OXO sip trunk with Genesys
Re: OXO sip trunk with Genesys
luis.molinas wrote:Hi tot3nkopf,
the numbering 2000 is an extension of the SipServer.
I will try to declare the sip trunk as public.
Regards.
Sorry I meant 6004 (extension in OXO). settings are also for OXO.
Of course in Genesys this must be a trunk.
luis.molinas
Post by luis.molinas »
The 6XXX are IP Touch 4018 series
I tried the sip trunk as public and the results is the same. the INVITE sends E2000@remotegatewayIP.
luis.molinas wrote:The 6XXX are IP Touch 4018 series
Try with noteworthy VipPuNua and EXNUVOFoi and check canonical format configured in OXO.
I did not ask the type of set, just if it is configured in one of the attendant groups.
rui.costa
Post by rui.costa »
Still with the SIP trunk as private try the following in the ARS table
Mouse Right click => [x] Opt. Parameters
Calling = priv
Called/PP = priv
Best Regards
Rui Costa
OXE_4400
Post by OXE_4400 »
So.
Have You succeeded to connect OXO <= SIP => Genesys ?
Hey OXE should be as any external DIO gateway. ..if having issues post SIP traces ;-)
Enviado desde mi Xperia Z usando Tapatalk 2
OXE_4400
Post by OXE_4400 »
I prefer not to have issues, that is why I am asking others about connection before offering to customer.
Ohhh ok hehe but should be possible anyway. If you ever do a lab let us know to help. I don't work with OXO but would like to see it done.
Sent using Tap Talk on my Xperia Z
enio.eltz
Post by enio.eltz »
Hi luis.molinas
Did you get OXO <=SIP=> Genesys working?
I would let SIP trunk as private, in ARS --> called ISVPN as hom and gateway parameters as blank. As it is a trunk to trunk connection between OXO and Genesys (at least what I understand) , gateway parameters is not necessary in this case.
It is necessary to check why OXO is sending the letter E before the number 2000 on the invite. OXO is taking this from some place, and Genesys answers 404 not found because there is no E2000 at Genesys.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
OXE_4400
Post by OXE_4400 »
Enio,
You are quite closely to luis , can You reask him directly? Joke :-)
Return to “Configuration”
