6450p10l switch image is carshed,, wht to do ...
mhrahmanpt
Re: 6450p10l switch image is carshed,, wht to do ...
Post by mhrahmanpt »
Hey Jorge Matias
No, i didnt solve this issue yet..
I am so happy to know that you explained in good way..
Thanks alot dear..
I will be back to lab on Saturday .. and will try to fix it.. hope will work out.
once again thanks for step by step explanation. .
devnull
Post by devnull »
There a Techtip regarding flash Errors on 6450 (and 6250).
Techtips are 12505 (for 6450) and 12506 (for 6250)
Release note states the bug was fixed in 6.6.3 451.
Jorge described the necessary steps to recover..
mhrahmanpt
Hi..
I saw one post in unleased that , to issue command "setNextRunningVersion 2" and "reboot" and it is rebooting into working.
after that i got login console.. and logged in with default usernam and passoword.
then i checked directories as shown below.
ls certified
drw 2048 Feb 3 2000 ./
drw 2048 Feb 3 2000 ../
?-- 0 Jan 1 1970 KFbase.img
-rw 2325506 Dec 31 2000 KFdiag.img
-rw 5083931 Dec 31 2000 KFeni.img
-rw 2511585 Dec 31 2000 KFos.img
-rw 597382 Dec 31 2000 KFsecu.img
-rw 705 Dec 31 2000 software.lsm
-rw 2025 Feb 3 2000 boot.cfg
59908096 bytes free
-> ls working
Listing Directory /flash/working:
-rw 15510736 Dec 31 2000 KFbase.img
59908096 bytes free
BUt i after this i checked flash.. ( -> fsck /flash) and found errors as below..
Error found in inode tree of the following:
/certified/KFbase.img
Results of check on all directory contents and inodes.........ERROR
Errors Detected:
Invalid Inode Meta Block Encountered.
Volume Information:
2,048 bytes per block.
55,104 total blocks in volume.
relFsChk Error = 209.
Error (209) checking the media
An error was encountered during fsck processing.
This error was not repaired by fsck.
ERROR: Call to fsck failed.
ERROR: resource allocation failure
My concern on this issue is , is reimage is still necessory ( even if this error persist ) , as it is booting to configuration console..
kindly note that .. KFbase 's size in certified mode is 0 ( is this error..)
Dear Hey Jorge Matias and Devnull .. kindly help me on this ..
jdsm
Post by jdsm »
mhrahmanpt wrote:Hi..
At this point you don't want to try to recover filesystem, because data in flash is irrecoverable! You need to format the filesystem and install a freshly new firmware!
Follow the instructions I have written in my previous post, which includes the flash formatting.
That will bring your switch into a properly working condition again.
Jorge Matias
devnull
Post by devnull »
If you don't recover now you will have the same error after a reboot (Working and certified differ -> hence it boots certified with the 0 byte base.img)
-> recreate flash and recover with a current release.
If you copy your boot.cfg into your recovery USB Stick it will copy that as well, so you don't have to reenter the whole configuration. You'll still need the UserTable, banners aso..
mhrahmanpt
devnull wrote:If you don't recover now you will have the same error after a reboot (Working and certified differ -> hence it boots certified with the 0 byte base.img)
Hey Devnull.
Great reply.. now it is clear .. thanking you alot.. may god bless you
Regards.
Musthafa Habeeb
gamermic
Post by gamermic »
Are you able to do a "ls" command in kernel mode?
Are you able to view Crash.pmd file?
enrique.man
Post by enrique.man »
Thanks for this post! I just followed the procedure indicated by Jorge Matias and it worked smoothly on a OS6250-24.
After power cycling the switch i copied the images to /flash/working directory, and executed "reload working no rollback timeout" so i
could configure the switch and save changes.
-write memory
-copy working certified.
Enrique
Return to “OmniSwitch 6450”
