Mon Oct 10 11:17:39 2016   DIRECTION : SEND & RECEIVE
Mon Oct 10 11:17:39 2016   crypto index : 0
Mon Oct 10 11:17:39 2016 [display_ipc_in] ------------- End ----------------
Mon Oct 10 11:17:39 2016 [CMotorCallManager::onIncomingEvent] an event 10765 arr        ived on the eqt 3525 -1.
Mon Oct 10 11:17:39 2016 [CMotorCallManager::onIncomingEvent] state = PROCEEDING        _STATE.
Mon Oct 10 11:17:39 2016 [onIncomingEvent] SUCCESSFUL arrived.
Mon Oct 10 11:17:39 2016 [onIncomingEvent] relative_request = 10752
Mon Oct 10 11:17:39 2016 [CProceedingState::receiveSuccessfulEvent] Call: 5b2021        067e7722a144d5752d13ab0305@192.168.X.X:5060 eqt: 3525 PROCEEDING_STATE received        an event.
Mon Oct 10 11:17:39 2016 [quoteString] => " Bryan"
Mon Oct 10 11:17:39 2016 1125[CMotorCall::isCryptoAuthorized] config crypto=0/0.
Mon Oct 10 11:17:39 2016 [isValidGwExt] ext gw 7 is valid
Mon Oct 10 11:17:39 2016 1125[CMotorCall::isTLSProtRequiredForExtGw] =0.
Mon Oct 10 11:17:39 2016 87fa [CSipAddrSpec::getAddrSpecAsString]
Mon Oct 10 11:17:39 2016 1125[CMotorCall::emitSuccessfulMessage] P-Asserted-Iden        tity: " Bryan" <sip:2621@192.168.XXX.XXX;user=phone>
1476091059 -> Mon Oct 10 11:17:39 2016 1125[CMotorCall ABCF ExtGW
Mon Oct 10 11:17:39 2016 1125[CMotorCall::emitSuccessfullMessage] uacGatewayMode        =0 uacRefresher=0.
Mon Oct 10 11:17:39 2016 1125[CMotorCall::makeResponseSdp] Audio media.
Mon Oct 10 11:17:39 2016 1125[CMotorCall::appendAudioAttributToMedia] Direction:        0.
Mon Oct 10 11:17:39 2016 1125[CMotorCall::appendAudioAttributToMedia] format 101
Mon Oct 10 11:17:39 2016 1125[CMotorCall::makeResponseSdp] fromSdp.getMediaDesci        prionCount :1
Mon Oct 10 11:17:39 2016 [CSipMediaDescription::parseFormatString] Got 5 format(        s) from string 8 0 18 4 101
Mon Oct 10 11:17:39 2016 [sameCodec] accepted Format : 8.
Mon Oct 10 11:17:39 2016 [sameCodec] requested Format : 8.
Mon Oct 10 11:17:39 2016 [sameCodec] same Format.
Mon Oct 10 11:17:39 2016 [CSipMediaDescription::parseFormatString] Got 2 format(        s) from string 8 101
Mon Oct 10 11:17:39 2016 1125[CMotorCall::mediaAccepted] Media accepted: m=audio        32612 RTP/AVP 8 101
a=sendrecv
a=rtpmap:8 PCMA/8000
a=ptime:20
a=maxptime:30
a=rtpmap:101 telephone-event/8000
Mon Oct 10 11:17:39 2016 1125[CMotorCall::makeResponseSdp] no crypto line, media        accepted=0.
Mon Oct 10 11:17:39 2016 1125[CMotorCall::makeResponseSdp] Final Sdp.
Mon Oct 10 11:17:39 2016 1125[CMotorCall::emitSuccesfulMessage] Answer sdp.
Mon Oct 10 11:17:39 2016 [removeAudioMediaPortNull] media no=0.
