Hello:
I have an OXO R6.10 system with a E-1 ISDN PRI card connected to the public carrier. There are two specific numbers (the customer HQ call centers) that can not be dialled from digital sets but on analog sets the call is OK (also external calls to any set forwarded to these numbers). Using the trace tool in OMC, I managed to make both traces almost the same. There is only one line that differs from the digital set call trace and the analog set call trace, but the digital set still can not make the call. For all other numbers both type of sets can dial ok, even if the traces are not the same.
These are the traces for a bad call (digital set) and a good call (analog set)
BAD CALL (DIGITAL SET)
ISDN3_00039 17/11 09:23:21 TX d_channel: 42 (S:00 T:000) payload: (49) 08 02 00 30 05 04 03 90 90 A3 18 01 A3 1E 02 85 83 6C 09 01 80 33 34 30 35 38 30 30 70 10 81 30 31 31 30 30 38 30 30 30 35 32 31 32 37 35 7E 01 04
0x05 SETUP Ref: O,48
ie 0x04 Bearer capability: 90 90 A3
Coding: CCITT standardized
Information transfer capability: 3.1 kHz audio
Transfer mode: Circuit mode
Transfer rate: 64 Kbit/s
User info layer 1: G.711 A-law
ie 0x18 Channel identification: A3
Interface identifier: Implicit
Interface type: Primary rate
Indicated channel: Preferred
D-channel identified: No
Information channel selection: any channel
ie 0x1E Progress indicator: 85 83
Progress: Origination address is non-ISDN
ie 0x6C Calling party number: 01 80 33 34 30 35 38 30 30
Number type: Unknown
Numbering plan: ISDN/Telephony(CCITT Recommendation E.164/E.163)
Presentation: presentation allowed
Screening: user-provided, not screened
Number: 3405800
ie 0x70 Called party number: 81 30 31 31 30 30 38 30 30 30 35 32 31 32 37 35
Number: 011008000521275
ie 0x7E User-user: 04
ISDN3_00040 17/11 09:23:21 RX d_channel: 42 (S:00 T:000) payload: (10) 08 02 80 30 0D 18 03 A9 83 81
0x0D SETUP_ACK Ref: D,48
ie 0x18 Channel identification: A9 83 81
Indicated channel: Exclusive
D-channel identified: Yes
Information channel selection: B1 channel
Channel type: B-channel units
Channel number: 0x01
ISDN3_00041 17/11 09:23:23 RX d_channel: 42 (S:00 T:000) payload: (13) 08 02 80 30 45 08 02 84 9F 1E 02 82 88
0x45 DISCONNECT Ref: D,48
ie 0x08 Cause: 84 9F
Class: Normal event
Value: Normal, not specified
ie 0x1E Progress indicator: 82 88
Progress: In-band information or appropriate pattern now available
ISDN3_00042 17/11 09:23:24 TX d_channel: 42 (S:00 T:000) payload: (9) 08 02 00 30 4D 08 02 81 90
0x4D RELEASE Ref: O,48
ie 0x08 Cause: 81 90
Class: Normal event
Value: Normal release
ISDN3_00043 17/11 09:23:24 RX d_channel: 42 (S:00 T:000) payload: (5) 08 02 80 30 5A
0x5A RELEASE_COMP Ref: D,48
GOOD CALL (ANALOG SET)
ISDN3_00047 17/11 09:24:04 TX d_channel: 42 (S:00 T:000) payload: (46) 08 02 00 31 05 04 03 90 90 A3 18 01 A3 1E 02 85 83 6C 09 01 80 33 34 30 35 38 32 33 70 10 81 30 31 31 30 30 38 30 30 30 35 32 31 32 37 35
0x05 SETUP Ref: O,49
ie 0x6C Calling party number: 01 80 33 34 30 35 38 32 33
Number: 3405823
not here??
