Hello all,
So we indicate to the users it's not possible to see colleagues or to dial by name.
Anyway it's strange despite the cost differenciation between oxo and oxe.
Bye.
can't possible to reach enterprise directory from 4019
- tot3nkopf
Re: can't possible to reach enterprise directory from 4019
Again: It is working on both. On OXE you need advanced (not standard) license.
well...
2 things, a spadmin output to solve the mistery and user set config export to be 100% sure
Now about the feature itself...using keys sucks to be called "dial-by-name" should be store-keys-using-search-by-name :/
- tot3nkopf
Exept Alcatel I do not know any other phone with alfanumeric keyboards.cavagnaro wrote: Now about the feature itself...using keys sucks to be called "dial-by-name" should be store-keys-using-search-by-name :/
So I would say that dialing by name using the keypad is pretty normal and of course better than no directory.
Oh yeah, I mean, on pure PBX side of course ALU is the only one I think, but these days, Lync, many SIP interfaces integrate with LDAP and stuff like that so no more a "unique" feature...
Anyway, that is discussion for engineering level apart
hello tot3nkopf,
strange...
i have checked this some times ago on a bics oxe (r9.1) and it didn't work even if the set has more multilines and uses the advanced license.
this means i can give the right for "call by name and minimail" for the telephone but a long press on the phonebook button doesn't bring up any call by name function. the only function that will work is that the 4018/9 can now receive text messages (even from another set which is forwarded to text message).
if i find some time... I'll recheck this on oxe r11.0.1...
if you gather more information about this, please post it here.
thanks and regards...
strange...