Mon Oct 10 11:17:39 2016 1125 [CCall::makeGenericResponse] 200
1476091059 -> Mon Oct 10 11:17:39 2016 1125 [CCall::getDialog] Confirmed Dialog        is not found (ID = 6eef3fcb72f467410d070f15a8fc6417;as434494ea)
Mon Oct 10 11:17:39 2016 1125 [CCall::getDialog] Returning Initial Dialog Server
Mon Oct 10 11:17:39 2016 1526 [CDialog::createResponse] 200
Mon Oct 10 11:17:39 2016 1526 [CDialog::createResponse] create a CONFIRMED dialo        g
Mon Oct 10 11:17:39 2016 B26F0 [CMessage::getMyViaHeader] From index is out of b        ound
Mon Oct 10 11:17:39 2016 1527 [CDialog::CDialog] look for the transaction #0, tr        ansaction key = z9hG4bK5ddfda31
Mon Oct 10 11:17:39 2016 1527 [CDialog::CDialog] copy the transaction #0, transa        ction key = z9hG4bK5ddfda31
Mon Oct 10 11:17:39 2016 21d7 [CTransaction::CTransaction] Transaction is cloned        in 4 state
Mon Oct 10 11:17:39 2016 1527 [CDialog::addTransaction] added transaction 21d7 w        ith branch z9hG4bK5ddfda31, with CSeq 102
Mon Oct 10 11:17:39 2016 1527 [CDialog::startDialogTTL]
Mon Oct 10 11:17:39 2016 1527 [CDialog::createResponse] 200
Mon Oct 10 11:17:39 2016 CEDCC [CResponse::CResponse] Creation of a response
Mon Oct 10 11:17:39 2016 21d7 [CTransProceedingState::createResponse] CResponse        CEDCC ref=1
Mon Oct 10 11:17:39 2016 CEDCC [CResponse::create] RESPONSE CREATION
Mon Oct 10 11:17:39 2016 87fb [CSipAddrSpec::getAddrSpecAsString]
Mon Oct 10 11:17:39 2016 618C [CHeadersService::applyToMessage] P-Asserted-Ident        ity header = P-Asserted-Identity: " Bryan" <sip:2621@192.168.XXX.XXX;user=ph        one>
Mon Oct 10 11:17:39 2016 CEDCC [CMessage::getHeaderAtIndexFromSipMessage(Content        -Type, 0)] sip_getHeaderAtIndex FAILED => HSS ERROR No exist
1476091059 -> Mon Oct 10 11:17:39 2016 CEDCC [CResponse::checkStatusLine] Create        StatusLine from code given as parameter
Mon Oct 10 11:17:39 2016 CEDCC [CResponse::createToHeader] Initialize To TAG fro        m context
Mon Oct 10 11:17:39 2016 CEDCC [CResponse::createViaHeaders] Copy Via headers fr        om previous request (number : 1)
Mon Oct 10 11:17:39 2016 CEDCC [CResponse::create] Initialize context (Local = T        o & Remote = From)
Mon Oct 10 11:17:39 2016 CEDCC [CMessage::send] sip_sendMessage (192.168.X.X:50        60)
Mon Oct 10 11:17:39 2016 SEND MESSAGE TO NETWORK (192.168.X.X:5060 [UDP]) (BUFF        LEN = 878)
SIP/2.0 200 OK
Supported: replaces,timer,path,100rel
Session-Expires: 1800;refresher=uas
P-Asserted-Identity: " Bryan" <sip:2621@192.168.XXX.XXX;user=phone>
Content-Type: application/sdp
CSeq: 102 INVITE
Content-Length: 216
v=0
o=OXE 1476091056 1476091056 IN IP4 192.168.XXX.XXX
s=abs
c=IN IP4 10.51.255.5
t=0 0
a=sendrecv
a=ptime:20
a=maxptime:30
1476091059 -> Mon Oct 10 11:17:39 2016 [sip_freeEventContext]
Mon Oct 10 11:17:39 2016 21d7 [CTransProceedingState::createResponse] Final : Tr        ansaction changes to Completed state
Mon Oct 10 11:17:39 2016 21d7 [CTransaction::changeState] STATE CHANGED TO COMPL        ETED
Mon Oct 10 11:17:39 2016 21d7 [CTransaction::changeState] notifying the parent d        ialog
