Ominivta 8870 Adminnmc Acount locked
This application replaces the OmniVista 4760
mejust
Post by mejust »
Hello
I have no way to reset my Adminnmc account password :-)
I tried to use toolsOmnivista and I get a message that my account is locked . Through Directory Manager I get the same message.
Im stuck here , I can´t get in Omnivista which is frustrating and I really don´t want to reinstall because I know by experience that I will have to reinstall windows also .
Is there any way that I can unblock my adminnmc account so I reset the password.
Thanks in Advance
rolfo333
Re: Ominivta 8870 Adminnmc Acount locked
Post by rolfo333 »
are you keeping your password policies when creating a new password (unchanged period, length, history)?
Br
mejust
Post by mejust »
Hi Rolfo ,
I can´t even get in Toolsomnivista to be able to think about password policies .
When toolsominivista asked for adimnmc password I get a message that my account is locked due to many tries.
rolfo333
Post by rolfo333 »
So you start ToolsOmniVista, log in with the directory manager password, it stops services, you say Password Update and then number 4 in the following and then it does not let you?
mejust
Post by mejust »
I log in toolomnivista I try login with my directory password and I get a message saying that my account is blocked.
tgn
Post by tgn »
have you tried to login with the ldap client (i think its name is dirmanag.exe)?
regards...
mejust
Post by mejust »
Hi Tgn same thing same message. :(
doublezero
Post by doublezero »
It is possible to set directory manager password directly in database. I will post how to when i am in my notebook
Gesendet von meinem A0001 mit Tapatalk
ACFE OXE R11.1 | ACSE OpenTouch R2.0 | ACSE 8770 R2.5
mejust
Post by mejust »
Thank you doublezero
I can´t wait to know how to do that . Thanks a bunch .
Hoping to hear from you soon :-)
doublezero
1) Change directory: 8770\SunONE\slapd-8770\config
2) Edit: 'dse.ldif'
3) Modify line: nsslapd-rootpw: {SSHA}5lh……
New entry: nsslapd-rootpw: {CLEAR}hugo
(CLEAR means you can fill in the password in a readable format – like 'hugo')
DON'T SAVE THE MODIFICATON YET!
4) Stop service: 'Sun Directory Server 7.0 Control Center'
Stop service: 'Sun Directory Server Enterprise Edition 7.0'
5) SAVE the modification of 'dse.ldif'
6) Start service: 'Sun Directory Server 7.0 Control Center'
Start service: 'Sun Directory Server Enterprise Edition 7.0'
(The 'Sun Directory Server Enterprise Edition 7.0' should start automatically, if not start it)
7) Use the ToolsOmnivista.exe to change the password of the 'Directory Manager'; otherwise the password isn't encrypted in the 'dse.ldif' file.
Return to “OmniVista 8770”
