R9.H1301.24
thatawa
R9.H1301.24
Hi everybody,
Just a little post to say the R9 works fine.
Think about desactivating the firewall and everyting is right.
Good luck.
Good luck.
- frank
Re: R9.H1301.24
I found one issue with it for now..
I have 10 DPT1, and 20 trunk groups.
I can create 2 accesses for 2 trunks (no matter if they are on the same board, or different board), then I can't create any new access to other trunks. I need to reboot.
I sent the traces to R&D.
Can you try ? I'm not even sure you need to have the physical connections. Just create in your WMware a shelf, and give it a shot. Thx
root
Re: R9.H1301.24
maybe a problem of the trunk value in the cfgUpdate?frank wrote:I found one issue with it for now..
Eliott_DUP
Re: R9.H1301.24
Check dumpnewtel values.
How many bytes Additional free space you have?
It sounds like a memory allocation problem. (Remanent size)
- frank
Re: R9.H1301.24
Yup,
This was it. My remanent size was at -1 , I did not pay attention.
-1 means that it is not managed , and it takes a value (small) by default.
Once the PCX boot, it manage it to the minimum + some spares.
I could create 2 accesses, then blocked.
Once I reboot, it does again the minimum configured + some spares, which let me create again 2 accesses in those 2 spares...
etc etc etc..
So I changed my remanent to 42000, and it's all good
etc etc etc..
root
Re: R9.H1301.24
that happens if you play in vmware without a real ops which includefrank wrote:Yup,
a hardware.mao to setup good values for trunks, 1/2 com and remanent size
psyloptik_DUP
Re: R9.H1301.24
can you tell me which version of the PC installerdo you use to install the R9 on vmware,
i use the same as the one i use for the R8 but it doesn't work fine and i don't know why.
if you can help me it will be great.
thanks in advance
Jul
thanks in advance
Jul
psyloptik_DUP
Re: R9.H1301.24
Good answer my friend very useful
there is no production environmnent on release 9 for the moment but i went back from alcatel university and i took the release and the OPS but i didn't found the PC installer so if someone have it it will be great if you send by e-mail or give me a link where i can download it.
Thanks.
Thanks.