Mon Oct 10 11:17:39 2016 1527 [CDialog::onTransactionState(pTrans = 21d7, previo        usState = Proceeding, currentState = Completed, reason = Final resp creation]
Mon Oct 10 11:17:39 2016 21d7 [CTransaction::startTimer] Timer G is started (del        ay = 500 ms)
Mon Oct 10 11:17:39 2016 21d7 [CTransaction::startTimer] Timer H is started (del        ay = 32000 ms)
Mon Oct 10 11:17:39 2016 1527 [CDialog::updateRouteSet] there are 0 record-route        headers
Mon Oct 10 11:17:39 2016 [CSessionTimerContext::CSessionTimerContext] New CSessi        onTimerContext from response (Server, UA)
Mon Oct 10 11:17:39 2016 [CSessionTimerContext::updateAfterRefreshReception] Upd        ate CSessionTimerContext (refresh reception)
Mon Oct 10 11:17:39 2016 [CSessionTimerContext::updateSupported] Request timer s        upported
Mon Oct 10 11:17:39 2016 [CSessionTimerContext::updateMinSE] Min-SE updated : 30        0
Mon Oct 10 11:17:39 2016 [CSessionTimerContext::updateSessionExpires] Session-Ex        pires updated : 1800
Mon Oct 10 11:17:39 2016 [CSessionTimerContext::setRefreshMethod] Allow refreshM        ethod=INVITE
Mon Oct 10 11:17:39 2016 [CSessionTimerContext::updateAfterResponseRefreshCreati        on] Update CSessionTimerContext (response refresh creation)
1476091059 -> Mon Oct 10 11:17:39 2016 [CSessionTimerContext::updateSessionExpir        es] Refresher updated : i
Mon Oct 10 11:17:39 2016 [CSessionTimerContext::startTimers] Start session timer        expiration : 1800000
Mon Oct 10 11:17:39 2016 [CSessionTimerContext::startTimers] Start session timer        will expires : 900000
Mon Oct 10 11:17:39 2016 1125 [CCall::insertInDialogMap] added dialog #1527 with        the key 6eef3fcb72f467410d070f15a8fc6417;as434494ea
Mon Oct 10 11:17:39 2016 1526 [CDialog::updateRouteSet] there are 0 record-route        headers
Mon Oct 10 11:17:39 2016 [CProceedingState::receiveSuccessfulEvent] emitSuccessf        ulMessage OK.
Mon Oct 10 11:17:39 2016 1125[CMotorCall::setCurrentState] NOE-SIP : sendBackupU        pdate Msg not sent to twin CS
Mon Oct 10 11:17:39 2016 [exec_ipc] in end 30138.
Mon Oct 10 11:17:39 2016 RECEIVE MESSAGE FROM NETWORK (192.168.X.X:5060 [UDP])
ACK sip:192.168.XXX.XXX SIP/2.0
Via: SIP/2.0/UDP 192.168.X.X:5060;branch=z9hG4bK38e224e3
Max-Forwards: 70
Contact: <sip:2373@192.168.X.X:5060>
CSeq: 102 ACK
User-Agent: XIVO PBX
Content-Length: 0
Mon Oct 10 11:17:39 2016  [CIOCom::receiveRequest] optimisation value 1
1476091059 -> Mon Oct 10 11:17:39 2016  [CIOCom::IsNoeOptionsMsg] Not in same do        main FAILED => 192.168.XXX.XXX node000000
Mon Oct 10 11:17:39 2016  [CIOCom::IsNoeOptionsMsg] NoeOpt 0
Mon Oct 10 11:17:39 2016 B26F1 [CRequest::CRequest] Creation of a request (RECEI        VED FROM NETWORK)
Mon Oct 10 11:17:39 2016 [CIOCom::receiveRequest] Received CRequest B26F1 ref=1
Mon Oct 10 11:17:39 2016 [CIOCom::receiveRequest] rport1 not empty
Mon Oct 10 11:17:39 2016 [CDispatcher::onIncomingRequest()]
Mon Oct 10 11:17:39 2016 [CDispatcher::processRequestFromManagerIndex()] start a        t index 0
