OmniVista 2500 v4.1.x
dpmp
Post by dpmp »
Hi @all
Is there a demo licence available for the most recent release of OmniVista 2500 v4.1.x?
In licencing center it is only possible to get a demo licence for 3.5
Many thanks in Advanced!
Best regards
Daniel
devnull
Re: OmniVista 2500 v4.1.x
Post by devnull »
AFAIk the starter (10 Licenses) costs 0.10$ so it should be affordable (but it's slower to get)
mursid
Post by mursid »
Hi all,
Is there any demo license for virtual appliance R4.1.2 ?
Thanks and regards,
Mursid
The same like devnull has wrote.
But there is also an evaluation licence possible for 60 days with 50 devices.
https://service.esd.alcatel-lucent.com/ ... ce/OV25411
Step 1 - Enter Customer ID and Order Number
Enter the values shown below, then click Next:
· Customer ID - 99999
· Order Number - evaluation
Step 2 - Select the License Type and Quantity
Select the License Type and the number of devices to be managed from the drop-down menu (e.g., Evaluation NM License for 50 devices - EVAL-NM-EX-50-N_1); then enter the Passcode (alcatel), and click Submit Entry.
Step 3 - Complete the License Registration Form
Complete all of the required fields on the License Registration Form and click Submit. A Confirmation E-Mail will be sent to the e-mail address entered.
Step 4 - Download the License Key
After submitting the License Registration form, click OK at the confirmation prompt to download the license key into Notepad.
strelok
Post by strelok »
Hi !
We have OmniVista 3.5.6.
Can we upgrade it to 4.1.1 with using old license key ?
Hi strelok,
your licence is named 3.5. So you need an upgrade license. upgrade is cheaper than the normal license. But be aware that the new license is counted by all switches - not the managed ip adddresses like in 3.5. So for a stack or VC with 4 switches you need a license for all 4.
strelok
Post by strelok »
Hi silvio.
Thank you for answer.
Now it's clear.
HUSSAINQCS
Post by HUSSAINQCS »
What is the core licenses need to put ?
HUSSAINQCS
i have the VMM evaluation licenses
VMM is for virtual machines.
For switches you need the core licenses.
Return to “OmniVista 2500 v3.5”
