Omni Pcx Office Small issue
atcmatteo
Re: Omni Pcx Office Small issue
Post by atcmatteo »
no way to login...
tried with kilo1997
then installed omc 10.8.1a and renamed expert dll
nothing solved
maxmania
Post by maxmania »
Do you have any "console" phone? Advance reflex, 4039, 4034?
Best Regards
Jose Alves
atcmatteo
Post by atcmatteo »
maxmania wrote:Do you have any "console" phone? Advance reflex, 4039, 4034?
NO! :(
maxmania
Post by maxmania »
Try to find in the OMC help the console cable diagram, to connect vis rs232. I think is the last option you have before you go to Lola software. if you can't find it send me a PM.
Best Regards
Jose Alves
atcmatteo
Post by atcmatteo »
I think the problem is between pc and pcx connection, I've FTP error, logged with wireshark seems doesn't comunicate.
Is possible in windows 7 i miss some ftp protocols?
atcmatteo
Post by atcmatteo »
should be the internal cmos battery the problem??
atcmatteo
Post by atcmatteo »
Finally i've found the problem and now i have acces via FTP to the omnioffice!!!
Now I have a analogic phone line to connect to this Huawei B593s-22
http://support.huawei.com/ecommunity/bbs/10176957.html
but when i connect it the line goes on, like if I'm doing a call
in this way the phone line is always busy and isn't possible to call.
What i can do? There is someting in the PBX setup to fix it or i've to connect the cable line in other way?
I hope is possible to use this configuration betwenn the Huawei router, so I can run all the office with only a gsm simcard inside it and have phone, fax and 4g internet connection
PlanoPCX
Post by PlanoPCX »
This looks like an OxO (not a 4200, it's a bit too recent for that). You should be OK with OMC as long as you check the older versions compatibility box as suggested by 'maxmania' earlier in this thread. What exactly is the error you are getting? Have you a UA/digital card in the system - have you a 4039 phone that you can connect through the first port - there is a limited administration menu available through the phone.
gohar
Post by gohar »
better late than never.... where can I get OMC 10.x please..
rkraehen
Post by rkraehen »
You can get the OMC on the ALE BP portal or via an ALE partner
Return to “Hardware”