Mon Oct 10 11:17:39 2016  102 [CCallManager::onIncomingRequest()]
Mon Oct 10 11:17:39 2016 1125 [CCall::receiveRequest] ACK
Mon Oct 10 11:17:39 2016 1125 [CCall::getDialog] Confirmed Dialog found
Mon Oct 10 11:17:39 2016 1527 [CDialog::receiveRequest]
Mon Oct 10 11:17:39 2016 1527 [CDialog::receiveAckRequest]
Mon Oct 10 11:17:39 2016 1527 [CDialog::getTransactionByCSeq] CSeq = 102
Mon Oct 10 11:17:39 2016 21d7 [CTransaction::changeState] STATE CHANGED TO TERMI        NATED
Mon Oct 10 11:17:39 2016 21d7 [CTransaction::freeTimerToken] Timer G is freed
Mon Oct 10 11:17:39 2016 21d7 [CTransaction::freeTimerToken] Timer H is freed
Mon Oct 10 11:17:39 2016 21d7 [CTransaction::changeState] no transaction state,        terminated reason : Request reception
Mon Oct 10 11:17:39 2016 1527 [CDialog::receiveAckRequest] the INVITE request is        terminated
Mon Oct 10 11:17:39 2016 1125 [CCall::checkAuthentication] ACK
Mon Oct 10 11:17:39 2016 1125[CMotorCall::controlAuthentication] ---*--- END ---        *--- Control authentication
1476091059 -> Mon Oct 10 11:17:39 2016 1125[CMotorCall::onReceiveRequest] s=0 d=        0 v=0 o=1.
Mon Oct 10 11:17:39 2016 1125[CMotorCall::onReceiveRequest] request for gateway.
Mon Oct 10 11:17:39 2016 1125[CMotorCall::onReceiveRequest] state = ACCEPTED_STA        TE.
Mon Oct 10 11:17:39 2016 1125[CMotorCall::compareDialogFromContext] same Dialog
Mon Oct 10 11:17:39 2016 1125[CMotorCall::methodAckReceived] Ack => update the i        nviteContext.
Mon Oct 10 11:17:39 2016 [receiveAckMessage] Call: 5b2021067e7722a144d5752d13ab0        305@192.168.X.X:5060 eqt: 3525 ACCEPTED_STATE received a message.
Mon Oct 10 11:17:39 2016 [receiveAckMessage] g711u: 255 g711A: 255 g723: 255 g72        9: 255.
Mon Oct 10 11:17:39 2016 1125[emitEventToMonitel] content size (lginfo): 660 cca        l crypted= 0
Mon Oct 10 11:17:39 2016 1125[emitEventToMonitel] CAC = 0 eqtCAC = -1
Mon Oct 10 11:17:39 2016 1125[emitEventToMonitel] cacUsed=0 eqtCac=-1
Mon Oct 10 11:17:39 2016 1125[emitEventToMonitel] displayIPCMessageOut
Mon Oct 10 11:17:39 2016 ** SIP TRUNKING **
Mon Oct 10 11:17:39 2016 [sendLgEvtSip] Event sent on eqt : 3525 Id :-1
Mon Oct 10 11:17:39 2016 [display_ipc_out] ------------ Begin ---------------
Mon Oct 10 11:17:39 2016 Id : -1
Mon Oct 10 11:17:39 2016 ACK
Mon Oct 10 11:17:39 2016 [display_ipc_out] ------------- End ----------------
1476091061 -> Mon Oct 10 11:17:39 2016 B26F1 [~CRequest] req 5b2021067e7722a144d        5752d13ab0305@192.168.X.X:5060 102 ACK
Mon Oct 10 11:17:39 2016 [CTransaction::notifyDialog]
Mon Oct 10 11:17:39 2016 [CTransaction::notifyDialog] notify parent dialog
Mon Oct 10 11:17:39 2016 1527 [CDialog::onTransactionState(pTrans = 21d7, previo        usState = null, currentState = Terminated, reason = Request reception]
Mon Oct 10 11:17:39 2016 21D7 [~CTransaction] transaction 102 INVITE
Mon Oct 10 11:17:41 2016 RECEIVE MESSAGE FROM NETWORK (192.168.X.X:5060 [UDP])
BYE sip:192.168.XXX.XXX SIP/2.0
Via: SIP/2.0/UDP 192.168.X.X:5060;branch=z9hG4bK4a1bdb53
Max-Forwards: 70
CSeq: 103 BYE
X-Asterisk-HangupCause: Normal Clearing
X-Asterisk-HangupCauseCode: 16
