pickup group like other vendors.
knarf
Post by knarf »
we build a app, to make the same feature than in oder pbx systems, like u...y.
each user is able to activate the popup on his phone with, or without beep.
If a call arrived to a set in the same pickup group the user get a popup with the caller and called info and he could choice pickup or not.
this is a very popular feature in the world, i hope so.
best regards
Re: pickup group like other vendors.
Web, doc, something?
tgn
Post by tgn »
i think he means sys-groupcall. the is a short description and one screenshot here https://www.sys-tel.de/en/software/alca ... lications/
regards...
--- back to basics... focus your eyes on the essential things... ---
knarf
Post by knarf »
hi, we work on to translate all apps.
that's the reason why the screenshots in german
firdaouse1984
cannot pickup group on external call
Post by firdaouse1984 »
hi everyone,
i have 1 problem with OXE which is i cannot pickup line from external call.But internal call is working good.
situation:
when i"m using my mobile phone call to direct line it will ring to ext :1234 ..Ext 1234 and 1235 is in same group pickup but ext 1235 cannot pickup 1234 line.But it working when internal call.
can someone help me on this.I am using only direct line to call in and out .
External call - usual DID call to ext 1234? Or call present on key "line supervision"? Or this call to hunt group?
Return to “IP Touch apps”
