Omnivista, New device
Motello123
Post by Motello123 »
Hi guys.
I've installed OV 2500 v3.5...
The installation was done with Vmware ESXii 6.0.
We've got just one problem with Vmware tools, i was not able to mount a cdrom and install it.
Now i'm trying to add a new switch, with snmp v3.
This is the config of the switch.
"! Trap Manager:
snmp station 10.139.255.2 162 "snmpuser" v3 enable
! SNMP:
snmp security authentication all
snmp authentication-trap enable
User name = snmpuser,
Password allow to be modified date = None,
Account lockout = None,
Password bad attempts = 0,
Read Only for domains = None,
Read/Write for domains = All ,
Snmp allowed = YES,
Snmp authentication = MD5,
Snmp encryption = DES
Console-Only = Disabled
On the OV web panel, i've configured that discovery profile:
CLI/FTP User Name :snmpuser
SNMP Version :SNMPv3
Timeout (msec) :5000
Retry Count :3
User Name :snmpuser
Auth & Priv Protocol :MD5
Context Name
Context ID
Trap Station User Name :omnivista
Discover Link :Normally
Shell Preference :SSH
Use GetBulk :true
Max Repetitions :10
If i try to discover a new device, the results it 0.
What is wrong?
Or...what thing i've not configured?
Thank you.
Motello.
Re: Omnivista, New device
In switch:
aaa authentication snmp local
ip services snmp - should enabled too
In OV:
have you put the same pw 4x (auth and encryption)?
Abione
Important snmp-trap to activate
Post by Abione »
Hi Silvio,
I want to know the necessary and very important snmp-trap to activate on OS6900, OS6860 that we use Omnivista 2500.
Thank you.
Regards.
AbiOne.
why do you not open a new thread if you have a new question? It will be better for other users to find answers too.
I not fully understand your question.
here the config in the switches for the trap station (= OV-Server) with snmpv3. User xxx ist the already created snmp-user (v3 too).
snmp station 10.10.254.1 xxx v3 enable
snmp authentication trap enable
Return to “OmniVista 2500 v3.5”