Content-Length: 0
Mon Oct 10 11:17:41 2016  [CIOCom::receiveRequest] optimisation value 1
Mon Oct 10 11:17:41 2016  [CIOCom::IsNoeOptionsMsg] Not in same domain FAILED =>        192.168.XXX.XXX node000000
Mon Oct 10 11:17:41 2016  [CIOCom::IsNoeOptionsMsg] NoeOpt 0
Mon Oct 10 11:17:41 2016 B26F2 [CRequest::CRequest] Creation of a request (RECEI        VED FROM NETWORK)
Mon Oct 10 11:17:41 2016 [CIOCom::receiveRequest] Received CRequest B26F2 ref=1
Mon Oct 10 11:17:41 2016 [CIOCom::receiveRequest] rport1 not empty
1476091061 -> Mon Oct 10 11:17:41 2016 [CDispatcher::onIncomingRequest()]
Mon Oct 10 11:17:41 2016 [CDispatcher::processRequestFromManagerIndex()] start a        t index 0
Mon Oct 10 11:17:41 2016  102 [CCallManager::onIncomingRequest()]
Mon Oct 10 11:17:41 2016 1125 [CCall::receiveRequest] BYE
Mon Oct 10 11:17:41 2016 1125 [CCall::getDialog] Confirmed Dialog found
Mon Oct 10 11:17:41 2016 1527 [CDialog::receiveRequest]
Mon Oct 10 11:17:41 2016 1527 [CDialog::receiveBasicRequest]
Mon Oct 10 11:17:41 2016 21d8 [CTransaction::changeState] STATE CHANGED TO INITI        AL
Mon Oct 10 11:17:41 2016 21d8 [CTransaction::changeState] notifying the parent d        ialog
Mon Oct 10 11:17:41 2016 1527 [CDialog::onTransactionState(pTrans = 21d8, previo        usState = Terminated, currentState = Initial, reason = None]
Mon Oct 10 11:17:41 2016 21d8 [CTransInitialState::receiveRequest] Transaction c        hanges to Trying state
Mon Oct 10 11:17:41 2016 21d8 [CTransaction::changeState] STATE CHANGED TO TRYIN        G
Mon Oct 10 11:17:41 2016 1527 [CDialog::onTransactionState(pTrans = 21d8, previo        usState = Initial, currentState = Trying, reason = Request reception]
Mon Oct 10 11:17:41 2016 1527 [CDialog::addTransaction] added transaction 21d8 w        ith branch z9hG4bK4a1bdb53, with CSeq 103
Mon Oct 10 11:17:41 2016 [CSessionTimerContext::~CSessionTimerContext] Free CSes        sionTimerContext
Mon Oct 10 11:17:41 2016 1125 [CCall::checkAuthentication] BYE
Mon Oct 10 11:17:41 2016 1125[CMotorCall::controlAuthentication] ---*--- END ---        *--- Control authentication
1476091061 -> Mon Oct 10 11:17:41 2016 1125[CMotorCall::onReceiveRequest] s=0 d=        0 v=0 o=1.
Mon Oct 10 11:17:41 2016 1125[CMotorCall::onReceiveRequest] request for gateway.
Mon Oct 10 11:17:41 2016 1125[CMotorCall::onReceiveRequest] state = COMPLETED_ST        ATE.
Mon Oct 10 11:17:41 2016 [receiveByeMessage] Call: 5b2021067e7722a144d5752d13ab0        305@192.168.X.X:5060 eqt: 3525 COMPLETED_STATE received a message.
Mon Oct 10 11:17:41 2016 1125[emitEventToMonitel] content size (lginfo): 660 cca        l crypted= 0
Mon Oct 10 11:17:41 2016 1125[emitEventToMonitel] CAC = 0 eqtCAC = -1
Mon Oct 10 11:17:41 2016 1125[emitEventToMonitel] cacUsed=0 eqtCac=-1
Mon Oct 10 11:17:41 2016 1125[emitEventToMonitel] displayIPCMessageOut
Mon Oct 10 11:17:41 2016 [isValidGwExt] ext gw 7 is valid
Mon Oct 10 11:17:41 2016 ** SIP TRUNKING **
Mon Oct 10 11:17:41 2016 [sendLgEvtSip] Event sent on eqt : 3525 Id :-1
Mon Oct 10 11:17:41 2016 [ipc_thread] IPC Thread : Ipc reception 30139.
