Hi..
Okay, this is for VoIP...
But I also have 2 T1 (ABC-F). Once the ABC-F is created, the system does not let me create a new hybrid link.... Also, how can you tell the system to go over the T1's first, and VoIP 2nd ? Because when you use ABC-F, there is no ARS...
Thank you
T1 + VoIP
la_toupie
- frank
hi..
NNooooo, the customer wants the T1's to be taken first.
Have you had your solution running somewhere ?
Because I spoke with Alcatel, and they told me that there is no way that the IP is taken as a backup: If the T1s are down, IP will not work. So if you tried your solution and if it worked, I WANT IT !
gundam
I don't think this is a supported design (VoIP as a backup to the ABC-F).
If this works then the Sales team from Alcatel will have no problem selling the PCX. Imagine if the ABC-F goes down due to a bad DPT1 to Telco, calls automatically goes over the customer’s data network as backup.
Now I do know you can have various signaling backup, but IP is not an option.
la_toupie