ISDN3_00048 17/11 09:24:04 RX d_channel: 42 (S:00 T:000) payload: (10) 08 02 80 31 0D 18 03 A9 83 81
0x0D SETUP_ACK Ref: D,49
ISDN3_00049 17/11 09:24:06 RX d_channel: 42 (S:00 T:000) payload: (5) 08 02 80 31 02
0x02 CALL_PROCEEDING Ref: D,49
SAN_00050 at line 8081 "depub_aels"
on 17.11 at 09:24:06 (2060700497)
info : 0000 7305 0000 0001 FFFF FFF9 FFFF FFFF
ISDN3_00051 17/11 09:24:06 RX d_channel: 42 (S:00 T:000) payload: (13) 08 02 80 31 01 1E 02 8A 88 1E 02 8A 81
0x01 ALERTING Ref: D,49
ie 0x1E Progress indicator: 8A 88
ie 0x1E Progress indicator: 8A 81
Progress: Call is not end-to-end ISDN: more info may be available in-band
SAN_00052 at line 8081 "depub_aels"
on 17.11 at 09:24:06 (2060700524)
ISDN3_00053 17/11 09:24:06 RX d_channel: 42 (S:00 T:000) payload: (13) 08 02 80 31 07 1E 02 84 84 4C 02 00 C3
0x07 CONNECT Ref: D,49
ie 0x1E Progress indicator: 84 84
Progress: Call has returned to the ISDN
ie 0x4C: 00 C3
ISDN3_00054 17/11 09:24:12 TX d_channel: 42 (S:00 T:000) payload: (9) 08 02 00 31 45 08 02 85 90
0x45 DISCONNECT Ref: O,49
ie 0x08 Cause: 85 90
Class: Normal event
ISDN3_00055 17/11 09:24:12 RX d_channel: 42 (S:00 T:000) payload: (5) 08 02 80 31 4D
0x4D RELEASE Ref: D,49
ISDN3_00056 17/11 09:24:12 TX d_channel: 42 (S:00 T:000) payload: (5) 08 02 00 31 5A
0x5A RELEASE_COMP Ref: O,49
The only difference is this line on the digital set call: ie 0x7E User-user: 04, before the call release.
Anyone knows about this message and how can be avoided?
Greetings,
Chamizo
E-1 ISDN call on analog set ok but on digital set not ok
Re: E-1 ISDN call on analog set ok but on digital set not ok
Post by et »
This is a user to user signalling element. May be your provider doesn't accept this. Try to disable flag in Subscribers/ Details/ Features/ UUS Allowed for digital subscribers. Temporarily. But furthter investigations may be useful.
Post by Chamizo_DUP »
Well, disabling UUS on the extensions worked. The public operator only told me that the good calls were non-ISDN and the bad calls were ISDN, and they no dot support ISDN calls. I think this would be the permanent solution.
Thanks..
Thanks..
Jump to
- General topics
- ↳ Talk to the admins
- ↳ GENERAL
- ↳ Outside World
- ↳ PARTS
- ↳ Pre-Sales
- ↳ JOBS
- ↳ Remote assistance contracts
- ↳ Actis
- ↳ Equipement Pictures
- ↳ OT/OXE/OXO FEATURES REQUESTS
- ↳ Lucent Technologies
- IF YOU ARE NOT TECHNICALLY TRAINED ON THOSE PBX, PLEASE POST IN ONE OF THOSE FORUMS
- ↳ Beginner's questions about the Crystal Hardware
- ↳ Beginner's questions about the Common Hardware
- ↳ Beginner's questions about the (4400 / Enterprise) PHONE APPLICATION or OPERATING SYSTEM
- ↳ Beginner's questions about the OmniPCX OFFICE
- VOICE - Documentation
- ↳ OXE (Crystal / Common) - System Documentation
- ↳ 4760
- ↳ OXO - System Documentation
- ↳ Documentation
- VOICE - OXE (OmniPCX Enterprise)
- ↳ Shelf
- ↳ Media Gateway
- ↳ PWT/DECT System
- ↳ System
- ↳ Translator
- ↳ Classes of Services
- ↳ Attendant
- ↳ Users
- ↳ Users by profile
- ↳ Set Profile
- ↳ Groups
- ↳ Speed Dialing
- ↳ Phone Book