Mon Oct 10 11:17:41 2016 [ipc_thread] IPC Thread : TCL thread signaled.
Mon Oct 10 11:17:41 2016 [display_ipc_out] ------------ Begin ---------------
Mon Oct 10 11:17:41 2016 Id : -1
Mon Oct 10 11:17:41 2016 BYE
Mon Oct 10 11:17:41 2016 [display_ipc_out] ------------- End ----------------
Mon Oct 10 11:17:41 2016 1125[CMotorCall::setCurrentState] NOE-SIP : sendBackupU        pdate Msg not sent to twin CS
Mon Oct 10 11:17:41 2016 [exec_ipc] in 30138.
1476091061 -> Mon Oct 10 11:17:41 2016 [display_ipc_in] ------------ Begin -----        ----------
Mon Oct 10 11:17:41 2016 neqt : 3525 Id : -1
Mon Oct 10 11:17:41 2016 SUCCESSFUL
Mon Oct 10 11:17:41 2016 xx :        0
Mon Oct 10 11:17:41 2016        RELATIVE REQUEST : BYE
Mon Oct 10 11:17:41 2016 CLIR : 0
Mon Oct 10 11:17:41 2016 COLP : 0
Mon Oct 10 11:17:41 2016 CAC-CSBU info : UNKNOWN
Mon Oct 10 11:17:41 2016 [display_ipc_in] ------------- End ----------------
Mon Oct 10 11:17:41 2016 [CMotorCallManager::onIncomingEvent] an event 10765 arr        ived on the eqt 3525 -1.
Mon Oct 10 11:17:41 2016 [CMotorCallManager::onIncomingEvent] state = TERMINATED        _STATE.
Mon Oct 10 11:17:41 2016 [onIncomingEvent] SUCCESSFUL arrived.
Mon Oct 10 11:17:41 2016 [onIncomingEvent] relative_request = 10755
Mon Oct 10 11:17:41 2016 [receiveSuccessfulEvent] Call: 5b2021067e7722a144d5752d        13ab0305@192.168.X.X:5060 eqt: 3525 TERMINATED_STATE received an event.
Mon Oct 10 11:17:41 2016 1125[CMotorCall ABCF ExtGW
Mon Oct 10 11:17:41 2016 1527 [CCall::findFirstServerTrans]
Mon Oct 10 11:17:41 2016 1527 [CCallLeg::findFirstOpenServerTrans] Current Reque        st in transactionMapByBranch
Mon Oct 10 11:17:41 2016 1125 [CCall::makeGenericResponse] 200
Mon Oct 10 11:17:41 2016 1527 [CDialog::createResponse] 200
1476091061 -> Mon Oct 10 11:17:41 2016 CEDCD [CResponse::CResponse] Creation of        a response
Mon Oct 10 11:17:41 2016 21d8 [CTransTryingState::createResponse] CResponse CEDC        D ref=1
Mon Oct 10 11:17:41 2016 CEDCD [CResponse::create] RESPONSE CREATION
Mon Oct 10 11:17:41 2016 CEDCD [CResponse::checkStatusLine] Create StatusLine fr        om code given as parameter
Mon Oct 10 11:17:41 2016 CEDCD [CResponse::createViaHeaders] Copy Via headers fr        om previous request (number : 1)
Mon Oct 10 11:17:41 2016 CEDCD [CResponse::create] Initialize context (Local = T        o & Remote = From)
Mon Oct 10 11:17:41 2016 CEDCD [CMessage::send] sip_sendMessage (192.168.X.X:50        60)
Mon Oct 10 11:17:41 2016 SEND MESSAGE TO NETWORK (192.168.X.X:5060 [UDP]) (BUFF        LEN = 488)
SIP/2.0 200 OK
User-Agent: OmniPCX Enterprise R10.0 j1.410.49.a
CSeq: 103 BYE
Content-Length: 0
Mon Oct 10 11:17:41 2016 [sip_freeEventContext]
Mon Oct 10 11:17:41 2016 21d8 [CTransTryingState::createResponse] Final : Transa        ction changes to Completed state
Mon Oct 10 11:17:41 2016 21d8 [CTransaction::changeState] STATE CHANGED TO COMPL        ETED
1476091061 -> Mon Oct 10 11:17:41 2016 21d8 [CTransaction::changeState] notifyin        g the parent dialog
Mon Oct 10 11:17:41 2016 1527 [CDialog::onTransactionState(pTrans = 21d8, previo        usState = Trying, currentState = Completed, reason = Final resp creation]
Mon Oct 10 11:17:41 2016 21d8 [CTransaction::startTimer] Timer J is started (del        ay = 32000 ms)
Mon Oct 10 11:17:41 2016 1527 [CDialog::updateRouteSet] there are 0 record-route        headers
Mon Oct 10 11:17:41 2016 [exec_ipc] in end 30138.
