Info Fax Server
Re: Info Fax Server
Hi Cav,any updates?
Re: Info Fax Server
Well I tried another trunk R2 on same environment and have the same results.
So I asked to apply a patch on the OXE which seems to correct some issues about fax and SIP. Will do it this weekend.
If it still fails will have to see how to analyze that sync issue as I have almost no experience with R2 tracing tools.
Thanks for the concern
Re: Info Fax Server
trkstat C c and you will see if there are some errors in the line special sia 64 and los 2m
Re: Info Fax Server
You got me there ;) sia 64? Los 2m?
Re: Info Fax Server
LOS 2M THE 2MB SGNAL IS LOST CLOCKING 2 MB IS LOST
SIA 64K FRAMING AT 64KB(VOICE STAGE) is compromised t far end
can u past the trkstat C c ? have you such as alrm
gossippk10
Re: Info Fax Server
Post by gossippk10 »
I also have this problem. Is anyone using Alcatel products in Dubai or Karachi
EdwardPeterson
Re: Info Fax Server
Post by EdwardPeterson »
I'm going to create a fax server with specfic software to run on it. The software for the fax server does not have to run on a server(as the o.s), it could run on a windows 2000 professional as the o.s. Is there any reason I should install server as the o.s. or would 2000 prof. be sufficient? Just looking for opinions..
Any help would be appreciated...
johnawagner
Re: Info Fax Server
Post by johnawagner »
gossippk10 wrote: 05 May 2018 16:41 I also have this problem. Is anyone using Alcatel products in Dubai or Karachi
I’m facing the same issue—anyone here using Alcatel products in Dubai or Karachi?”
Re: Info Fax Server
You might want to look at this solution: https://www.t38fax.com/solutions/t38-fa ... x-servers/
Return to “OmniTouch 8450 Fax Software”