- ↳ Entities
- ↳ Trunk Groups
- ↳ External Services
- ↳ Inter-Node Links
- ↳ X25
- ↳ Data
- ↳ Application
- ↳ Specific Telephone Services
- ↳ ATM
- ↳ Event Routing Discriminator
- ↳ Security and Access Control
- ↳ IP
- ↳ SIP
- ↳ DHCP Configuration
- ↳ Alcatel-Lucent Series 8&9
- ↳ SIP Extension
- ↳ Encryption
- ↳ Passive Communication Server
- ↳ SNMP Configuration
- VOICE - OXE - Common topics
- ↳ MAIN
- ↳ ACTIS
- ↳ Asterisk
- ↳ Boards
- ↳ Bugs & Security issues
- ↳ Equipment Pictures
- ↳ Feature Request
- ↳ H323 / Sip
- ↳ IP / VoIP
- ↳ IP SECURITY / ENCRYPTION (Thales)
- ↳ ipTouch (40x8) issues and tricks
- ↳ Linux tricks
- ↳ MOH
- ↳ ON SITE TROUBLES
- ↳ Phones
- ↳ Sipfoundry
- ↳ Software Loading
- ↳ Swinst
- ↳ System Hacking
- ↳ Traces
- ↳ Usefull commands
- ↳ Voice Guides
- ↳ Wireless configuration and sets
- VOICE - OpenTouch
- ↳ MAIN
- ↳ OTEC - OpenTouch Enterprise Cloud
- ↳ OTBE - OpenTouch Business Edition
- ↳ OTMS - OpenTouch Multimedia Services
- ↳ OTSBC - OpenTouch Session Border Controller
- ↳ OTNS - OpenTouch Notification Service
- ↳ OTMC - OpenTouch Message Center
- ↳ OTFC - OpenTouch Fax Center
- ↳ OpenTouch Conversation
- ↳ Smart Guest Applications
- VOICE - BiCS
- ↳ MAIN
- VOICE - OXO
- ↳ MAIN
- ↳ Configuration
- ↳ 42xx Systems
- ↳ Networking
- ↳ H323 / IP / Pimphony
- ↳ Internet and related
- ↳ Applications
- ↳ Hotel mode
- ↳ DECT
- ↳ Hardware
- VOICE - Omni Suite
- ↳ OmniTouch 8400 Instant Communication Suite
- ↳ OmniTouch 8410 Instant Communication Web Services
- ↳ OmniTouch 8440 Messaging Software
- ↳ OmniTouch 8450 Fax Software
- ↳ OmniTouch 8460 Advanced Communication Server
- ↳ OmniTouch 8464 Meet-me Audio Conference Bridge
- ↳ OmniTouch 8660 My Teamwork Conferencing and Collaboration
- ↳ OmniTouch 8670 Automated Message Delivery System
- ↳ OmniTouch Contact Center Standard Edition
- ↳ OmniTouch Contact Center Premium Edition
- VOICE - Applications
- ↳ AECS - Alcatel Extended Communication Server
- ↳ Alcatel OpenTouch Customer Service
- ↳ Aviso
- ↳ Call Center SoftPanel (ALU ProServices)
- ↳ CCD / CCS / CCIVR
- ↳ Free Desktop
- ↳ GENESYS
- ↳ Hotel / Hospital
- ↳ Ip Desktop Softphone
- ↳ IpTouch Phones XML Applications
- ↳ MSAD
- ↳ MyIC (My Instant Communicator)
- ↳ My Messaging / IMAP
- ↳ My Teamwork (ex-eDial)
- ↳ OmniPCX Record
- ↳ OmniVista 4760
- ↳ OmniVista 8770
- ↳ OTUC
- ↳ PREMIUM / GCE
- ↳ Rainbow
- ↳ Ubiquity
- ↳ ENS - Emergency Notification Server
- ↳ VNA - Visual Notification Assistant
- ↳ VAA - Visual Auto Attendant
- ↳ VitalSuite
- ↳ VitalQIP
- ↳ Voicemail (46x5)
- ↳ XML Presentation Server & TAPI Server
- ↳ 4980 - WebSoftPhone
- ↳ 4625 Interactive Voice Response
- VOICE - Third Party Applications
- ↳ AGITO NETWORKS
- ↳ AUDIOCODES
- ↳ ASTERISK
- ↳ AVST
- ↳ CDR Real time on Ethernet
- ↳ CISCO
- ↳ NGINX
- ↳ NICE
- ↳ Notification Systems
- ↳ OAK
- ↳ SOURCE TECH
- ↳ systel
- ↳ IP Touch apps
- ↳ Click2Dial
- ↳ MYIC apps
- Voice - Virtualization
- ↳ AWS
- ↳ Linux KVM
- ↳ VmWare
- ↳ HyperV
- ↳ Other
- Alcatel Unleashed tools, documentations, and misc files...