Mon Oct 10 11:17:41 2016 [display_ipc_in] ------------ Begin ---------------
Mon Oct 10 11:17:41 2016 SIP EQT RELEASED
Mon Oct 10 11:17:41 2016 [CMotorCallManager::onIncomingEvent] an event 10773 arr        ived on the eqt 3525 -1.
Mon Oct 10 11:17:41 2016 [CMotorCallManager::onIncomingEvent] The call with eqt:        3525 has released its equipment.
Mon Oct 10 11:17:41 2016 1125[CMotorCall::emitSipEqtReleaseAck] SIP_EQT_RELEASE_        ACK
Mon Oct 10 11:17:41 2016 1125[emitEventToMonitel]1 T38 REINVITE TRUE
1476091061 -> Mon Oct 10 11:17:41 2016 1125[emitEventToMonitel] displayIPCMessag        eOut
Mon Oct 10 11:17:41 2016 SIP_EQT_RELEASE_ACK
Mon Oct 10 11:17:41 2016 1125[CMotorCall::unRegister] Remove eqt : 3525 diag : -        1 from the map.
Mon Oct 10 11:17:41 2016 [CMotorCallManager::eraseCallwithEqt] erase 3525 -1.
Mon Oct 10 11:17:41 2016 [CMotorCallManager::onIncomingEvent] killSession.
Mon Oct 10 11:17:41 2016 1125 [CCall::killSession]
Mon Oct 10 11:17:41 2016 21d6 [CTransaction::changeState] STATE CHANGED TO TERMI        NATED
Mon Oct 10 11:17:41 2016 21d6 [CTransaction::changeState] no transaction state,        terminated reason : None
Mon Oct 10 11:17:41 2016 21d8 [CTransaction::changeState] STATE CHANGED TO TERMI        NATED
Mon Oct 10 11:17:41 2016 21d8 [CTransaction::freeTimerToken] Timer J is freed
Mon Oct 10 11:17:41 2016 21d8 [CTransaction::changeState] no transaction state,        terminated reason : None
1476091061 -> Mon Oct 10 11:17:41 2016 1125 [CCall::killSession] notifying the c        all manager
Mon Oct 10 11:17:41 2016  102 [CCallManager::onCallClosed]
Mon Oct 10 11:17:41 2016  102 [CCallManager::onCallClosed()] Call 1125 closed. R        emoving call 139515608 from the maps
Mon Oct 10 11:17:41 2016 [CMotorCallManager::onNotifyCallClosed] Call : 5b202106        7e7722a144d5752d13ab0305@192.168.X.X:5060 is closed.
Mon Oct 10 11:17:41 2016 [CMotorCallManager::onNotifyCallClosed] call processRes        ponse.
Mon Oct 10 11:17:41 2016 1125[CMotorCall::chooseBestResponse] pForkedBranch=0x85        a44c0 iResponseCode=2000.
Mon Oct 10 11:17:41 2016 1125[CMotorCall::chooseBestResponse] next branch.
Mon Oct 10 11:17:41 2016 1125[CMotorCall::processResponse] no response found.
Mon Oct 10 11:17:41 2016 [CMotorCallManager::onNotifyCallClosed] Remove eqt from        the map.
