6465 enable POE
Navap
6465 enable POE
Post by Navap »
In alcatel6465 industrial switch the Poe command not working.. its showing power supply not configured.cinfigure it using power supply command.
Even I try command power supply enable 1.. error: command not working in this platform..
What is the solution and command for enable Poe on this?
Re: 6860E vf-link-mode issue
Hi Navap,
hello in the forum. Please open a new thread (new topic) for a new question. Your is very different to this thread (and the wrong switch-type).6465 is Rel. 8 - maybe you know up to now only Rel. 6 switches (f.e. 6350/6450). So look into the cli-guide for R8-Switches. And you will find "lanpower service start slot ...."
best regards
Tommy124
Re: 6465 enable POE
Post by Tommy124 »
powersupply <number> name <string> type [ale/phoenix-contact/ third-party] wattage <75-185>
powersupply enable <slot>
The wattage part is only for the third party type, otherwise it is 24-48vdc or hi-ac or lo-ac
after this you should be able to enable POE
Kind Regards,
Tommy
Marvin
Re: 6465 enable POE
Post by Marvin »
I have some problem also with this switch. How can i enable the POE switch. Is it supported the axis camera on this OS6564-P6? Please help me. And advance thank you.
pstolpe
Re: 6465 enable POE
Post by pstolpe »
AOS 8 is different from AOS 6. In 8 you have to use the lanpower command to enable lanpower.
lanpower slot 1/1 service start
Return to “OmniSwitch 6465”