- ↳ GitHub Script Repository
- ↳ "Home Made" documentations
- ↳ Alcatel Misc Documentation
- ↳ OFFICIAL TC's
- ↳ DIALER
- ↳ infocollect
- ↳ ipview analyzer
- ↳ motview
- ↳ sngrep
- ↳ VM_BACKUP
- ↳ Other Alcatel-Lucent tools
- Developer's corner
- ↳ AHL / OHL
- ↳ Alarming, Notification & Location
- ↳ CCTI / CCA
- ↳ CSTA
- ↳ My IC Phone
- ↳ My IP Touch Service for Enterprise
- ↳ O2G
- ↳ OmniVista 8770 User Provisioning
- ↳ SIP
- ↳ TAPI
- ↳ TSAPI
- ↳ Web Services
- Alcatel Data Equipment
- ↳ Security
- ↳ OmniAccess 3500 Nonstop Laptop Guardian
- ↳ Mobility
- ↳ OmniAccess WLAN Switching Systems
- ↳ OmniAccess WLAN 4302
- ↳ OmniAccess Wireless Access Points 41
- ↳ OmniAccess Wireless Access Points 65
- ↳ OmniAccess Wireless Access Points 60/61/70
- ↳ OmniAccess Wireless Access Points 80M
- ↳ Mobile IP Phones
- ↳ OmniAccess Devices
- ↳ OmniAccess 5780
- ↳ OmniAccess 5740
- ↳ OmniAccess 5510
- ↳ Network Management
- ↳ Omnivista
- ↳ Omnivista Mobility Manager
- DATA - Documentation
- ↳ Technical papers
- ↳ Troubleshooting guides
- DATA - Lan Switching
- ↳ OmniSwitch 10k
- ↳ OmniSwitch 9900
- ↳ OmniSwitch 9000 / 9000E
- ↳ OmniSwitch 6900
- ↳ OmniSwitch 6865
- ↳ OmniSwitch 6870
- ↳ OmniSwitch 6860 / 6860E
- ↳ OmniSwitch 6855
- ↳ OmniSwitch 6850 / 6850E
- ↳ OmniSwitch 6560 / 6570M
- ↳ OmniSwitch 6465
- ↳ OmniSwitch 6450
- ↳ OmniSwitch 6400
- ↳ OmniSwitch 6360
- ↳ OmniSwitch 6350
- ↳ OmniSwitch 6250
- ↳ OmniSwitch 2220
- ↳ OmniSwitch 2260 / 2360
- ↳ Legacy Devices (OS4024, XOS, OmniCore)
- ↳ OmniSwitch 6600 / 7000 / 8800
- ↳ OmniSwitch 6800
- ↳ OmniStack LS 6200
- ↳ Misc
- DATA - WLAN, Mobility and WAN
- ↳ OmniAccess WLAN Switching Systems (OEM)
- ↳ Mobile IPTouch Phones (MIPT)
- ↳ OmniAccess Stellar Express
- ↳ OmniAccess Stellar Enterprise
- ↳ Brick VPN Firewall
- ↳ OmniAccess 5740/5780
- ↳ OmniAccess ESR 5720
- ↳ OmniAccess 5510
- DATA - Network Management
- ↳ OmniVIsta 3600 Air Manager
- ↳ OmniVista 2500 v4.x
- ↳ OmniVista 2500 v3.5
- ↳ OmniVista 2500/2700 v3.4 and older
- ↳ OmniVista Cirrus
- ↳ Alcatel Quarantine Manager
- ↳ Fortigate Security
- DATA - Service Provider
- ↳ 5520 ASAM
- ↳ 5620 SAM
- ↳ 5650 CPAM
- ↳ 5670 RAM
- ↳ 5750 SSC
- ↳ 7210 SAS
- ↳ 7360 ISAM
- ↳ 7450 ESS
- ↳ 7450 Ethernet Service Switch
- ↳ 7750 Service Router
- ↳ 7705 SAR
- ↳ 7750 SR