Mon Oct 10 11:17:41 2016 [CTransaction::notifyDialog]
Mon Oct 10 11:17:41 2016 [CTransaction::notifyDialog] notify parent dialog
Mon Oct 10 11:17:41 2016 1526 [CDialog::onTransactionState(pTrans = 21d6, previo        usState = null, currentState = Terminated, reason = None]
Mon Oct 10 11:17:41 2016 1526 [CDialog::onTransactionState] dialog is terminated
Mon Oct 10 11:17:41 2016 1526 [CDialog::onTransactionState] onDialogClosed
Mon Oct 10 11:17:41 2016 1125 [CCall::onDialogClosed]
Mon Oct 10 11:17:41 2016 1125 [CCall::onDialogClosed] not only initial *********
1476091061 -> Mon Oct 10 11:17:41 2016 1125 [CCall::onDialogClosed]: the dialog        1527 is NOT closed
Mon Oct 10 11:17:41 2016 21D6 [~CTransaction] transaction 102 INVITE
Mon Oct 10 11:17:41 2016 CEDCA [~CResponse] resp(180) 5b2021067e7722a144d5752d13        ab0305@192.168.X.X:5060 102 INVITE
Mon Oct 10 11:17:41 2016 1527 [CDialog::onTransactionState(pTrans = 21d8, previo        usState = null, currentState = Terminated, reason = None]
Mon Oct 10 11:17:41 2016 1125 [CCall::onDialogClosed]: the dialog 1527 is closed
Mon Oct 10 11:17:41 2016 1125 [CCall::onDialogClosed] All the dialogs in the Cal        l are closed
Mon Oct 10 11:17:41 2016 21D8 [~CTransaction] transaction 103 BYE
Mon Oct 10 11:17:41 2016  102 [CCallManager::removeGarbage] at index i = 0
Mon Oct 10 11:17:41 2016 1125 [CMotorCall::clear_subscription]  subscription man        aged with key
Mon Oct 10 11:17:41 2016 [CMotorCallManager::eraseSubscription] tyr to erase wit        h key
Mon Oct 10 11:17:41 2016 [CMotorCallManager::eraseSubscription] No call found wi        th key
Mon Oct 10 11:17:41 2016 1125[CMotorCall::~CMotorCall] Call : 5b2021067e7722a144        d5752d13ab0305@192.168.X.X:5060 is being destructed.
Mon Oct 10 11:17:41 2016 1125 [CCall::~CCall]
Mon Oct 10 11:17:41 2016 1125 [CCall::removeGarbage]
Mon Oct 10 11:17:41 2016 1527 [CDialog::~CDialog]
1476091063 -> Mon Oct 10 11:17:41 2016 1526 [CDialog::~CDialog]
Mon Oct 10 11:17:41 2016 CEDCC [~CResponse] resp(200) 5b2021067e7722a144d5752d13        ab0305@192.168.X.X:5060 102 INVITE
Mon Oct 10 11:17:41 2016 B26F0 [~CRequest] req 5b2021067e7722a144d5752d13ab0305@        192.168.X.X:5060 102 INVITE
Mon Oct 10 11:17:41 2016 CEDCD [~CResponse] resp(200) 5b2021067e7722a144d5752d13        ab0305@192.168.X.X:5060 103 BYE
Mon Oct 10 11:17:41 2016 B26F2 [~CRequest] req 5b2021067e7722a144d5752d13ab0305@        192.168.X.X:5060 103 BYE
bwen
Re: trunk SIP OXE-XIVO
Post by bwen »
I have resolved the 073 problem with DEF parameter in Translator > External Numbering Plan > Ext. Callback Translation and displayed name by speed dials
bwen
Post by bwen »
To sum up, now calls are working form asterisk to OXE with displayed names so , I only have two problems yet:
1 - operator calls from asterisk to xivo
2 - setting up calls from OXE to Xivo
Point 1 is not really important, i can call the DID number to join operator but if anyone has a solution, I take it.
For point 2, anyone could tell me the main steps in few words please? Do I need to declare xivo user in OXE or use a prefix to send call to the trunk?
Return to “Asterisk”
