R9.H1301.24
Re: R9.H1301.24
Download it from BPWS
root
Re: R9.H1301.24
Post by root »
psyloptik wrote:Good answer my friend very useful
there is no production environmnent on release 9 for the moment but i went back from alcatel university and i took the release and the OPS but i didn't found the PC installer so if someone have it it will be great if you send by e-mail or give me a link where i can download it.
Thanks.
pc-installer should be part the full version
Re: R9.H1301.24
check in folder (if we say about R9) /dhs3mgr/h1301/pcmao/boot_res/pcinstall
psyloptik_DUP
Re: R9.H1301.24
Post by psyloptik_DUP »
thanks i found it it's okay now
i've OPS from Alcatel so all is open but it show me an error because the version of my release is 62.2 and the system wants the version 62.0.
Do you know what it mean ?
kasethur
Re: R9.H1301.24
Post by kasethur »
Hi all i am facing one issue in R.9 h1301.24
when i am try to dial pin dialing its accept the pin number and password but its not dialing any isdn number.
Re: R9.H1301.24
Then check your configuration, has nothing to do that it is VMWare as OXE is already installed and working.
Return to “Other”
