8001 phones are not coming UP
morio
Re: 8001 phones are not coming UP
Post by morio »
i had some issues with 8001. so what i did was i had to use a POE injector. (the POE switch) didnt work. so maybe the power output of the sswitch wasnt enough.
din1s
Post by din1s »
Could you please share the firmware you are using for 8001G phone? We're having the same issues as described here previously, some are stuck without anything on LCD, some with RED LED lights on, and some turns on, but hangs after a while.
nkurunziza
Post by nkurunziza »
Hi din1s,
DId you find any solution? I have the same problem with my 8001 phones
hakuna
Post by hakuna »
There is no solution. POE injector works for a few but otherwise these phones are dead. Alcatel has no solution.
Chao.
oukthr
Post by oukthr »
Hi, I submitted a service request to Alcatel, and they sent me this procedure, it works for 2 of three phones that have this probleme.
ACFE OXO Connect
ACFE OmniPCX Enterprise
hakuna
Post by hakuna »
Already tried this and was able to save one in 50 phones. This doesn't work if kernal is already latest.
kygres
Post by kygres »
oukthr can you upload the kernel and application file please
Malih
Post by Malih »
oukthr wrote: 21 Aug 2022 04:10 Hi, I submitted a service request to Alcatel, and they sent me this procedure, it works for 2 of three phones that have this probleme.
Can you send pdf in my email
malihesm3@gmail.com
Aeroflock
Post by Aeroflock »
Can you share me the kernel and application ?
adrinraha
Post by adrinraha »
Ehsanabooali1985@gmail.com
Return to “SIP”
