CPUe and CoCPU batteries
Kaffi
Post by Kaffi »
What are the procedure of changing the batteries ?
I see in the manual it says to replace the batteries of CPUe and CoCPU every 2 years, but it does not state how to do it.
Im a bit skeptical to just pull out the cpu card an remove the battery off the board, as i assume all settings will be lost?
What about downtime of the system?
Re: CPUe and CoCPU batteries
You can do 1 CPU At the time if you have 2 CPUs.
Mostlikely it's for time keeping in the BIOS
Return to “Beginner's questions about the OmniPCX OFFICE”
